Question about Konica Minolta Office Equipment & Supplies
Frozen touch screen
I've got a konica based copiers (a olivetti Dcolor MFP 362 plus), with a lot of users printing / scanning / copying on it. The scren is frozen 3 or 4 times per day. In this case we have to reboot. An idee ?
  • Konica Minolta Master
  • 6,696 Answers
Yes have tech come out and re flash the firmware not the drivers but the copier firmware which is normal on a secure web site access to dealerships only.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 14, 2016
  • 214 Answers
SOURCE: Dead touch screen
did you try to turn the brightness button.
Posted on Jun 19, 2008
Kevin Hayes
  • 167 Answers
SOURCE: multiple copy error
Turn OFF sorting and/or grouping in the finishing tab.
Posted on Dec 05, 2008
  • 15 Answers
SOURCE: Konica Minolta Bizhub 350
You are getting a failure sheet. This happens when the scan doesnt go through. I think you are reffering to SMB scanning, which needs to have the following setup on both the MFP and the copier.
Host ID or NAME - IP address or hostname with DNS resolution.
Share Name - This is your SMB share name or folder share name on the remote PC
User Name - This is an account that is configured on the remote PC
Password - This is the password for the account setup on the remote PC.
Some things to keep in mind: Third party firewalls can block the bizhub from writing files.
Set share permissions to full control. (under sharing tab> permissions buttion)
Set NTFS permissions to at least write access. (if you have a "security" tab on the shared folder.
Or, you may see something like "allow network users to change my files" on the sharing tab. This basically does the same under different configuration scenario.
One last thing. If you havent changed anything since the problem started, it is probably just something like an expired password on the account that is setup for the copier.
Good Luck.
Posted on Jun 09, 2009
SOURCE: touch screen on hp laserjet m 3027 mfp not working
turn of the printer. Hold the C and # buttons and turn on the printer. When the screen goes black it will be ready to be re calibrated. there is a white dot, touch it with a pen, another white dot appears, touch it with a pen. It will continue to turn on now with a newly calibrated screen.
Posted on Nov 25, 2009
  • 61 Answers
SOURCE: Konica Minolta bizhub 6500 pro/Fiery controller scanning problem
Hello a Fiery print controller is basically a computer, which needs to be rebooted once a week to get rid of temp. files. Try shutting down each fiery every Friday and restarting Monday morning and your problems will be resolved. What model Fiery's do you have (IC-408, IC-901),? let me know which model and I can see if their is a patch to correct this issue. dave.herron@att.net PS: I am full line KonicaMinolta dealer
Posted on Dec 25, 2009
Why can't I scan from the bizhub362
be a little more specific, have you set the copier up to scan to smb or email?
Sep 17, 2014 | Konica Minolta Bizhub 362 Copier
Toshiba estudio 456se printer
Toshiba Copiers STUDIO456
http://business.toshiba.com/media/downloads/products/506seriesm_Web_high.mov
Key Features
  • Up to 45 PPM
  • Black & White MFP
  • Sml/Med Workgroup
  • Copy, Print, Scan, Fax
  • Secure MFP
  • Eco-Friendly
  • MSRP $12,989 (Base Unit)
May 05, 2014 | Toshiba e-Studio 35 Copier
I an getting light copies on konica minolta bizhub 362 what is the adjustment to make copis dark
Normally light copy comes out when mirrors are dirty. Before any adjustment clean the slit glass and mirrors.
Dec 17, 2012 | Konica Minolta Bizhub 362 Copier
How to change scan to email default email?
Download the free user manuals directly from Konica Minolta support and you will find details on all the settings you can adjust for your copier.
There are 26 manuals for your machine. I would just download the network scanner user guide and the Copy/Fax/Scan/Box Operations Quick Guide and look for the procedure there.
http://kmbs.konicaminolta.us/wps/portal/web/home/support/manuals
Jul 31, 2012 | Konica Minolta Bizhub C451 Copier Print...
Scanned documents on our bizhub 362 no longer save to folder on our server. We are not sure why, as we did not change any settings on the server or the bizhub. Help???
Check the ip address of your server in copier.if its change then enter the correct one.If user name and password of your server has been changed then re enter the new in copier machine.(in one touch settings)Check the folder name it should be the same as entered in copier machine.Make sure your server and copier machine are connected with each other.Check the cable or check it by using ping command.
