1911 dll i cant paste it to the directory help pls.
    Novelist:
  • 110 Answers
Paste what into where? My assumption is that you have a "Dynamic link library", or dll for short, called 1911.dll.
My second assumption is that you are probably trying to paste it into the system32 folder.
But what version of Windows are you using? Windows xp, Vista, 7, 8, 8.1? (I would hope not older than XP).
This information is needed to guide you. please tell us on what version of windows you want to put it, and in what folder.
Posted on Apr 01, 2014
WDSUTIL.dll is missing from your computer this problem my system pls help me...
Downlaod WDSUTIL.dll here: http://www.dllme.com/dll/files/wdsutil_dll.html
Extract "WDSUTIL.dll" to a location on your computer. We recommend you to unzip it to the directory of the program that is requesting "WDSUTIL.dll"
If that doesn't work, you will have to extract WDSUTIL.dll to your system directory. By default, this is:
C:\Windows\System32 (Windows XP, Vista, 7)
If you use a 64-bit version of Windows, you should also place WDSUTIL.dll in C:\Windows\SysWOW64\
Make sure overwrite any existing files (but make a backup copy of the original file).
Reboot your computer.
For Instant Fix use Reginout system utility.
Jan 18, 2013 | Computers & Internet
Tip
How can you crate setup file or .exe using QT platform
We are developing software but we are unable to run in others PC/Computer. As we know that QT is Platform Independent and Open source Software, which is use Nokia to develop Mobile Application.
Needs:
  • Qt
  • Setup creator
  • libgcc_s_dw2-1.dll
  • mingwm10.dll
  • QtGuid4.dll
  • QtCored4.dll
Procedure:
  • When you start a project then automatically qt creates 2 folders within main Directory. One is "Debug" and another is "release".
  • If we are want to run application in other PC then we need ".dll" files and combined them.
  • Open My Computer and go to the "Installation Drive" where QT is installed.
  • Find out the Main Directory of the QT. If you install in "c:" then go to the c drive and open "qt" folder and get a directory name as "2010.01"
  • When you open "2010.01", then you can see another directory as "qt" open it.
  • You click on Search option from the "Standard Button" bar and type the libgcc_s_dw2-1.dll file and search it. When you find it copy the file and paste into your Project Directory's "Debug" folder. Do same things for another three ".dll" files.
  • After that you can run your application by the .exe file. Does not need to open Qt and open your project then run.
  • Now you can simply copy the project Directory and paste into other PC and open Directory and run it.
  • Or you can create a shortcut on the desktop as others software. From where you can run it by Click.
Deploy and Packaging:
If you want to create a setup file as other software, need to install it. Then -
  • First download a file "icinst", it's free. After that install it.
  • After that open it from start programs and windows will be come where you select your Project Directory and do "Next".
  • You can create a License Agreement as others software.
  • Do as per the given Instruction.
Note: Before create a setup file you must be collect all dll files and paste in "debug" folder
Imon Saha
on May 16, 2011 | Computers & Internet
I am trying to install master of orion II on a windows 7 64 bit operating system and it won't open, because DPLAY.dll cannot be found. I have downloaded the driver, put it in the sys32 folder, the...
First install MOO2 on a computer were it runs and copy the entire micropose directory to the program files (x86) directory.
Then copy the dplayx.dll file from the windows\sysWOW64 directory and renamed it dplay.dll and put it back in the sysWOW64 directory (be sure the dplayx.dll file is still there) or if you have the 32 bit version it should be found in the system32 directory (I am guessing, but you will need a dplay.dll)
Found this great post about getting MOO2 to run in Windows 7, and even with the compatibility enabled it still has a graphics palette problem. The reason is because of Windows explorer, and to fix the problem you need to disable explorer.
I know this can be a little too much for some, there is an easier way.
Simply create a notepad file on your desktop, and paste the following.
(If you have 32-bit version of Windows 7.)
TASKKILL /F /IM "explorer.exe"
cd C:\"Program Files"\Microprose\Orion2
start /w C:\"Program Files"\Microprose\Orion2\Orion95.exe
start C:\Windows\explorer.exe
(Copy and paste below if you have 64-bit)
cd C:\"Program Files (x86)"\Microprose\Orion2
start /w C:\"Program Files (x86)"\Microprose\Orion2\Orion95.exe
Make sure you rename the text file to Moo2.bat, then it will launch Moo2 and disable explorer. Moo2 plays perfectly fine this way, even without any of the compatibility enabled.
The Batch file will also restore your explorer when you exit the game.
Alternatively, you could use DosBox to play the game.
Click Here for instructions
Hope this helps,
G33k
May 11, 2011 | Spectrum Holobyte Masters Of Orion 2 -...
How can I fix my gdi.dll, it needs to be downloaded and my toolbars are gone and cant be accessible, I accidentally erase it
gdi.dll should be located in the i386 directory. You may find a copy of it in a directory called DLLCache under the C:\windows\ directory. Hope that helps.
Nov 07, 2010 | Microsoft Windows XP Professional SP2
Mwsbar.dll & m3plugin.dll files missing
Download the files from
m3plugin.dll---->http://www.mediafire.com/?k6blbjrbtvzxkq7
mwsbar.dll---->http://www.mediafire.com/?pvmo4vzkt44r3i4
Copy and Paste the above file into the below mentioned directory
C:\Windows\System (Windows 95/98/Me), C:\WINNT\System32 (Windows NT/2000), or C:\Windows\System32 (Windows XP, Vista, 7).
**Make sure overwrite any existing files (but make a backup copy of the original file).
**Reboot your computer.
Oct 09, 2010 | Computers & Internet
Cannot install office 2007 due to an osetup.dll error
Go here first and follow the steps. http://dll-repair-tools.com/dll/essential-osetupdll-for-smooth-running-of-microsoft-office
Now go here and download the DLL file. http://www.dll-files.com/dllindex/dll-files.shtml?osetup
Now go to the Windows directory and chose the subdirectory System. Paste a copy of the DLL here. Now chose the subdirectory System32 and do the same.
Reboot the computer and install Office. You should be good to go now! Good Luck Phil
Feb 21, 2010 | Microsoft Office Home and Student 2007...
I was about to open the Microsoft Office word when suddenly a pop up appeared on my screen and says "Microsoft Office Word needs file msointl.dll to run". What should I do. I need to open my important...
Goto :
http://www.dlldump.com/download-dll-file...
There you'll find the dll file you need. Just copy and paste it in the correct directory.
(usually it will be
C:\Program Files\Common Files\Microsoft Shared\office11\1033\)
Nov 13, 2008 | Microsoft Windows XP Professional
Pls. help
I had visited a website to get a free screen saver. somethling like a toolbar or something was downloaded onto my computer, I used Windows XP. Actually I was cancelled the process of download but obviously when I was restart my computer a error message showed "Run DLL
Error loading C:\PROGRA~1\MYWEBS~1\Bar\1.bin\M3PLUGIN.DLL
the specified module could not be found
Is any suggestions as how to remove this unauthorized download from my system.
Thanks in advance
Aug 13, 2008 | Intel Motherboard
Intermec 761B - ITCScan dll issue
Copy and paste the ITScan.dll file to as follows
c:windows/
and
c:windows/system/
and
c:windows/system32/
Please rate SOLVED if you like my solution.
Best regards,
Philip
Nov 02, 2007 | Intermec 761B Portable Terminal
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
