Question about Freeverse Flick Fishing
Flick fishing how can I rotate my device to go fishing because It dont work
When I start the game it wants from me to rotate the device I rotated it every single side but it dont want to work
HELP!My Fonepad cant auto rotate!
Go to settings>display and make sure the autorotate is enabled. If it still isn't working then there may be an issue with your device's accelerometer, test it in a game such as temple run.
Mar 31, 2014 | ASUS FonePad
Downloaded a game but can't get it to rotate the right way
If you have rotate turned on and it still will not rotate you have a game that doesn't fit the format of your screen. Not all games will work perfect on every device.
Aug 01, 2013 | Tablets & eReaders
My iPad has a lock on it beside the battery sign how I can remove it so I can send emails
You probably locked the screen rotation,
to fix this:
  1. Rotate iPad so the display is in the desired orientation.
  2. Double-click the Home button to display recently used apps.
  3. Flick from left to right along the bottom of the screen.
  4. Tap the Screen Rotation Lock button on the bottom left of the screen.
  5. The lock will disappear
Jan 17, 2013 | Apple iPad (16 GB) WiFi Tablet PC
I PUSH THE START BUTTON THE GAME KEEPS ROTATING SCORING POINTS AND WON'T STOP
You might want to repost this in a different section, even video games.
Jul 26, 2012 | Cars & Trucks
How do you unlock the rotation on an iPad? I've looked it up and I'm told the switch above the volume control turns it off and on, but on my iPad it just turns the volume off and on.
Use the following steps to enable screen rotation lock:
  4. Tap the rotation lock button on the bottom left of the screen.
  5. A padlock will appear in the rotation lock button.
Dec 28, 2010 | Apple iPad (16 GB) WiFi Tablet PC
JVA 2440 rotates continuously in spa mode
If you remove the handel and open thr top of the actuator you will see a set nut on the center of the shaft that you use to set where the valve stops. If this is tight then you may have a bad micro switch in the unit and you should replace the actuator. Good luck.
Jan 07, 2010 | Jandy Aqualink Rs4 One Touch Control...
Humming noise from tyres
Make sure the tire pressure is proper..
Be sure to rotate them every 6-k miles or so..
If they are not rotated - the tread could get the fish-scale effect..
Run you open hand gently across the tread in the direction of up and down - not side to side..
If you feel the fish-scale effect - it is from not rotating them and that is what is causing the humming noise..
Rotate them asap.. if it has been TOO long - the "humming" might not go away until your next set of tires..
Good luck ;o)
Sep 16, 2009 | Lexus LS 400 Cars & Trucks
How do you catch the spotted bass
The easiest way is to use the attractant. When the rotating circle comes up, do it and you'll catch the specific type of fish that is your objective.
Mar 08, 2009 | Nintendo Rapala''s Fishing Frenzy for Wii
How to reel in a fish
To reel out push on Z on the nunchuk and continue to rotate nunchuk or push on B and Z
Jan 12, 2009 | Nintendo Rapala''s Fishing Frenzy for Wii
CD will not rotate.
The spindle motor may have failed. Can you try 'starting it off' by hand after inserting a CD?
Jan 25, 2008 | Teac AD-600 3-Disc CD Changer
Freeverse Flick Fishing Logo
35 people viewed this question
Top Freeverse Apps Experts
Erin Wood
Erin Wood
Are you a Freeverse App Expert? Answer questions, earn points and help others
