Question about GE Refrigerators
Evaperater fan making noise
Model gfsl6kkybls
    Top Expert:
  • GE Master
  • 12,962 Answers
Bearings are shot on that motor. U can try a light weight oil on them but it appears that the best route is to just exchange the motor.
Go to appliancepartspros.com and get the number for the part you need then check out ebay for that part - mucho cheaper that way.
Posted on Apr 01, 2014
Evaperater freezes up at the top fride not getting
IT appears that the evaporator fan motor has failed, or just stuck . Open the inside rear panel to check this component
Oct 05, 2014 | Refrigerators
How do you change a evaperater fan on a Beverage air bottle cooler?
Its a pain but reach down in there and pull the screws out and remove the panels. Its in there honest! Hope this helps good luck.
Jul 12, 2014 | True TD-50-18 Beverage Cooler
Samsung model RS263TDBP/XAA
How to Test the Fridge Fan on Samsung Refrigerator Once you have the fan motor out put a drop of machine oil in the bearing caps. That will stop the noise.
Feb 14, 2018 | Refrigerators
My Viking Freezer is three years old. The problem is the constant roaring sound it makes. No one can sit in my kitchen, family room or living room for very long before the noise from this freezer gets on...
There are several fans on your unit one on the top with the compressors, one inside the freezer, and one at the bottom. If you open the freezer and the noise gets louder or stops then you know it is the evaperater fan. Sometimes the bearings start to go and they make louder noise. Also check on the back wall for frost you could have a frosting problem and the fan blade is hitting on the ice
Oct 23, 2017 | Viking 15.9 cu. ft. Upright Freezer...
No evaperater fan run,compressor running,coil is frosting but no voltage to inside fan.
Look to the fan delay/defrost terminator that is located inside to the evap. It is usually attached to the evap coil. check there first.
Aug 25, 2010 | True 206 cu. ft. Freezer TWT-67F
OUR XEROX COPY MACHINE MAKES A SQUEALING NOISE WHEN MAKING COPIES
On this model most squeeling noises come from the fuser assembly.
If it is that loud replace the fuser assembly.
Other known prolbems is with the fuser fan in the back.
To see if it is the fuser fan, take off the back cover.
When the machine makes a copy unplug the fan very momentary. See if the noise goes away.
If the noise is still there, then it is possible the fuser is causing the problem.
Make sure the correct fuser is installled on this machine model.
Oct 21, 2009 | Xerox CopyCentre C20 Black and White...
Fan makes loud noise when i start car
Firstly we need to know what model etc. Noisy fan if viscus could be the viscus itself - fan blade hitting something on the shroud / housing. First check & make sure the small bolts haven't shaken lose. Good luck
Jun 01, 2009 | 2001 Cadillac DeVille
Heater/ defrost
YOUR GONNA HAVE TO PULL THE AIR BOX OFF & CLEAR THE DEBRI OUT OF THE DRAIN(THE AIR BOX IS LOCATED ON THE PASSENGER SIDE FIRE WALL)IT HOUSES THE EVAPERATER COIL & HEATER COIL..ON THIS MAKE & MODEL I'M NOT SURE WHERE THE DRAIN IS.IT WILL BE A RUBBER LINE THAT GOES NOWHERE BUT OUTSIDE ON THE PASSENGER SIDE OF YOUR CAR(UNDERNEATH OF COURSE)YOUR FAN IS LOCATED IN OR NEAR THE AIR BOX THIS SHOULD GIVE YOU A GOOD STARTING POINT.YOU JUST MIGHT TO BE ABLE TO CLEAR IT WITH A FINE PIECE OF WIRE.SORRY BUT THIS A GENRIC OF WHAT I COULD TELL YOU,BUT ITS 2 IN THE MORN & I NEED TO GO TO BED.LET ME KNOW.OR CONTACT ME LATER TODAY & I'LL GIVE YA A LITTLE MORE DETAILED IMFO.THANX FOR USING FIX-YA
Nov 13, 2008 | 2002 Mitsubishi Lancer
LBF6
Frost over the box tells me that you do have refrigerant flowing through the evaporator coil. If the coil has a defrost element as you stated it should also have a fan for circulating the cold air. Apparently your fan is not operating.
Jul 26, 2008 | Freezers
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
