Question about Konica Minolta Bizhub 552 Copier / Printer / Scanner
Konica milonta c451 ibt belt reset - Konica Minolta Bizhub 552 Copier / Printer / Scanner
4 Suggested Answers
jqsababa967
  • 145 Answers
SOURCE: Konica Minolta c451: Tray 1 is not available
look behind the tray for paper....
if not do the folowning
power machine off from main switch sould be on the side or open the front door it;s on bottom left side.hold down the utility botton while powering on keep holdin untel prompted with message ...TROUBLE RESET press it should say ok than powr machine off wait 20sec power back on
hope that help
keep us posted
Posted on Mar 18, 2009
waqar697
  • 67 Answers
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Posted on Mar 30, 2009
  • 7 Answers
SOURCE: how do you reset the konica minolta bizhub c451
Network settings are accessed through the Administrator menu. Press Utility/Counter, then choice #3 should be Administator Settings. Enter your admin password and Network Settings should be choice #5.
Also, if the bizhub is already on the network, you can enter the IP address into your web browser and log in as an administrator to get to the network settings.
Posted on Dec 13, 2009
My Konica bizhub c451 is showing p6p7p9p8 and it keeps sterbilizing without showing ready to copy pleas what do I do
Check the Transfer Belt assy,
Remove and Clean properly
Remove all Imaging Unit and shake properly and put it again.
P6/7/8/9 indicating all Imaging units are not in good condition.
So at warmup, color patch not getting properly generated
Dec 22, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
C4501 in c451
Laser malfunction; try to reset the equipment as follow:
Shut down from the main power switch wait for a few seconds and then start it up while keeping the 'Utility/Counter' button pressed; keep it pressed until the reset button appears on the touch screen, release the 'Utility/Counter' button, touch the reset button and an OK message should appear below. Restart it normally and it should work.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 19, 2014 | Konica Minolta Office Equipment & Supplies
Erreur P21 konica C650
requires remove of the transfer belt and cleaning of the registration sensors located under the belt on the right side of the machine, with belt out requires knowing what lever to push to expose the sensor to clean them or the have them replaced.
Jun 08, 2014 | Konica Minolta Bizhub C451/c550/c650 Toner...
How to know Transfer Belt fuse is gone
The fuse blows as soon as its put in the machine. Thats how the machine knows to reset its count
Dec 20, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
Docucolor 242 code 042-326. What do we need to
arrwup.gifBSD On BSD 9.20 - Transfer Belt Position Monitoring arrwup.gifDescription Belt Home Position too long
arrwup.gifInitial Action NOTE:
If this fault is declared 3 times in succession, the print mode will be disabled. In order to clear this condition, reset NVM location 741-105 to 0.
  • Check the opening/closing of the Front Cover.
  • Turn the power OFF then ON.
arrwup.gifProcedure Check that the Transfer Belt is in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Center if required (see REP 9.3).
Perform ADJ 9.13 Belt Edge Learn Cycle.
The Belt Edge Learn Cycle ends abnormally. Yes No Unanswered
End
Check the reflective mark at the rear of the Transfer belt.
The reflective mark positioned correctly and reflects properly. Yes No Unanswered
Clean the reflective mark and reposition it properly, if the problem continues, replace the IBT belt ( PL 7.3).
Enter dC330 [042-200 Transfer Belt Home Sensor]. Rotate the belt manually for 1 turn.
The display changes. Yes No Unanswered
Go to OF 99-1 and troubleshoot the Transfer Belt Home Sensor ( PL 7.5).
Check the operation of the actuator of the Transfer Belt Edge Sensor Assembly.
The actuator moves smoothly. Yes No Unanswered
Replace the Transfer Belt Edge Sensor Assembly ( PL 7.4).
Select [042-016 IBT Steering Motor (CW) High Current] and [042-017 Steering Motor (CCW) High Current].
The IBT Steering Motor operate. Yes No Unanswered
Go to OF 99-9 and troubleshoot the IBT Steering Motor ( PL 7.4).
Check the installation position of the IBT Belt Module (the four legs of the IBT Belt Module are placed on the board springs of the Transfer Drawer and the fixing screws (M4: x2) of the IBT Drawer are tightened).
The IBT Belt Module is installed in the proper position. Yes No Unanswered
Adjust the installation position of the IBT Belt Module.
Set dC131 [741-105 Angle Data Initial Value (A0)] to 0.Install the IBT Belt in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Perform ADJ 9.13 Belt Edge Learn cycle.
End
Replace the Transfer Belt Home Sensor ( PL 7.5). If the problem continues, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem persists, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem is persistent, replace the IBT Belt Module ( PL 7.1).
Sep 08, 2009 | Xerox Office Equipment & Supplies
Need written instructions on how to reset IP code Konica bizhub C451
there are two ways you can rea\set the ip address you can press utility counter administrator password is 12345678 the go to network ip address and you can chane it there if you know the ip address you can browse to the machine and log in as administrator and go to network and reset there
May 05, 2009 | Office Equipment & Supplies
Konica Minolta Bizhub 552 Copier / Printer / Scanner Logo
29 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
