Question about Nissan Vehicle Parts & Accessories
Transmission speed sensor ocation
My speed sensor working some time i need to know how i can replaced and her location please my car Nissan sunny model 1996 thank you so much
    Sergeant:
  • 462 Answers
Sensor is usually mounted on transmission
Posted on Sep 07, 2014
2 Suggested Answers
sxygaman
  • 95 Answers
SOURCE: how to change automatic transmission to manual transmission in nissan sunny 1996 AWD
this is a lot of work you have to change the flywheel cut access panel for clutch pedal run new lines for master and slade cylinder as well as cut access panels for shfter cables the do sell kits for conversion with clutch pedals and most hardware hardest part is finding the right flywheel
Posted on Aug 12, 2012
2000 nissan maxima transmission problem
Vehicle Speed Sensor" IS BAD. Vehicle Transmission Speed Sensor at AutoZone com Best Vehicle...
2000 Nissan/Datsun Maxima 3.0L SFI DOHC 6cyl
The Vehicle Speed Sensor - Location is located: Mounted on transmission
Jul 25, 2015 | Nissan Cars & Trucks
Speed sensor
The speed sensor would probably be on the side or ontop of the transmission. I would order the part and look for its twin on the car and replace it. normally they are held in by a pressure plate with one bolt.
Apr 01, 2014 | Nissan Vehicle Parts & Accessories
Need to know the location of a speed sensor on a 2000 Nissan Maxima
The speed sensor (transmission revolution sensor) is located on the left side of the bellhousing near the top. Access is through the driver's side wheel well.
Jun 29, 2010 | 2000 Nissan Maxima
Speed sensor location on a Nissan Maxima 2000 gxe
There are two speed sensors one is called a revolution sensor that is located on the case of the transmission. You can take the driver side wheel off and see the sensor on the top of the case of the transmission. A 10mm bolt is holding it in. Easy fix
May 20, 2010 | 2000 Nissan Maxima
Spedometer and trip meter stopped working
You need to replace your speed sensor. It is located on the transmission, usually held in by 1 bolt, and has a wire clip attached. It is usually a easy repair, but sometimes the old speed sensor doesn't want to come out easy.
May 04, 2009 | Nissan Pathfinder Cars & Trucks
Location of speed sensor in alitma 2005 2.5
Boritz2: there are several speed sensors on this vehicle, so I will give you the locations of all of them due to the fact that I don't know which one you are seeking.
There are speed sensors located at each wheel to work with the ABS unit.
On the trans-axle, on the driver's side near the top of the transmission.
I hope this has been helpful to you.
Is there a reason you are looking for the speed sensor?
Mar 21, 2009 | 2005 Nissan Altima
Where is the vehicle speed sensor located on a 91 nissan pickup
The speed sensor is located on the transmission towards the tail shaft. The housing that encloses the cable will attach on the side of the tranny. At this connection you will find the speed sensor right where it attaches to the tranny. There will be a couple of wires attached to the speed sensor.
Jan 15, 2009 | 1991 Nissan Pickup
1996 HONDA THE SPEEDOMETER CUTS ON/OFF IT DOSE NOT HAVE A REGULAR
The 1996 Honda Civic does not have a traditional manual Speedometer cable that would require tightening. The speedometer is electronically controlled by a speed sensor located on the transmission. There is a wire that goes from that sensor to the speedometer in the instrument cluster. Either you have a short in the wire or you may have a bad connector either on the back of the cluster or at the transmission. Scanning your car woudl let you know what is happening, especially if you get a P0501 - which is for the speed sensor.
Dec 30, 2008 | 1996 Honda Civic
Nissan ga15 engine idle adjustment locations
The idle speed is computer controled, it is not adjustable, you most likely have sludge in the throttle valve and the idle speed control air bypass valve, clean them with carb spray with the engine running.
Sep 17, 2008 | 1996 Nissan Sentra
Vehicle Parts & Accessories Logo
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Jim Y
Jim Y
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
