Question about Kocaso M1050
Start up i cannot start up the pad it just says safe mode. i did return it to factory settings as i purchased it second hand
  • Kocaso Master
  • 2,219 Answers
SAFE MODE OPTIONS
1. Press the System or Menu Button in the lower left corner and navigate to Manage apps.
2. Find the most recent app you installed.
3. Force close it.
4. Disable it if possible.
5. Remove this app.
6. Reboot the boot to see if the Safe mode is gone.
If the Safe mode label is still present, the article suggests that it may be necessary to press several keys to achieve the removal of the Safe mode label and its effect of suspending the other apps. In essence, we now move to the second discussion of entry into Safe mode:
1. Safe mode can be entered by pressing buttons at start-up. .
2. It is not known exactly which buttons were pressed but it mostly likely was the System and Home (center big button) and maybe even the Escape/Back button on the right.
3. The right combination of buttons, which supposedly are the same to enter Safe Mode, are the same to exit Safe Mode.
4. If you are certain you entered Safe Mode by accident - meaning you know you did not recently or just now installed an app that force closed Android, then you just have to find the combo to exit it.
5. Try pressing the volume buttons might clear the Safe Mode on the first reboot after initial entry into Safe Mode.
6. If the Safe Mode label disappears after pressing the volume buttons, your phone is okay.
7. If the label is still present, try rebooting the phone again.
Safe mode in Android what to do if you see that label on your screen
Posted on Feb 22, 2015
My camera will not stop taking picturs my tablet keeps going on and off
hi Sheila,
this is all i could find out from the internet.
start to suspect an app on the device is the cause. To test that you may want to start the tablet in "Safe Mode" and see if the problem still happens. If it doesn't happen when in "Safe Mode", then you need to figure out which app is the culprit.
To get into "Safe Mode" please do the following.
1. First turn off the tablet.
2. Next press and hold "Power" until you see the manufacturers logo on the screen, then release the power button.
3. "Quickly" press "Volume Down" and hold it for few seconds until you see the message "Safe mode: ON" or something similar.
4. If you wanted disable it, simply repeat the steps above, and you should see "Safe Mode: OFF" rather than on.
plus this.
Thank you everyone that has provided your information to us here. I am going to compile all the steps that have been suggested here and add a few for you guys to try. If none of these work, the tablet will need to be serviced.
Charging troubleshooting.
First off we suggest you use the original charger. This is the only charger we can guarantee is compatible with your device. If you still have this issue with your original charger, you can test your device with another charger to see if you get the same results. If this is the case you should continue with these troubleshooting steps. If this solves the issue, you will need to obtain a new charger.
Safe mode Test
Next you should test your device in safe mode. The steps to put a tablet into safe mode can vary, so I would suggest googling your "tablet model" safe mode. If you cannot find steps to put this device into safe mode, let us know here and we can pull up the steps for you in most cases. Once in safe mode test your device for a few days. If you have this issue still, then there is some type of hardware issue that will need to be service. At the bottom of this post, I will provide a link to where you can set up this service.
Factory reset/ uninstalling apps.
If you do not have this issue in safe mode, then there is some type of software issue with this device. You can do one of the following.
Factory reset your device and then test your device. You will need to keep note of the applications you are installing so if you install something new, you will know it is that application that is causing the issue.
The other way to test this is to go the other way around. You can uninstall applications till the issue does not appear anymore.
Lastly, if none of these help the issue, you will need to have this device set up for service. If you would like to look into this option, you can do this here. http://www.samsung.com/us/support/service/request
Dec 03, 2017 | Tablets & eReaders
Why does my nextbook keep asking me if I want to put it in safe mode?
