Question about Casio FR-2650Plus Calculator
Print is blurry, even with new ink roller
I have replaced the ink roller, and still get blurry print - even changed out the ink rollers twice, and still get blurry print. Is it defective ink rollers, or has print head gone bad?
2 Suggested Answers
SOURCE: How to ink Casio FR 1211 Printing Calculator
I have a Casio FR-1211 Printing Calculator and I have the same problem. I removed the roller and tried inking the roller with "Sanford's Roll-On Stamp Pad Inker". It works beautifully ! I don't know how long it will last, but for now the print is dark and clear.
John
Posted on Aug 23, 2010
Print is blurry and faint. I have replaced ink roller numerous times.
Usually caused by the rubber perishing on the print wheels or the hammer mechanism failing. These printers don't last a long time. They are very cheap for a reason. You could try cleaning the rubber print wheels but normally, the whole printer would be replaced
Apr 18, 2015 | Sharp XE-A106 Cash Register
Replace ink cartridge
INK ROLLER REPLACEMENT
If printing is blurry even when the ink roller is in the proper
position, replace the roller.
Ink roller: Type EA-732R
WARNING
APPLYING INK TO WORN INK ROLLER OR USE OF
UNAPPROVED INK ROLLER MAY CAUSE SERIOUS
DAMAGE TO PRINTER.
1) Turn the power off.
2) Remove the printer cover. (Fig. 1)
3) Remove the ink roller by turning it counterclockwise and
pulling it upward. (Fig. 2)
4) Install the new ink roller and press it in the correct position.
Make sure that the ink roller is securely in place. (Fig. 3)
5) Put back the printer cover.
Jun 08, 2012 | Sharp EL-1611P Calculator
Hp 5550dn prints text fine but pictures are blurry?
Don't replace but verify the condition of fuser assembly, if you found any cracks or folds on teflon roller or pressure roller causes the same thing, just verify get back to us...
Feb 01, 2012 | HP LaserJet 5550DN Printer
How do you change the ribbon
Hi mkline519,
The new ink roller types are EA-781R-BK (Black) and, EA-781R-RD (Red).
To change the ink rollers.
1). Set the power switch to off.
2). Remove the printer cover. The little paper guard or, flap on top.
3). Remove ink rollers by turning each one counterclockwise and, pulling upwards. With the calculator facing you. Red is on the left and, black is on the right.
4). Install the new ink rollers in there correct position's. Simply press them in one at a time and, make sure they are secure.
5).Put the print cover back on.
If calculator prints blurry, the rollers may not be not secure. If you have any questions about this calculator simply post a comment and, I'll respond quickly.
Jan 13, 2011 | Sharp EL-2192Rll Calculator
My machine needs the ink changed? how do I do this
There is no ink in that model, it is a thermal printer. You might have the wrong paper or a bad print head or a bad print roller. To test this. Get some thermal paper (You will know it is thermal if you expose it to a heat source and it turns black) and some electrical tape. But a small strip of electrical tape on the print roller. Then do a test sheet. if it prints out darker where you have the electrical tape on the roller it means you need a new roller or possibly a new paper tray cover. You are not getting enough pressure where the two make contact. if you get nothing you need a new print head. We can help with this, 800 989 4909, ask for Jeff
Oct 15, 2009 | Schiller Cardiovit At 1 Ecg Machine
Distorted Printout
Causes for distortion or blurring
Cause
Solution
Transfer unit is defective
Replace the transfer unit. Calibrate the printer after
replacing the transfer unit.
Secondary-transfer roller is defective
If it does not rotate smoothly or is deformed, replace the
secondary-transfer roller.
DC controller PCB is defective
Replace the DC controller PCB. Calibrate the printer
after replacing the DC controller
Sep 11, 2009 | HP LaserJet 3055 All-In-One Printer
Printing
Your print head may be dirty. Remove the ink carts and examine the print heads.
You should also examine the printer for a printer head parking location or cleaning pad (usually off to one side, where the cart sits when not in use or there is a pad on the side to use in cleaning the print head.)
If the print head is dirty, clean it with a soft cloth.
If the landing pad or cleaning pad is dirty from a leak, you may need to remove it or replace it.
Does printing sound normal? It is also possible that worn rollers may cause the page to advance incorrectly.
May 06, 2009 | Lexmark X7350 All-In-One Printer
Changing Ink in the Canon P170-DH Printing Desk Top Calculator?
The manual for the Canon P170-DH calculator is found on the canon usa web site. It is 22 mg in size, but prints out to 4 pages in English, Spanish and French.
According to the manual: Use only Ink Roller CP-13.
There are four figures showing the steps, so you'll have to imagine it.
1. Turn power switch off.
2. Remove the printer cover (Figure1).
3. Hold the tab of the ink roller. Lift the ink roller out of the base (Figure2).
4. Insert the new ink roller into position. Push down on the center of the ink roller until it locks into place (Figure3).
5. Replace the printer cover (Figure4).
Print out the manual for yourself and put it in a safe place.
Nov 20, 2008 | Canon P170-DH Calculator
Ink rollers
Unless the ink roller that you installed was dried out, usually, the replacement rollers just snap in place and are good to go. Check to make sure there is ink on the roller by either pulling the ink roller out again, and touching it with your finger. If no ink on your finger, you might have received a dried out replacement roller. Also the roller should be somewhat like a sponge. If you push against the sponge and it doesnt spring back and it stays indented, then the roller might also be bad. If you happen to have a bottle of ink for an ink pad, you can try soaking the roller with the ink so the roller is wet, (but not DRIPPING WET) and try it again in the calculator. IF you get some image for a little while, then I would say try a new fresh ink roller.
Hope this helps.
Feb 04, 2008 | Sharp EL-2192Rll Calculator
Canon p170-dh
if you calculkator does not print at all try to move a switch to p or print, and you have a ink roller on the printer
Dec 08, 2007 | Canon P170-DH Calculator
Casio FR-2650Plus Calculator Logo
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
