Question about Nortel Lands Phones
Unplugged phone and plugged back in. Phone does now does not work
Light to kitchen was staying lit up. The office could not connect into my room or anywhere else in building. I tried pushing several buttons to get connection back. Nothing worked. this morning i unplugged phone from wall & then plugged back in. Now phone is dead.
  • 119 Answers
Have you tried another phone?
Posted on Apr 10, 2014
SOURCE: caller-id quit working
This is a followup to my earlier suggestion. My caller id is working. So, the culprit had to be related to the 9V battery. Just try my earlier solution from 1/20/07. If it works..fine. If not, bye-bye to the phone.
Posted on Feb 10, 2007
SOURCE: Phone line/phone jack problem
The wiring on the jacks is set up for a 2 line phone.
If you take the jacks apart, you will see either:
A) red, green, and black, yellow
B)white blue/blue white and white orange/orange white
You need to swap the pairs.
If there are red/green/black/yellow wires. remove the yellow/black and move them to where the red/greens are. Then put the red/green wires, where the yellow/black used to be.
OR, you need to swap the orange and the blue wires.
Posted on Dec 22, 2007
SOURCE: Can't reset Panasonic KX-TG6700 phone
I have the same problem,,,
Posted on Feb 17, 2008
  • 47 Answers
SOURCE: My Phone will not connect to the base unit...
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
Posted on Jan 06, 2009
SOURCE: Panasonic KX-TGA601CB cordless phone Was working
phone says move closer to base
Posted on Jan 28, 2010
The power went out, and when it came back on, my Whirlpool Oven Model RF341BXKW just beeped incessantly. When I tried to turn the oven on, the red light blinked, when normally it stays lit when any heat is...
Hello Rudymilo! We are terribly sorry to hear of your concern with your Whirlpool Range. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Rudymilo), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool RF341BXKW Electric Kitchen Range
Our office has a NEC multiline phone, and line 9 is lit up green, but when accessing it, there is a busy tone, how can I clear that line?
Easiest way is to unplug the system, wait 20 seconds, and plug it back in. If it's still lit, maybe there's no dial tone on the line.
Carl
Jul 06, 2009 | NEC DSX Super Display Phone BLACK
Line 2 stays lit with red light
I think that just means that you do not have a 2-line connection to the phone. Either your cord is a 1-line cord or your 2-line cord is plugged into the wrong jack on the back of the phone,
Apr 14, 2009 | RCA 25202RE3 Corded Phone
My headset was working fine (Plantronics CS50). Now I can use it to talk on my phone to office extensions but when I punch an outside line, their is a loud, very loud noice that prevents one from hearing...
The CS50 is not a phone and it is not specific to VoIP.  It does not transmit over the ehternet wiring in your office space.
Here is how to really "reboot" or as the manufacturer refers to it "perform a system reset" on your headset:
1. Lift the headset off of the charging base.  Make sure the headset is turned off.  The green light should not be lit on the charging base. 2. The mute button is on the black little wheel on the top of the headset.  If you push it straight down with the tip of your finger it will mute it.  Now, at the same time, push and hold the mute button with the call answer button.  You will see a green light on the headset flash quickly.  After 2 series of flashes, let go of both the call answer and the mute button. 3. Place the headset back on the charging cradle.  Leave it there for 30 seconds.  Lift it up and try it now.
Also make sure that the red light on the base is lit up.  This means there is power to the system.  If it's not, check the connection.
Jan 28, 2009 | Plantronics CS60 Professional Headset
Phone works in one jack but not another
Hi, Looks like either the wiring is slightly different or the jack plug not quite with in the tolerance limit. Can you swap the cables between the units (if they are removeable) to eliminate the cable as well. I would suspect the cable on the new phone! I would also make sure there is no dirt on the connectors on the plug...there are minute grooves where you can see the meatl...sometinmes these get blocked!
Jan 08, 2009 | GE 28111 Cordless Phone
Office Moves/Swaps
pretty new to this myself but ive moved a few numbers around from the server room.
ours is set up with the proper ext numbers on the extensions around the office and in the server room i have those numbers on a hub with another hub with ext numbers for the phones.
you will have to unplug the correct ext cable and plug it back into the new ext number for the office its going to
sorry if this is no good or not what your looking for, pretty new to this and if it does help then excellent
May 02, 2008 | NorStar M7310 Corded Phone
Phone cords
With the lines lit on the phone, it's indicating an off-hook condition or no battery from the line. Check the lines for dial tone at the demarc to determine if it's phone company problem. Thank you. Jer
Feb 18, 2008 | Panasonic KX-T7730 Corded Phone
Telephone dont work
That light is indicating that you have a phone off the hook, a short in one of your phone lines, or a bad modem. Unplug the phone line from the back of the modem. If it stays solid, plug it back in and go and disconnect every phone in your house. If it stays solid you have a phone issue. Plug them back in one-by-one and see which one causes it to start blinking. If it doesn't go away after unplugging all your phones, you have a phone line issue. If it is still blinking after unplugging the phone line from your modem, your modem is bad.
Dec 30, 2007 | Arris Touchstone 450a (CM450) Modem
Plugging it in
Your Nortel M7208 phone is plugged into your Norstar phone system (not the phone line) You would not be able to use DSL on the same phone port used by the M7208 phone. A filter connected to that port would not solve a DSL issue and could only cause problems with the M7208 phone. You may need to put the filter on the phone lines before they connect to the Nortel phone system... I don't know which system you have or how it is wired up so I am not sure how easy that would be for you.
Nov 10, 2007 | NorStar M7208 Corded Phone
Lands Phones Logo
75 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
