Question about RCA CDRW121 2-Disc CD Recorder
Where can I get the tray for the right side? It is broken beyond repair. It was working fine before tray broke.
I have no part number, but could identify it from a diagram very easily. It is the tray the CD sits in.
Hello, I own a Samsung BD-d5300 bluray player which works fine. Only the tray doesn't open anymore. No eject. Any suggestions? Thanks
Disc loading mechanism fault. might be of a broken loading belt or a broken gear wheel. Contact any service technician. To take out the mechanism from the set is a skilled work indeed. If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 28, 2016 | Samsung Bd-d5300 Blu-ray Disc Player black
Can't find replacement turning tray for 2009 Kenmore Microwave
Check with some repair places that fix microwaves, our shop keeps ones if the unit is beyond repair, may find a good used one for very little that way--almost all use the same type of drive on the bottom.
Dec 13, 2012 | Microwave Ovens
Need new glass tray for Kenmore microwave bought in 1977. Model # 99371.
They made Microwaves in 1977? wow. I would try an appliance junkyard, or ebay. We have used a microwave safe plate of the right size and it worked well. Good luck!
Apr 29, 2012 | Kenmore Microwave Ovens
My slide projector is a Kodak 760H. The forward and reverse functions do not work. The 140 slide tray loads fine and the picture loads and projects. But pushing the forward or reverse buttons does...
First of all, if you have the remote that came with the projector, plug it in & try that. I suspect that it will not work, but it is worth a try. If it does work, you are a lucky person!
The problem you are experiencing is very common for a projector of that age. The cycle solenoid "link" is broken - or worse - the solenoid has an "open" circuit.This is a pretty complicated replacement and adjustment of the solenoid position that follows. You can purchase the parts required from www.micro-tools.com They also have instructions on their website. If you feel this repair is beyond what you want to get into, contact an authorized repair dealer for assistance. Good Luck !!
Jul 04, 2011 | Kodak Office Equipment & Supplies
I broke the paper tray on my Ricoh AP 2000; need a replacement
Everything is repairable! Between epoxy, super glue, model glue (works better on the plastics it's designed for) and Duct Tape!?!? Yankee Engineering!!, Come on. :^D
But to answer your question: eBay
Aug 24, 2009 | Ricoh Aficio AP2000 Laser Printer
Sun visors flop down and obsruct the view on my 2007 kia optima
Both of my visors broke -- first the one right after purchasing (had dealership repair) then the other (still under warantee, so dealership repaired). The lady said the 2007 Optimas had a "bad batch" of visors and many needed to be replaced. Fine. Now the driver's side broke again. It just needs to be replaced. I love the Kia, hate the visors. Not a bad payoff for the reasonable price. So far, the only thing that has broken.
Jun 27, 2009 | 2007 Kia Optima
AR 200- paper pulls to the green bar and then stops- will not print or move from there and screen says to clear paper path. no paper moves beyond the same point.
This "green bar" (registration roller) could be a few things
  1. Registration sensor dirty or inoperable
  2. Feed tires dirty
  3. Registration rollers dirty
  4. Fuser gate broken
For item 1 the flag and sensor is located under the copier. if you only have one tray then this can be located and removed easily. if you have 2 trays then this get more difficult. Here are the steps for one tray
  1. Open and remove right side door
  2. Remove toner, developer, and drum unit
  3. Remove paper tray
  4. Turn copier on its right side
  5. (Top is away from table and bottom is towards table) Towards the bottom of the copier there is a guide that needs to be removed (2 screws)
  6. There is a cover where a couple of wires are going to needs to be removed (use caution)
  7. Once removed take can of air and blow out sensor
  8. Replace items as removed
For item 2 follow steps 1-4 and locate tires clean using warm soapy water on a lint free cloth or mechanics towel
For item 3 open and remove right side door and clean grey rollers located under green cylinder which is your drum (USE caution not to touch or damage)
If the first 3 steps do not help then you should call your local Sharp dealer for repairs.
Mar 17, 2009 | Sharp Office Equipment & Supplies
Plastic clip holder to hold dishwasher tray is broken
If you are handy, contact an appliance parts store that sells retail. You should find them in the yellow pages. Brand and model number will be needed usually on the inside edge of the door.
If you are unsure, Look in Repair and Service link at Fixya.com for a repair service in your area.
Good Luck,
Dec 05, 2008 | Home
Lexmark Optra T612
The broken part is called the bell crank arm part number 56P1228 this is very common. If the printer isn't recognising your tray, remove it and check the little plastic fingers on the left side (half way down the tray) and the metal springs in the printer (left side) which the tray pushes on to.
Aug 04, 2008 | Lexmark Optra T612n Laser Printer
Broken Glass tray
That model number isn't showing up. Could you confirm that?
Then I'll see if anything is still available for it.
Otherwise, here are two suggestions:
You place a microwave-safe saucer upside-down on the roller assembly (if equipped) and then put a microwave-safe plate right-side up on top of the saucer. You can also use another glass turntable tray that doesn't fit instead of the plate.
Be sure both are centered, checking them frequently to be sure shifting does not occur. Otherwise, a spill of hot material could result.
Another option is to check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round".
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 10, 2008 | Microwave Ovens
RCA CDRW121 2-Disc CD Recorder Logo
55 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
