Question about Deckmate Sonora Wood Burning Outdoor Fireplace
Ash pan I have had my outdoor wood burning fireplace for about 3 years an the ash pan & handle have rusted an broken, where can I get another one to replace this one? I bought it at Lowes in Danville KY an they do not carry any kind of parts. Thanks
Electric fireplace or wood burning fireplace. Which is better ?
Source: The Good And Bad Of Electric Fireplaces
You are able to save money by using electric fireplaces because they are significantly cheaper and more efficient to run. As opposed to turning on the heat for the entire home, you only have to actively heat one area although this is the same case for traditional fireplaces. Still, using an electric fireplace eliminates the need for buying wood, starting and maintaining a flame, and cleaning/servicing a fireplace with a chimney. Moreover, you are able to use an electric fireplace for an extended period of time. Wood-burning stoves are limited by the supply of wood. Gas burning fireplaces don't have that restriction, but require costly installment and creation of gas-line access. A foundational benefit of electric fireplaces is not causing any harmful particle emissions, which are a major side-product of traditional fireplaces, and one of the causes of their degradation.
How To Care For An Electric Fireplace
electric-fireplace-luqhqtew4twq4g4srgxhyj11-3-0.jpg Given the clear advantages that electric fireplaces have over traditional fireplaces, even die-hard fireplace lovers can justify making the switch to electric. Still, it is important to be apprised of the precautions and maintenance requirements before committing to a purchase. The most likely "repair" will be to change out bulbs as they die, typically about every two years. Models with LED bulbs will likely never need replacement. If you have a fireplace with conventional bulbs, replacing them is simple and straightforward. It is done by unplugging the fireplace, allowing it to completely cool if it was in use, and then accessing the rear panel of the unit. The panel can be unscrewed easily with a screwdriver. With the back panel removed, you should look for the bulb housing. This may differ from model to model, so consult the user guide before continuing (making sure to note what type of bulb is required). When you have the replacement, remove the old, and replace it with the new bulb. Some fireplaces require halogen bulbs which should not be handled by hand as this could compromise the longevity and quality of the bulb, in which case you should wear gloves to handle the bulb. With the new bulb in, you can screw back the rear panela and use the fireplace normally.
Electric fireplaces contain fans that are instrumental in providing heat to the room. The fan, as well as the other components, are usually pre-lubricated. However, if the fan is halting or not moving smoothly, it may indicate that cleaning is required. As with any other maintenance, make sure the unit is turned off and unplugged. You can use your vacuum's brush and wand attachments to clean the fan. Begin by taking off the grate and lightly cleaning to remove dust and grime. When finished, you can retrace with the wand attachment to pick up any remaining dirt. Replace the grate when you're finished.
The exterior mantle requires nothing more than occasional dusting and wiping. You should avoid the use of harsh chemical sprays, and instead, opt for mild soapy water and a lint-free cloth. Cleaning the glass display and mantle will make a big difference in the appearance of the unit. Be sure to dry the unit completely to avoid streaks and water marks.
Jun 21, 2017 | Home
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
mendotahearth.com/gas-fireplace-stove-owners-manual.php
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
[PDF]FIREPLACE HEATER - Crane
crane-usa.com/assets/.../Fireplace_Heater_2013.pdf
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
Can't keep the wood burning in stove. How does the buck stove take in air?
To burn properly, it needs proper combustion air and proper draft. Draft is effected by the size and height of the flue the appliance is connected to and by how much combustion air is available. The appliance flue connection should not be reduced to fit a smaller chimney size. That is, an 8" flue should not have an 8 x 6 reducer to vent it into a 6" chimney.
The wood you are burning could contribute to a poorly burning fire. To burn properly, the wood needs to have been "seasoned" for a minimum of 1 year or close to it. Two years is even better. "Green"
or freshly cut wood contains an unbelieveable amount of moisture in it and a tremendous amount of the heat is wasted just "preheating" the wood to the temperature that causes it to release gasses for ignition.
I don't know the style or model of your Buck, but all wood burning appliances should have combustion air dampers of either a sliding design, rotating round design or hinged design with handle at the bottom front of the firebox. I'm sure there are some fancy new designs that have air piped in from outside the structure.
Every wood fired stove, fireplace or furnace has its own idiosyncrasies and its up to the user to determine what's required for making it operate as designed.
