Question about Epson Office Equipment & Supplies
Epson WP-4530 leaking blue ink
Whenever I print, even in black and white, I end-up with dots and streaks of blue ink all over the page. Unfortunately, with the Epson WP-4530, you can't remove a color cartridge and still print in black and white. I've cleaned and aligned the print heads many times, but that does not help. When it first started, there were huge lines of very wet, blue ink on the pages, so it seems to be getting somewhat better. Although I can't use any document I print from this printer for work. Anyone have a way to fix this? Thanks!
  • 76 Answers
SOURCE: cartridge alignment
So if the magenta or yellow are not showing up, it may mean you have installed an empty (or dried up) color cartridge. If you have it, put the "low" volume color cartrige back in and print an alignment page. If you don't have the cartridge, no problem, just print a page from Google. Don't worry about the alignment until you print from Google. See if color is even available. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 21, 2007
  • 3 Answers
SOURCE: Streaks / Bands of broken print area
No cleaning was successful, finally replaced the printhead and solved the problem.
Posted on Mar 06, 2008
Ajkill
  • 2035 Answers
SOURCE: white horizontal streaks in documents
I Am Experiencing Poor Print Quality With My Dell™ Printer
Table of Contents
Verify the Printer Ink Levels Using the Dell Printer Solution Center
Clean the printer contacts and print a test page
Clean the Printer Nozzles Using the Dell Printer Solution Center
Dell™ Printer Additional Information
» Verify the Printer Ink Levels Using the Dell Printer Solution Center
Poor print quality of a document or picture may be the result of low ink levels or dirty printer nozzles or contacts.
To check the printer's ink levels, perform the following steps:
1.
Click the Start button, point to All Programs, point to Dell Printers, and then point to Dell (printer model).
2.
Click Dell Printer Solution Center.
3.
Locate the printer's ink levels on the lower right corner of the Dell Printer Solution Center window.
4.
If the printer's ink levels indicate that ink cartridges are empty, click the Order Ink button to place an online order for replacement ink cartridges.
For information about ordering ink for your Dell printer, refer to article: Obtaining Ink for a Dell™ Printer
Back to Top
» Clean the printer contacts and print a test page
To manually clean the printer nozzles and contacts, perform the following steps:
1.
Turn the printer off and remove the power cord from the back of the printer.
2.
Open the printer lid.
3.
Manually move the ink-cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right hand side of the printer.
4.
Take a warm, semi-damp paper towel and gently clean the wiper on the right side of the maintenance station.
5.
Lift up on the cap(s) that cover the ink cartridge(s).
6.
Remove the ink cartridge(s), and using a new warm, semi-damp paper towel, gently clean the contacts on the ink cartridge(s).
Verify that the contacts on the ink cartridge(s) is/are sufficiently dry prior to re-inserting into the printer.
7.
Re-insert the ink cartridge(s) back into the correct printer slot(s).
7.
Close the printer lid.
8.
Re-attach the printer power cord to the back of the printer unit.
9.
Press the Power button to turn the unit back on.
10.
11.
12.
Click the Maintenance tab.
13.
Click the Print a test page icon.
A test page prints.
Back to Top
» Clean the Printer Nozzles Using the Dell Printer Solution Center
To clean the printer nozzles and contacts using the Dell Printer Solution Center:
1.
2.
3.
4.
Click the Clean to fix horizontal streaks icon.
5.
Click the Print button.
Note:
The printer will make sounds when cleaning the nozzles that are not commonly heard during normal usage
Posted on Mar 21, 2008
Joed911
  • 4338 Answers
SOURCE: HP 2840 ready yet prints only a white page
Did you resolve this issue?
If not check that the Scanner bulb is lighting. If not check the cable from the scanner to the formatter and seated correctly. The scanner or the formatter board may be bad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 07, 2008
SOURCE: Canon Pixma ip3000 printer, changed black ink
i had the same problem and just repeated the cleaning and testing, eventually the black showed up but took more than a few repetitions
Posted on Jun 30, 2009
Prints 1" wide blue streak from top to bottom of page
If you're holding the paper so the narrow side is up, and the blue streak is vertical, then it's not a bad print head. If the stripe is from side to side with the paper held that way, then possible that the head is bad. The 4530 is an office type printer with large carts that connect to the print heads with hoses. It's possible that a hose has come off and is dumping ink that way, or that the hose is leaking...
Apr 17, 2015 | Epson Pro Wp-4530 All-in-1 Inkjet Wireless...
Black 3e Cartridge
check the printer head and roller inside the printer
also check the nozzle because it may be clogged due to some
dust
Jul 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
How do i get my printer to print last page first
Any special reason? They will always print in the right order, so you can read in correct order. You organice your printing on Page set-up.
Jul 24, 2014 | Epson Workforce Pro Wp-4530 All-in-one...
Epson pro wp4540 printer is spraying a band of yellow ink down the page
remove cartidge- using a flashlight look at its "seat " in printer- sounds like you have a dust bunny- clean with q-tip
Dec 22, 2013 | Epson Workforce Pro Wp-4540 All-in-one...
Black ink blobs, streaks, and dots
R350 type my printer,not respont end error in display
Nov 28, 2012 | Epson Stylus 1400 InkJet Photo Printer
When we attempt to print it leaves black streak marks. At first it printed all black and when we went to setup under maintainence we chose alignment and clean cartridges. This worked however we still see...
If an inkjet printer gives white streaks where it should be black, it means the ink is very low, or there is dirt under the nozzles preventing it from printing properly, or, in the case of non original cartridges, ink might be leaking which prevents the bubbles of ink to squirt onto the page.
If the streaks are black where it should be white, is sounds like some dust or fluff below the cartridge leaves ink smears on the page.
Aug 23, 2011 | Lexmark X4650 InkJet Printer
Epson CX3810 started leaving blank streaks, now no ink on page
I went to Epson.com's technology on google - and as I followed their prompts, I learned that it was the printer heads and that you aren't supposed to tilt the machine. I have been moving it a lot, so undoubtedly tilted it. You can follow the prompts after a right click on the printer icon on the bottom left corner of the monitor and it cleans the printer head. This also solves a white streak problem if people are having white streaks where there's no pringint....They had lost of answers there too.
Dec 13, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Leaking black ink on printed pages
Hi, please attempt to run a numerous blank paper through the printer. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains or streaks are still present, the printer may need service.
Tirzo
Jun 12, 2008 | Epson Stylus CX7800 All-In-One InkJet...
102 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
