Question about Coby DVD-536
I have a coby dvd player hooked up to my new Vizio television. I don't know why, but when I play movies on the dvd player, they only play in black and white. I don't even pretend to know anything whatsoever about anything. I need a simple answer. I don't know what a multisystem is and/or PAL-PAL or NTSC. The vizio is a SV420M. If I get a new dvd player, will it play in color?
  • Coby Expert
  • 133 Answers
Press N/P button on remote, if that dont work, go into the Setup Menu and do a DEFAULT. If either of those dont work, check to make sure your video cable is in the correct location.
If your in U.S., should always be on NTSC
If outside of U.S., you would select PAL
Posted on Jun 04, 2010
Vizio tv - plays fine and in color. hooked up phillips dvd player - all connectors connected correctly. when i play the dvd, it is only in black and white . . . not color. how can i get my dvd to play...
Which input on the TV and which output on the DVD player are you using? HDMI is the best and easiest. Next is standard video plus audio (3 leads, yellow - video, red and white - audio). If you are using the component input, you can get B&W if you have the leads incorrectly connected. If you're going from component to video in, you might have the same result, I'm not certain. I hope this helps you resolve your problem. Let us know.
Mar 23, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
My dvd player is hooked up to t.v. but only plays movies in black/white
How is the DVD player connected to the TV? If you are using component video, check that the cables are connected correctly.
If you switch the order on two of the cables, the black and white result is common. So double-check that the red, blue and green connections (RPbPy) have been connected to both devices in the same order. Next try a different set of component video cables, in case one of the wires is damaged.
If possible, try a different type of connection to rule out a damaged input/output. Connect the TV to a different DVD player or the DVD player to another TV, if possible, to rule out similar damage.
Please add a comment with the connection type for additional support. I hope this helps.
Oct 07, 2012 | Vizio L37 Television
Vizio E370lv television saysno signal but plays dvds
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 25, 2012 | Vizio GV42L 42 in. LCD Television
2 symptoms; don't know if they're related or not. For some time now, when trying to watch a movie on my small screen Coby Portable DVD player, it will play just fine for about half the movie, then...
I'm sorry that the DVD player is not playing discs are expected. Based on the information you have provided, it appears that the Lens head of the DVD player is dirty. I suggest that you use a lens cleaning disc to clean the lens head and it should resolve the issue.
Thanks for understanding.
Please let me know if the issue persists.
Nov 14, 2011 | Coby Televison & Video
A new "Tangled" movie disc not play in Blu-Ray
As newer bluray movies come out they are constantly tweeking the format. More then likely you need to update your bluray players firmware or software. There should be an option under the menu for the bluray player to update the unit of course this will require that you have it hooked into the internet via ethernet cable or wifi network.
Apr 11, 2011 | Vizio VBR231 Blu-Ray Player
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
Coby dvd player 536 only plays movies in black and white
it has something to do with your TV's video system and your player's video system...they should match...that is,PAL-PAL,NTSC-NTSC and etc..or if your tv has a multisystem then just set it to AUTO..
Jun 15, 2009 | Coby DVD-536
Cant get color picture when playing DVD's
I too had the same problem. On the Vzio there are AV plug ins on the left side (not the back, but the left side). Use these jacks when connecting to the DVD player and choose the AV button on the TV remote. Viola!
May 27, 2009 | Sony Televison & Video
Dvd stopped playing in the middle of a movie...
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, if the player will no longer read any commercial dvd that you attempt to play, the unit is defective and needs to be replaced. Hopefully, since it's brand new, you still have the receipt and can return it to the retailer for an exchange or refund. The unit has a 90 day warranty from the date of purchase. You would need the receipt in order to receive a warranty exchange.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Dec 28, 2008 | Coby DVD-224 DVD Player
All dvds skips evan brand new ones
Return the unit to the store which you purchased it from. You have an internal problem with the scanner (led) You can first try to clean the led this could be your problem. They sell lens cleaning dvd disks. try it, you have nothing to loose. If this does not work, just bring it back.
Dec 27, 2007 | Coby 5.1 Channel DVD Player with Home...
Coby DVD-536 Logo
247 people viewed this question
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
