Question about HP OfficeJet 4255 All-In-One InkJet Printer
Sharp Printing Post Script Error
I have a Sharp that is printing a PS error after every page it prints out of JD Edwards. I have all error printing turned off. Is there another way to turn this off?
  • 624 Answers
SOURCE: Error Message "Page too Complex"
Hi Sccfire, This apparently is a fairly common problem with the 2800 series printer and associated with connection to a PC using USB. It can only be overcome by manually configuring the printer?s USB port to work in standard mode rather than at high-speed USB2.0 mode which probably won?t be to much of a problem. Here is a link from a support page on HP?s site that should walk you through the process: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00506095 Let us know how it goes and please don?t forget to rate the posting.
Posted on Jan 05, 2007
Inkworks
  • 87 Answers
SOURCE: NO RESPONSE, PRINTER DISPLAY BLANK
sounds like you have a bad formatter....there is a way to circumvent the formatter and print whats called an engine test. this is used just to test the mechanics of the machine and leave the brain out of the equation...
Engine Test Button Location HP laserjet printer 5000 series
The engine test verifies that the print engine is functioning correctly.
The Formatter PCA is completely bypassed during an engine test.
This test is very useful for isolating printer problems. The engine test
prints a full page of lines across the entire printable area, and is also
useful for checking and adjusting registration.
laserjet-5000-engine-test.jpg Note Engine test will print from the last input tray used.
If the last input tray is empty or if the last input source was the duplexer,
then the Engine Test will print from Tray 2 (standard 250 CST).
If Tray 2 is empty (and the last input tray is empty or the last input source
was the duplexer), then the Engine Test will not function.
Printing an Engine Test HP laserjet printers 5000 series
To print an engine test, use a non-metallic object (such as a pencil) to
press the engine test button. A single test page with horizontal lines
will be printed. To print multiple test pages, hold down the engine test
button.
If the engine test prints ok then you have a formatter issue...if you have added memory or a network card try taking them out one at a time to see if the problem goes away. Otherwise the formatter will have to be replaced.
Inkworks
Posted on May 22, 2008
  • 27 Answers
SOURCE: InDesign Printing problem; service error 49.4c02
This is a solution which has been suggested on another site, this has not been tested by myself so no promises.
1. Turn the printer off.
2. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
3. Remove all EIO devices from the printer.
4. Turn the printer on.
5. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device.
6. Replace a DIMM or EIO device if you determine that it causes the error.
7. Remember to reconnect all cables that connect the printer to the network or computer.
8. If the error persists, replace the firmware DIMM.
Hope it helps, as I said, not tested personally.
Posted on Jun 19, 2008
adonscott
  • 106 Answers
SOURCE: 5610xi won't work (at all) with Vista 64bit
hi,
you can try this workaround.. most of the printing issues can be solve by doing the following steps.:
1. download the Printing diagnostic utility
2. install it, and run it.
3. when its open, click on DIAGNOS, it will give you several errors why you cant print.
4. after doing that step, click on FIX. it will automatically fix the issue.
5. after that, it will give you all green checkmarks. then try to print something.
below is the link where you can download the file "printing diagnostic utility"
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=mp-56143-2&jumpid=reg_R1002_USEN
Posted on Jul 02, 2008
  • 25 Answers
SOURCE: printer stops printing half way down page
Solution Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, contact HP technical support for assistance.
Posted on Jul 08, 2008
I have a sharp AR-M237 printer and when I try to print is telling me Error: PostScript printing not license for this printer
You need to get the correct driver for printing Post Script. You need to buy the program with the licence to print post script. Good Luck
Jan 06, 2013 | Sharp AR-275 Copier
"Error: PostScript printing not licensed
You have to down load the pcl 6 driver for your machine model from http://support.sharp.net.au/drivers/ and install the printer, because now what you installed is ps driver thats why it is not working, rate this and vote for this.
Apr 08, 2011 | Sharp AR-235 Copier
Keeps printer page after page of nonsense try resetting doesn't help
Check your drivers. This is common when printing a PS (post script) job. Try PCL drivers. I have found this to be a big problem when printing a .PDF through PS.
Feb 22, 2010 | IBM Infoprint 1352 Laser Printer
My HP Laserjet 1320 won't print even modest sized PDF files. The Printer Window says "Error-Printing" I've had this problem for years. How can I get my printer to print PDF files? I increased the memory...
If you are using a PS (post script) print driver, delete it and install the PCL driver (PCL5 or PCL6 if available). May help, not positive. I have seen lots of pdf printing problems with PS or incorrect model drivers.
These drivers are free to download at "support.hp.com"
Feb 06, 2010 | HP LaserJet 1320 Printer
Printing from a mac OSX.5.8 to a Sharp copier AR BC320?
You will need to purchase the Post Script Driver for that model. Sharp Copiers require a product key code to enable post script on their copiers. A sharp dealership will have to sell it to you as well as to get the product key code for the postscript driver.
Dec 10, 2009 | Sharp AR-BC320 All-In-One Led Printer
Printing by SHARP AR M161 on Mac 9.2.2.
Go to printer setup and click on new printer. You should get a long list of printers. Hopefully yours is on the list. Click on the printer name and you will be presented with several drivers. Choose the one that is the best for you. Before you exit print a test page. Give the printer a name.
If this does not work you will have to install the windows driver. This is only possible If your Mac can run windows software.
Mar 04, 2009 | Sharp AR-M162 All-In-One Laser Printer
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Error: Printing data is inaccurate, printing processing is stopped Printer error page is printed with this error prints fine from the webpage printer is installed on windows 2000 over a network
I got the same error with another type of sharp photocopier AR-M257
My error, I was installing the wrong driver.
I installed the Sharp driver with the PS at the end.
You can download from here depending the version of the Windows you have
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Good luck!!
Aug 22, 2008 | Sharp AR-M207 All-In-One Laser Printer
Printer constantly paused during printing
Is Post Script Key in the Mahcine? (PS must be intalled on the machine)
Do you have the Correct Driver
www.sharpusa.com
Aug 08, 2008 | Sharp AR-BC260 Color Copier
PCL Xl Error
when installing new driver choose PS ( post script) instead and see it fixes problem
Good luck
Apr 03, 2008 | Kyocera Mita FS 3800 Laser Printer
HP OfficeJet 4255 All-In-One InkJet Printer Logo
26 people viewed this question
Seeker5211
Seeker5211
