Question about Refrigerators
I have a daewoo fridge with ice and water model FRN-Y22D2W and the waters not working need help
3 Suggested Answers
thompsonds20
  • 53 Answers
SOURCE: How to make ice cubes ?
Just fill pure water in the ice tray and allow it to cool for an hour your ice cubes will be ready. DO NOT OPEN IN THE MIDDLE TO SEE THE ICE FORMATION!
Posted on Jul 06, 2009
m_tragic
  • 66 Answers
SOURCE: I have a daewoo side by side by side fridge model
Your switch is faulty. Instead of turning off...it stuck on.
Posted on Dec 02, 2013
Ice maker problem daewoo frs-2031 IAL
I wouldn't buy a Daewoo fridge with Donald Trump's money!
Jun 27, 2016 | Daewoo Freezers
Daewoo frsu20dci fridge freezer, hiya, hope you can help. Our fridge freezer is making ice and dispensing ice but no water is coming out of the water dispenser when pressed. Help!!!
Check your water filter. They are known for clogging up. If that doesn't work...check your water inlet valve.. if that doesn't work check to see if you have a pinch in your waterline.
Jun 25, 2015 | Daewoo Refrigerators
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Jul 22, 2014 | Daewoo Freezers
I have a Daewoo FRN U20DA type american fridge freezer. The Ice maker has sropped working. There is no water getting into it. There is water getting through to the water dispenser in the front door. the...
The water filter should be changed every six months, not two years.
The water lines may still be frozen even though you turned the unit off, but most likely you are not getting water flow due to a clogged filter. Change it.
Feb 26, 2011 | Daewoo Freezers
So why does it take so long for the fridge to produce ice, and why after being turned on for 5 hours from new is there no water in the ice tray? The water runs via the water dispenser so why is it not in...
first, why are you asking a question on fridges in a section about cars specifically Daewoo.BUT to answer your question......a fridge/freezer needs about 24 hours for the whole system to settle down,and reduce the internal temp BEFORE it makes ice,
Nov 10, 2010 | 1999 Daewoo Lanos
Daewoo frnu20da Water/ice dispenser supply
Makes no sense, you would be back and forth every twenty minutes.
Jul 23, 2010 | Freezers
The freezer compartment of my daewoo FRN-U20DA is not cold enough and the ice is melting. The fan does not come on and there is no fault indicated on the display panel.
when the fan is not working. you cannot expect an ice cause the fan is to drive the cold to become an ice and to maintain the coldness.
Jun 23, 2010 | Freezers
Ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Jul 19, 2009 | Daewoo Refrigerators
Jul 06, 2009 | Refrigerators
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
