Question about GE Zoneline Deluxe Series Cooling & Electric Heat Unit AZ25E07D3B
Az28e09dabm1 ptac wont shut off all other functions work normal replaced control board already
Plug unit in it turns on with control board switch in off position
2 Suggested Answers
bobotfel
  • 236 Answers
SOURCE: PTAC UNIT QUIT WORKING
If you have a clamp tester, operate the unit with the clamp tester and check the current reading. If the current reading is normal but the reset button is tipped then there is something wrong withe power plug reset button. But if the current reading is higher than the name plate rating then there is something wrong with the unit.
Posted on Mar 09, 2008
The fan on my ptac unit want shut off even with the main power switch off
The contactor on the unit needs replacement, or the control board needs to be replaced.
Jan 21, 2017 | Heating & Cooling
I have a Friedrich PD model PTAC unit controlled by a chassis mounted Smart Center. The power on/off key will not work so I cannot get the unit to power on. Can this be repaired or will the board hav
check the reset button on the plug if it has one. If not you will need to replace the control board. Check on the board I can't remember this unit but some have a fuse on the board.
Sep 05, 2014 | Friedrich Heating & Cooling
Amana ptac error code C7
It's most likely your thermostat the one up front that plugs in under your control panel. Had one do the same thing replaced it now works perfect.
Mar 25, 2013 | Heating & Cooling
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
Ptac does not function. Board flashes "Br",
Dear Friend! Er means Powerwas lost or voltage is low.
Do you believe if volt meter shows correct volts, it's perfect? No, even loose contact of neutral,burnt wire, it shows correct volts in that point.
Simple way to check the power is alright or not, just remove the a/c plug and connect any other device like electric racer, table fan, blower or iron box which work same volts as a/c. If other devices work, your power is o.k Or check for loose contact in your electrical wiring. Thanks.
Jan 11, 2011 | Amana PTH153B50AM Air Conditioner
Will not switch to cool mode. heat and fan work fine
hi,
regarding on switch mode theres a common line between heating and cooling although fan is always connect on them.,also with the thermostat,the sequence on this when you switch to cooling and your connection is on heater,the contactor will shift to compressor source,so if there is no cooling, the contactor supplying the compressor is not functioning when you switch on cool mode.try to tighten screw on compressor relay maybe only loose.on control panel,or check continuity of compressor if the compressor still good,check also the freon charge using clamp ammeter,this should be done by ac technician.have a nice day
rate me up,thank's
Apr 26, 2009 | Heating & Cooling
LG PTAC acting strange in heat mode
I believe the problem in lies in the dual stage heat mode setup on the thermostat, but the unit going into defrost does make the unit act kinda strange. Even more so than other types of equipment. I would suggest hiring a licensed HVAC service technician if the problem cannot be resolved by yourself.
Dec 15, 2008 | LG LP120HED Wall/Window Air Conditioner
TRANE PTAC
You need to replace your control board, but if you are can repair it by your self you can change the relay that supply the fan and condenser.
Nov 15, 2007 | Heating & Cooling
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
Top GE Heating & Cooling Experts
ray gallant
Mack Baxter
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
