Officejet 6600 has a false paper jam
Everything is cleared and I still cant get to stop telling me I need to open the rear access panel and clear
  • 4 Answers
Clean off any dirt on the black rollers when you open the rear access panel. Also, if you have a can of air blow out the inside pretty good. The next thing I would try, is go to HP website and see if there is a firmware update for your printer. If, so download it and update the printer. Sometimes that will break it out of that error cycle.
Posted on Apr 01, 2014
jaylex
  • 417 Answers
SOURCE: sharp al 1655 false paper jam message,
Check that the paper feed roller is clean as if the roller slips it causes a late paper pickup jam but nothing will be in there also maybe a small torn piece in the machine some where. and check the fuser make sure that is it not stuck in there if no to all these then is will need a control board.
Thanks J
Posted on Feb 17, 2008
  • 4 Answers
SOURCE: 202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Posted on Aug 08, 2008
frcs68
  • 1605 Answers
SOURCE: rear access panel open
open the rear panel, check all path is clear. close the rear panel, mkae sure that the sides of the rea panel is locked in place. there is micro switch that detect the door panel. if the door is close correctly the micro switch os actived then you will get the error.
Posted on Jan 13, 2009
SOURCE: I got a paper jam. I can not get to the paper. I s...
I removed the cartridge, pulled out the skewed paper and it ripped leaving a very small piece behind. This continued the notice 'paper jam'. I had to remove the two side springs, remove the two star headed screws nearby the springs and prise up the grill to remove the paper shred. Replace everything and the error message is gone and printer normal.
Posted on May 25, 2010
SOURCE: HP Officejet Pro L7800. Had paper jam, but opened
mine was 2 there was paper stuck in the little white gears
Posted on Jul 17, 2010
Clear false jam paper
When I see this situation, I look carefully for a jammed senor lever. They either hang down from the top, or protrude up from the bottom of the paper path. They should freely move. If the do not, they are activating the sensor they are attached to.
They can get caught on the edge of a cover, or have a piece of paper from a previous jam caught in them.
http://h10032.www1.hp.com/ctg/Manual/c01770356.pdf page 152-154 Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
Apr 01, 2014 | HP OfficeJet Office Equipment & Supplies
Message appears "Paper jam".
Paper jams can be true or false. A false paper jam occurs when the error message displays, but no jammed paper is in the product. The following solutions apply to both true and false paper jam errors.
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report
Solution one: Clear the paper jam Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray.
Step two: Clear the jam from the back of the All-in-One
  1. Figure 2: Remove the rear access doorc01562020.gif
  2. Gently pull any jammed paper out of the rollers inside the product.
  3. Carefully remove any scraps of paper that are still stuck in the product.
  4. Reattach the rear access door. Insert the two posts on the right side of the door into the holes on the product, and then push the door in until it snaps into place.
  5. Reconnect the power cord to the back of the product, and then press the Power button (c01602202.gif ) to turn on the product.
Step three: Clear the jam from the front of the All-in-One Follow these steps to remove the paper jam from the front of the product.
  1. Without opening the cartridge access door, check the tray for jammed paper that you cannot remove from the back.
  2. If you see jammed paper, gently pull it out.
Step four: Print a self-test report
  • If the issue persists , continue with the next solution.
Solution two: Make sure that the carriage can move freely Follow these steps to make sure that the carriage can move freely. Step one: Check the paper path
  1. Check for any paper or object that might be stopping the carriage. Figure 4: Example of paper stuck in cartridge access areac01950807.gif
  2. Remove any paper or objects you find.
  3. Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle , move the carriage to the right.
  4. Remove any paper or obstructions found.
  5. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left, and then to the righ
Step two: Print a self-test report
  • If the self-test report does not print , continue with the next solution.
Solution three: Clean the rollers and the rear access door Dust, paper fiber, and other debris might accumulate on the paper feed rollers and cause paper jams and paper feed issues. Follow these steps to clean the paper feed rollers inside the product. Step one: Clean the rollers
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the back of the product.
  3. Press in the tab on the left side of the rear access door, and then pull the door away from the product to remove it. Figure 6: Remove the rear access doorc01562020.gif
  4. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  5. Press the cloth against the rollers and rotate them upwards with your fingers. Apply a moderate amount of pressure to remove any dust or dirt buildup. Figure 7: Rotate the paper feed rollersc00212278.jpg
  6. Make sure that the paper feed rollers on the rear access door are clean, free of paper bits, and rotate freely.
  7. Clean the surface and the rollers of the rear access door the same way you cleaned the large rollers inside the product.
  8. Replace the rear access door. Insert the two posts on the right of the door into the holes on the product, and then push the door in until it snaps into place.
Solution four: Service the product
Aug 08, 2011 | HP PSC 1610 All-In-One InkJet Printer
While printing 2 or 3 lines it shows paper jam message. Can't print even a page!!!
make sure you don't have any small pieces of paper stuck in the printer s.gif s.gif s.gif
Paper jams can be real or false. The unit may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same. WARNING: Jammed paper must be removed using the rear access door and the power cord must be disconnected or a carriage jam or mechanical damage may occur. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 1: Removing the rear access door c00108288.jpg Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
  4. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to buy on this page to order replacement parts.
  5. From the rear access door opening, remove the jammed paper.
  6. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  7. Reinstall the rear access door.
  8. Reconnect the power cord to the unit and turn the unit on. If a carriage stall occurs after clearing the paper jam, resolve the carriage stall.
Jan 10, 2011 | HP Deskjet F4100 All-In-One InkJet Printer
Nov 02, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
I HAVE A HP OFFICEJET J6480 ALL IN ONE. THE PROBLEM IS THAT IT SAYS I HAVE A PAPER JAM. I HAVE CLEARED ANY JAM, BUT IT WON'T CLEAR OUT
Hp printer paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Aug 17, 2009 | Office Equipment & Supplies
Says Paper Jam But No Paper In It
Hi
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 1: Removing the rear access door bd842f6.jpg
  5. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to buy on this page to order replacement parts.
  6. From the rear access door opening, remove the jammed paper.
  7. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  8. Reinstall the rear access door.
  9. Reconnect the power cord to the unit and turn the unit on. If a carriage stall occurs after clearing the paper jam, resolve the carriage stall.
Preventing paper jams The following information will help prevent paper jams from occurring:
  • When loading paper in to the paper tray, push it in until it meets first resistance. Do not continue pushing the paper in. If the paper is pushed too far in, more than one page is picked and paper jams result. This is the most common cause of paper jams with the HP Officejet 410 series.
  • Never use paper that is wrinkled or damaged in any way.
  • If you are having problems using paper that has already been printed on once, replace it with fresh paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door isn't locked.
  • Every six months - one year, clean the paper feed rollers with a rag slightly dampened with clean water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | HP Officejet 4110 All-In-One InkJet...
False paper jam on HP Office Jet V40
hp officejet v40 indicates a paper jam and it is cleared nothing
Apr 04, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Rear access panel open
Jan 05, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP ALL IN ONE PRINTER
Follow these steps to clear paper jam
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it around so the back of the unit faces you.
Figure 2: Removing the rear access door
  1. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  2. From the rear access door opening, remove the jammed paper.
  3. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  4. Reinstall the rear access door.
  5. Reconnect the power cord to the unit and turn the unit on.
  • Never use paper that is torn or wrinkled.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with new paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door is not locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
Jun 19, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Paper jam in HP 4255 office jet all in one printer
Clearing paper jams
CAUTION:
Jun 10, 2008 | HP OfficeJet 4255 All-In-One InkJet...
114 people viewed this question
k24674