Dec 06, 2014 | Buck Stove Home
Rusted Ash Pan
They sell stuff for that at manards you could make your own send me pick
Apr 04, 2014 | Deckmate Sonora Wood Burning Outdoor...
I have a gaz fireplace Marco DWF36CF-3 vented and would like to know if i can burn wood in it
My name is mike. YOU DO NOT want to attempt to burn wood in a gas fireplace. The reason for it, is the venting is not designed for the fumes and high heat the wood produces. Only way you can safely burn wood, in a gas fireplace is have to make sure the piping and venting is set up correct to burn wood. Your problem is not most likely your stove or fireplace for the safety, it would be your venting. Thanks Mike
Oct 22, 2011 | Heating & Cooling
Wood burning heater when putting wood into stove lots of smoke comes into the house when door is opened.
It ain't drafting right or you have the damper closed. Look for obstructions in the smoke stack.
Wood burning tips
  • Burn only wood. No garbage, plastics, rubber, paint or oil, briquettes, paper, etc. Burning these items releases harmful chemicals into the air.
  • Burn Wise Program from EPA: Emphasizes the importance of burning the right wood.
  • Build small, hot fires instead of large, smoldering ones.
  • Don't "bed the fire down" for the night. Holding a fire overnight is a fire hazard and can create serious indoor and outdoor air pollution problems.
  • Open your damper if the smoke is dark. Dark smoke indicates more pollution is being produced and fuel is being wasted.
  • Keep your stove clean and well-maintained. Follow manufacturer guidelines; replace catalytic stove filters every 1-4 years. Have your chimney checked and cleaned at least once a year.
Use seasoned wood The best fuel for woodstoves is dry, "seasoned" wood. Seasoned wood has a moisture content of about 20% or less. It tends to be dark in color, cracked on the ends, light in weight and has bark that is easily broken or peeled. Here are some tips for preparing seasoned wood:
  • Split the wood to help it dry. Wood will dry out more quickly and burn best if the wood is cut to about 3 1/2 inches to 6 inches in diameter.
  • Cover the split firewood to protect it from the weather and stack it loosely in alternating layers, at least 6 inches off the ground.
  • Time must be given to allow the wood to reach 20% or less moisture required for seasoned wood. This process takes approximately 6-12 months. Think ahead and buy next winter's wood well in advance.
It is recommended an annual chimney cleaning to remove creosote build up and to identify potential problems. Things to consider:
  • The Chimney cap may be plugged by debris.
  • Catalytic combustor and baffles are exposed to very high heat and deteriorate as used. Replace every 1-4 years depending on use.
  • Stovepipe angles and bolts are subject to corrosion.
  • Gaskets on airtight stove doors need replacement every few years. Gaskets and seals are used by the appliance designer to control the location and flow of air into the appliance.
  • Check seams on stoves sealed with furnace cement. Seams may leak and cause you to loose valuable heat and reduce the efficiency of the unit.
  • Replace broken or missing firebricks.
  • Keep the floor of your stove clean of debris and ash.
-from the web
Nov 02, 2010 | Heating & Cooling
I HAVE JUST PURCHASED AN IRON HEARTH OUTDOOR FIREPLACE GRILL MODEL 30072. WHEN WE STARTED TO BURN FIRWOOD THE BOWL CRACKED, ABOUT A 6 INCH HAIRLINE CRACK. wE DO NOT BELIEVE WE OVERTIGHTENED THE BOLTS AS...
If the outdoor fireplace was put together correctly, it shouldn't have cracked under normal use. I would contact the manufacturer about a refund/replacement. Outdoor fireplaces in general are designed to stand up to very high heats and outdoor conditions. I do not believe that you can replace just the bowl. You might be able to seal it with a high heat resistant sealant/bond, but I would try to get a refund. It sounds like your grill might have been defective.
Jul 19, 2010 | Kay Iron Hearth Portable Fire Pit Grill
Leaking smoke into loft
The outdoor fireplace should not have smoke in the loft. Have you tried cleaning the unit and making sure to remove any remnants of previous fires? The burning ashes could be causing the increase in smoke. I think that you should be able to find a solution that does not involve adding a liner, but I would try a thorough cleaning first.
Nov 24, 2009 | Spirit Elements Outdoor Fireplace Open...
Deckmate Sonora Wood Burning Outdoor Fireplace Logo
48 people viewed this question
Top Deckmate Home Experts
Donni Steen
Tom Chichester
Are you a Deckmate Home Expert? Answer questions, earn points and help others
