Question about Dell OptiPlex GX620 PC Desktop
Win 7 will not boot
Message checkpoint [wake]
5 Suggested Answers
  • 104 Answers
SOURCE: motherboard
Here is what you need to do. Disconect the module with the usb ports from the motherboard. It took a while for me to figure it out but a damaged usb port will make the computer go nuts.
Posted on Sep 14, 2008
  • 1481 Answers
SOURCE: Can not boot the system
if u realy want to make ur PC facotry fit....
visit my site
www.sureshayyar.110mb.com
Format Disk page
all detailas and necessary tools are available for download
Posted on Feb 05, 2010
  • 10406 Answers
SOURCE: shows no boot device run dianostics on harddrive _pass
If your computer cannot read from your disk-drive, then it will try to read from a disk inserted into the CD-drive.
So, it's likely that the disk-drive on your computer has died.
Take the computer to a qualified technician, to replace the disk-drive.
Posted on Mar 02, 2010
  • 222 Answers
SOURCE: "Previous attempts at booting this system have
you can see a logo screen at start computer?
if not the graphic chip are bad if you hear the fans to fast. you can try heat it using a heat gun .
you need to cover all using a aluminium sheet and discover the graphic chip. and heat it for 30 seconds. heat it making circular movement.
you can replace the mother board your self , and bought a used board and u will save a lot of money.
ebay have used and warranted parts for computers.
contact me if need more details , or if u have more info about your problem to figure it.
Posted on Dec 18, 2010
First boot of Win 7. New PC build
Hi.
First of all when you are in the BIOS and have set the DVD/CD drive as the first boot device make sure you save the settings before you restart the computer as it will not remember the changes if you don't.
Make sure that the lens on the CD/DVD drive is clean and also make sure the Windows 7 install disk is clean and free of any finger prints.
make sure that you keep tapping a key when the drive spins up as sometimes people miss the "Press any key to boot from CD/DVD" message.
If you still can't get the disk to boot then try the install disk in a working PC and see if that reads the disk. If it does then the optical drive could be faulty or does not support DVD format.
Regards.
Feb 04, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Having Boot Errors (0xc00000e9) + (0x000000f)
If this is windows 7 64 bit, try and update the bios from the manufacture web site.
Sep 05, 2012 | E-Machines Computers & Internet
The harddrive on my dell inspiron 1464 was formatted. Now the computer will not boot. (the message display's bot manager missing)\ How do I fix this. any help would be great, thank you
hello, try these steps to fix the problem.
  • Insert your Windows 7 DVD into your optical drive(DVD drive) and restart the system.
  • Boot using this DVD by pressing any key when windows asks "Press any key to continue..".
  • Select your language in the first screen and click "Next".
  • In this Window, select the option named "Repair your computer".
  • This tool will search for the installation directory for a minute.Once it finished, click "Next" once again.
  • Under Recovery Tool, choose the option named "Startup repair". Now,Windows will try to repair your startup problem and gives a message to restart your system.
  • Restart your system to finish the process.
Hope this helps!
Apr 11, 2011 | Dell Inspiron 1464 Notebook
I have a dell E510, trying to do a fresh install of windows 7, but it wont boot from cd, or usb flash drive. boot order was changed to boot from cd first then usb second. after that failed hit f12 and...
Hello
If this is a win 7 upgrade you need to have xp installed first,then you can install win 7.
If not,then in the boot order change to cd dvd then hdd,if you have two hdd make sure your primary is first.
Last,if you have a xp disc boot from that and do a delete partion and format the hdd.Then try win 7
Apr 04, 2011 | Dell Dimension E510 PC Desktop
Have Thinkcentre which boots in Win 7 and 2 Win XP
Try to re-install 2 Operating systems use this order,
1,Install windows XP by booting the XP cd,
2,and then install Win 7 by booting from Win 7 cd.
Then while you restart computer there will be a prompt menu asking to select OS to start. Thanks
Jul 25, 2010 | Lenovo ThinkCentre M57 Desktop - Intel...
I have win 7 and win xp loaded on my lap..How can I delet xp now?
You need to check if there any Boot Information in partition that is used by WinXP. In this situation best way is to reinstall Win7, and format all your partitions as you want in Win7 installations process.
Apr 18, 2010 | Microsoft Windows Vista Ultimate Edition
Shows no boot device run dianostics on harddrive _pass
Mar 02, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Motherboard
Sounds like you tried everything except reseating any other hardware that may or may not be placed in another socket such as PCI, AGP, etc... Like a Modem, Network adapter, Sound/Graphics card, Wireless card, etc... This is probably a wasted post as if you knew to check each stick of memory seperatly then you've probably already reseated all socketed hardware. Though, you could remove all non essential hardware such as I mentioned above and try installing Windows again?
Good luck and keep us posted.
Sep 06, 2008 | Dell Dimension 8400 PC Desktop
Motherboard
One of the greatest factor in intermittent shutdowns is because of heat issues. try to check the fans if they are all spinning. if all fan's are ok then you only need to replace the motherboard. here's a manual that might come in handy http://support.dell.com/support/edocs/systems/dim5100/en/sm/index.htm
Hope this helps.
thanks
Nov 13, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell OptiPlex GX620 PC Desktop Logo
23 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