Aug 04, 2010 | Konica Minolta Bizhub 362 Copier
How can I cut off the annoying beeping sound on the bizhub 362?
Press utility/counter button.on panelPress user settings.on touch screenNow check all the tabs.in one tab you will see the volume option for beep sound.decrease the volume and press ok and then press reset button.its done.
Jul 27, 2010 | Konica Minolta Bizhub 362 Copier
How do I access the menu/control panel?
MFP and scanner settings can be changed several ways: through the MFP control panel, the software application in use,
the print driver, MarkVision™ Professional, or the Web pages. Settings changed from the application or print driver apply
only to the job being sent to the MFP.
Changes made to print, fax, copy, and e-mail settings from an application override changes made from the control panel.
If a setting cannot be changed from the application, use the MFP control panel, MarkVision Professional, or the Web pages.
Changing a setting from the MFP control panel, MarkVision Professional, or the Web pages makes that setting the user
default.
Menus (A key is shown on the button.) Touch to access the menus. These menus are only
available when the MFP is in the Ready state.
The Menus button is on a gray bar called the navigation
bar. The bar contains other buttons described as follows.
Understanding the copy screens and options
Copy From:
Opens a screen where you can enter the size of the documents you are going to copy.
Touching any of the paper size icons on the follow-on screen will make that your selection and return you to the
Copy Options Screen.
When Original Size is set to Mixed Sizes, you can scan different size original documents (letter and legal size
pages). They will be scaled automatically to fit the selected output media size.
Copy To: Opens a screen where you can enter the size and type of paper on which your copies will be printed.
If the size settings for Copy From and Copy To are different, the MFP will automatically adjust the Scale setting to
accommodate the difference.
If you have a special type or size of paper that you'd like to copy onto that is not normally in the MFP paper trays,
you can select MP Feeder, and manually send the type of paper you want through the MP feeder.
When using Auto Match, the MFP will match the size of the original document as specified in the Copy From box.
If a matching paper size is not loaded in one of the paper trays, the MFP will scale the copy to fit loaded media.
Scale: Creates an image from your copy that is proportionally scaled anywhere between 25% and 400%. Scale can also be
set for you automatically.
When you want to copy from one size of paper to another, such as legal size to letter size, setting your Copy From
and Copy To paper sizes will automatically change the scale to keep all the original document information on your
copy.
Touching the arrow to the left lowers the value by 1%; touching the arrow to the right increases the value by 1%.
Holding your finger on an arrow makes a continuous increment.
Holding your finger on an arrow for two seconds causes the pace of the change to accelerate.
************************Darkness: Adjusts how light or dark your copies will turn out in relation to the original document.****************** here is the link to the full pdf manual for your unit: http://www.lexmark.com/publications/pdfs/2007/x644e/en/ug.pdf#xml=http://support.lexmark.com/lexmark/index?page=answeropen&segment=SUPPORT&userlocale=EN_US&locale=en&type=open&searchid=1270220491739&answerid=16777216&iqaction=6&url=http%3A%2F%2Fwww.lexmark.com%2Fpublications%2Fpdfs%2F2007%2Fx644e%2Fen%2Fug.pdf&productCode=&highlightinfo=106955230,537,548
Apr 02, 2010 | Lexmark X 646e MFP - multifunction ( B/W )...
How do I default my copier to print black and white rather than colour
select the settings you want to default on the copy screen then:
1.press the utility/counter key
2.touch the user setting key
3.touch the initial setting key
4.touch current setting
touch ok and close twice to exit
Nov 19, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta C250 Scanner problem
To print the transmission report:
1. Press the [Fax/Scan] key to display the Fax mode screen.
2. Touch [FAX Menu].
3. Touch [TX Report] on the Set 1 tab.
4. Select how to output the report, and then touch [Enter].
– Default: The transmission report is printed according to the previously specified method.
– ON: The transmission report is printed with each transmission.
– If TX Fails: The transmission report is printed only if the fax could not be sent.
– OFF: The transmission report is not printed, regardless of the transmission result.
Feb 05, 2008 | Konica Minolta bizhub C250 All-In-One...
64 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