The device went into safe mode because the app that you downloaded was not a safe application. The device does this so that the application cannot cause more problems to your device. Even though the app was downloaded from the app store it was not deemed safe by your device. Here are some tips that will help you to get your device out of safe mode: -Ensure that if you have a case on your device that you take it off being that the case may be holding the volume button causing you to boot into safe mode -Try turning the device off then back on to get out of safe mode -Power off your device, then reboot by holding the power button + volume up key, then in the boot menu select reboot device -This is sometimes caused by the users accidentally tapping safe mode when cutting the device on so simply restart your device Most users have success by simply restarting the device in order to be able to get out of safe mode. Do your best to restart or reboot your device before you have to perform a hard reset to get the app off of your device to no longer go into safe mode In order to hard reset -Power off device -Hold down volume up + power -Release at the boot menu -Use the volume keys to highlight factory reset -Press the power button to select factory reset -After this the device will begin to reset itself -After it resets itself use the volume keys to highlight reboot device -press the power button to have your device rebooted in its factory settings
Apr 20, 2016 | Nextbook Tablets & eReaders
How do I get my LG 7.0 tablet out of safe mode?
Get an Android Tablet out of safe mode
Use the following steps to get out of safe mode.
    1.Restart your device by holding the power button, then tap Power off.
    2.Tap Ok to confirm.
    3.Power the device on. Your tablet should now be out of safe mode. If the device is still in safe mode use one of the following methods.
      ·Uninstall the last application you installed:
      1.From the Apps menu, tap on Settings.
      2.Tap on the app and then tap on uninstall.
      3.Restart your device.
      ·Perform a factory data reset:
      1.From the Apps menu, tap on settings, and then tap backup and reset.
      2.Tap on factory data reset, and then tap reset tablet
      3.Tap erase everything to format your tablet back to factory default configuration.
Nov 21, 2015 | LG 8GB G Pad 7.0" Wi-Fi Tablet Black
How do I get my nextbook tablet out of safe mode?
Nov 04, 2015 | Nextbook Tablets & eReaders
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
I have tried all of the suggestions in the forum including a factory reset but my Toshiba Excite Tablet remains in safe mode. How do I remove the tablet back to normal mode?
Most likely it is dead. If you tried a real factory reset, then just look for another tablet. Toshiba is not going to help you as, from my experience, they do not care after they sell you the prodcut and it gets out of warranty.
Consider Samsung.
Dec 24, 2014 | Toshiba Excite 10 16GB 10.1" Capacitive...
Letter 'B' doesn't work on my keyboard!!!!!
You could try re-calibration, or reset the device, or restore device factory settings as per the below 3 options. There is also a link at the bottom to a user guide. If that doesn't work, you probably have a faulty touch screen, in that case return the device to the place of purchase for warranty repair/replacement:
Q: G-SENSOR is not responding.
A: You should calibrate your device using 'Settings' / 'Display' or Gravity Calibration App (optional).
Q: My GOCLEVER tablet does not react well, it is freezing, works much slower than normal or does not respond at all.
A: We recommend to restart your device using turn on/off button (pressing 3-4 sec) or reset button (with a pointed object).
Q: How do I restore factory settings?
A: You should use 'Factory reset' function available in the 'Settings' App. The factory reset will help if your application causes the inappropriate operation of your device. Note, that all your files will be lost, so we suggest to copy them to another device (pendrive, PC etc).
http://1palladium.com.ua/load.php?f=goclever-terra-101.pdf
Oct 13, 2014 | Tablets & eReaders
I have an Asus Memo Pad HD 7 which I purchased 3 months ago. It worked wonderfully until one evening while using the pad plugged into the wall, it stopped showing the charge icon in the upper left hand...
the more programs you install and run in the back ground the more the battery is drained. It comes to a point where there are so many programs running the gadget cannot run & charge at the same time. It might charge better if you uninstall a lot of programs or do a factory reset but that is drastic
Oct 30, 2013 | Tablets & eReaders
How do u master clear a a pad tablet
If you mean an iPad by "a pad tablet", then completely clearing it is very simple:
  1. Open up Preferences
  2. Select 'General'
  3. Select 'Reset'
  4. Tap 'Erase all content and Settings
This will completely wipe the iPad, returning it to it's factory state.
Hope that helps!
Feb 06, 2011 | Tablets & eReaders
Kocaso M1050 Logo
250 people viewed this question
Top Kocaso Tablets & eReaders Experts
CrisO
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
