Question about Motorola Mobility i730 Cellular Phone
Self check fail: 00800 Hit 4-5-6 to re-program codeplug.
Motorola gp338 codeplug problem
Send the radio to Motorola or a qualified repair center to get the corrupted codeplug cleared.
Dec 04, 2013 | Motorola Radio Communications
How to resolve CODEPLUG ERR on Motorola PTX760
Your radio needs to be reprogrammed or repaired. This type of error can occur for no reason, or during an interruption in programming. Check your programming/test set-up. Do not try to reprogram using the same codeplug (saved version of programming) as previously used, as it may be corrupt. If you cannot get the error to clear with a fresh programming, the radio will need to go to Motorola to have the error cleared.
Best regards.
Apr 12, 2013 | Laird EXL42MX * Motorola PTX760 Motorola...
I have moved some movies onto the my book which i just purchased, it plays the sound but does not show the picture what am i doing wrong
Contacting WD Technical Support
When contacting WD for support, have your WD product serial number, system hardware, and
system software versions available.
North America Asia Pacific
English 800.ASK.4WDC Australia 1 800 42 9861
(800.275.4932) China 800 820 6682/+65 62430496
Spanish 800.832.4778 Hong Kong +800 6008 6008
India 1 800 11 9393 (MNTL)/1 800 200 5789 (Reliance)
011 26384700 (Pilot Line)
Europe (toll free)* 00800 ASK4 WDEU Indonesia +803 852 9439
(00800 27549338) Japan 00 531 650442
Korea 02 703 6550
Europe +31 880062100 Malaysia +800 6008 6008/1 800 88 1908/+65 62430496
Middle East +31 880062100 Philippines 1 800 1441 0159
Africa +31 880062100 Singapore +800 6008 6008/+800 608 6008/+65 62430496
Taiwan +800 6008 6008/+65 62430496
* Toll free number is available in the following countries: Austria, Belgium, Denmark, France, Germany, Ireland, Italy,Contacting WD Technical Support
Korea 02 703 6550
Netherlands, Norway, Spain, Sweden, Switzerland, United Kingdom.
Netherlands, Norway, Spain, Sweden, Switzerland, United Kingdom.Contacting WD Technical Support
Korea 02 703 6550
Feb 06, 2011 | Western Digital My Book Essential Edition...
I need to know if I can fix an eprm err with the
An eeprom error can occur during programming due to several factors, it may have been as simple as a momentary glitch in the computer, radio or cable, or other unknown cause. Once you've discovered the error, you need to get rid of any saved codeplugs associated with the problem radio. You can try cloning another radio's codeplug back into the unit to see if it clears the error. If this does not work, there is nothing you can do using the CPS software to resolve the error. The radio would need to go back to the Motorola factory depot or a qualified/experienced service facility to have the error cleared and have the radio reprogrammed.
Best regards.
Mar 12, 2010 | Motorola EM1000R Two Way Radio
Xtl head shows "maintenance mode" "remote device" is it not programmed? Also is control head wiring red 12 volt and yellow ign.?
The red wire on the remote head should go to the battery (with a fuse inline) the yellow wire should go to a switched 12 volt source (with a fuse).
The XTL radio is in need of correct programing, With out looking at the codeplug I would say that the option for remote head was not checked.
Hope this helps, Bill
Aug 22, 2009 | Motorola Radio Communications
I dont know how to program
1. Program the ABC switch as zone select.
2. Program each 'personality' into the proper zone (eg A1, A2..., B1, B2..., C1, C2..., etc)
3. Load the codeplug into the radio.
May 27, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Working codeplug for MTz 8000
Only from Motorola or a Motorola Service Center. The radio requires all programming to be either programmed by a motorola dealer or by the owner of the the trunking system if they own the software for thier system.
Mar 31, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Wont turn on
i just read something on this problem.. something to do with the phone being stuck in program mode and you probably have to take it to the store to have it fixed.
Aug 04, 2007 | Motorola Mobility i560 Cellular Phone
Motorola Mobility i730 Cellular Phone Logo
134 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
