Question about LG LFX21971ST Stainless Steel Bottom Freezer French Door Refrigerator
LG LFC22740 bottom freezer refrigerator ice maker won't work
Ice maker doesn't work
rickzilla
  • 706 Answers
SOURCE: Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Posted on Sep 15, 2008
daddyo742001
  • 70 Answers
SOURCE: We have a LG bottom
Make sure water is gettig to solenoid vale on back. If so make sure screen is not plugged and solnoid is real opening. May need to test coil on valve. If it is not opening or froze off Ice marker will cycle several times a day as it is temp actuated.
Posted on Jun 29, 2009
SOURCE: lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Posted on Jul 12, 2009
  • 1768 Answers
SOURCE: fridgew/ice maker. ice tastes like sulfer.
This sound like you need a water filter change to the refrigerator.
Posted on Aug 05, 2009
EllaWatson25
  • 725 Answers
SOURCE: lg, french door, bottom freezer ice maker doesn't
It is possible that your ice maker has gone out. Can you tellme how old yiur refrigerator is? Normally , they can go out after abouit 18 monthw depending on different instances.
We will be happy to help get you going agin. If you would like for us to continue to assist you, you can contact us at :
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We are at your service and look forward to working with you.
Posted on Nov 07, 2009
Freezer not cold enough, not making ice. Refrigerator seems OK.
Refrigerant levels need to be checked. Freezer needs a higher level of refrigerant than the opposing side.
Jun 08, 2015 | LG LFC22740 Bottom Freezer French Door...
Icemaker doesn't work
If the ice maker is not filling, you will need to replace the "water inlet valve" on the back of the unit. Here is the part you need to order.
Oct 31, 2012 | LG Electronics LDC22720SW 22 Cu. Ft....
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ice maker doesn't make ice. It seems to not being able to rotate the ice tray to dump the ice.
this may be a bad heater in bottom of ice maker . if so replace the ice mker .. but do ck the tempts ..freezer must be 15 de or lower for ice maker to work properly .. hope this helps mm .. feed back pls ..
Jul 10, 2011 | LG LMX28988
NOT MAKING ICE JUST HOOKED UP WATER LINE AND TURNED ON TWO HOURS AGO
if you have just purchased the ref. and hooked it up it will take 24 hours for the ref. to get to correct temp.Plus the ice maker wont start to work until the freezer temp gets to 15 degrees.if the ref. has been in use then check the power button on the ice maker itself and make sure the power is on.
Nov 03, 2010 | LG LFC22740 Bottom Freezer French Door...
LG french door refrigerator ice maker
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 11, 2010 | LG LFC25770ST (250 cu ft) Bottom Freezer...
Refrigerator section not cooling
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 20, 2010 | LG LFC22740 Bottom Freezer French Door...
Fridgew/ice maker. ice tastes like sulfer.
Aug 05, 2009 | LG LFC20760ST Stainless Steel Bottom...
LG LFX 25950SB, the Ice Maker is not working, just hear a click
heatman101
klh
Feb 22, 2009 | LG LFX25960 Bottom Freezer French Door...
LG LFX21971ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
23 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
