Question about Nissan Vehicle Parts & Accessories
Speed sensor hello, i have Nissan sunny model 1996 the speed sensor do not work property i need to know how to replaced and the location please thank you so much.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
The speed sensor would probably be on the side or ontop of the transmission. I would order the part and look for its twin on the car and replace it. normally they are held in by a pressure plate with one bolt.
Posted on Apr 02, 2014
2 Suggested Answers
sxygaman
  • 95 Answers
SOURCE: how to change automatic transmission to manual transmission in nissan sunny 1996 AWD
this is a lot of work you have to change the flywheel cut access panel for clutch pedal run new lines for master and slade cylinder as well as cut access panels for shfter cables the do sell kits for conversion with clutch pedals and most hardware hardest part is finding the right flywheel
Posted on Aug 12, 2012
Where is the Nissan Xterra 2005 Speed Sensor Located and what does the main speed senor look like?
could be the vehicle speed sensor (VSS) and is on the trabsmission
talk with an accredited auto specialist to get the exact location or get a workshop manual to see how to test /replace it
could be very possible wiring problem and dirty connectors in the harness
Jul 15, 2017 | Nissan Cars & Trucks
Transmission speed sensor ocation
sensor is usually mounted on transmission
Apr 01, 2014 | Nissan Vehicle Parts & Accessories
Where would I find my speed sensor on a 1996 honda civic dx in order to replace it, and how would i replace it.
It is located on the side of the transmission, requires 1 bolt, will notice a power plug which you must unplug wire connector, remove the bolt then the sensor canbe removed from your transmission it will pull out. Before installing your new sensor you may want to rub a little transmission oil on the part of the sensor that goes in transmission there is a o-ring on the part. This will help it go in alot more easier also lubricate you new part. Hopefully this was helpfull the sensor is around $100.00 - $140.00.
Jan 09, 2011 | 1996 Honda Civic
I purchased 1500cc NISSAN Sunny 1996 model Car. Up to 80 km speed , she behaves very well. Above 80 frequently she hangs up with sudden reduction in speed. Why this misbehaviour?. When am I supposed to...
20/50 ,cheapest oil and change every 6000mile with oil filter every third oil change ,as for hold back ?=?could be anything under the bonnet causing this
Nov 20, 2009 | 1996 Nissan 200SX
Need HELP! locating the MAP sensor and the Camshaft sensor for an
The MAP sensor is on the breather hose next to the breather box,The speed sensors are pictured below.Please take time to rate this a fixya.
May 16, 2009 | 1996 Plymouth Grand Voyager
Problem with engine ligt on
Its located on the air cleaner box (the box where your air filter is) Its had cylindrical shape and kinds square on the top its black in color and had a plug on it. There is rubber intake hose connected to it. Good luck and thanks for using Fix-ya
May 05, 2009 | 1996 Nissan Maxima
Nissan sunny mod 96 dtc codes
There is a connector under the steering column, you need to buy an OBD 2 system scanner to plug into that connector and access the codes. The system is always in diagnostic mode, OBD 2 stands for On Board Diagnostics second generation.
Sep 22, 2008 | 1996 Nissan Sentra
Nissan ga15 engine idle adjustment locations
The idle speed is computer controled, it is not adjustable, you most likely have sludge in the throttle valve and the idle speed control air bypass valve, clean them with carb spray with the engine running.
Sep 17, 2008 | 1996 Nissan Sentra
Vehicle Parts & Accessories Logo
57 people viewed this question
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
George Agios
George Agios
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
