Question about Philips Magnavox DVD/VCR Dual Player
The dvd/vcr player comes on by itself. The remote does not work for the DVD player.
The machine comes on by itself after it has been shut off. The remote works for the VHS part, but the machine does not respond to any commands on the DVD side.
SOURCE: transfer VHS to DVD
The illustrations within the PDF is very help!
To play disc in other DVD players…
The disc needs to be finalized.
Page 37 of the manual has “Finalizing a disc”.
Recording from DVD to VCR…
Page 39 “Dubbing Mode”
http://www.funai-corp.com/support/manuals.aspx
Type in the box: MWR20V6
Posted on Nov 25, 2007
SOURCE: dvd door won't open
Mine just did the same thing about 1/2 hour ago. Found this site and tried advice of gopackgo - worked perfectly!
Posted on May 26, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: need a code for a magnavox dvd/vcr com for a jumbo universal remo
7-1-1 and 0-7-1-1 are the Magnavox universals.
Posted on Feb 15, 2009
  • 3 Answers
SOURCE: VHS won't play, sounds like tape will load then power shuts off.
This is similar or identical to another post, but here is an answer...
Hi, I have a solution you can try.
I had exaclty the same problem. When I tried to play a tape it would load (However, I recall I had to push hard to get the tape to be accepted, which is part of the problem) but would shut off after about 12 seconds, then when I powered back up the tape would eject. Finally I took the unit completely apart and attempted to use it with the covers off. Lo and behold, I found I could play a DVD on the unit without the unit powering off, but only if the room lights were on! If I tried to play a tape it would shut down the unit. So that led me to diagnosing the infrared loading and reel sensor circuits.
Background on that is there is an infrared LED that shines up through a plastic light pipe lens. The light from that LED (you can't see it) should shine on two photodiodes that are on either side of the tap mechanism, plus down through a gear with holes in it on to the reel sensor. When there is no tape inserted the two photodiodes will be illuminated and have about 0.2 volts across them. When a tape is installed the light will be blocked and the voltage goes up to above 2.5 volts across the diodes. You have to check this with the room lights dim as the diodes will respond to that light. When you block the light on either side of the plastic light pipe with your finger (with the unit disassembled) you should see the load motor engage, and it will back off when you take your finder away. For some reason in my unit the light from the LED was insufficient to turn on one of the diodes, and also to pulse the reel sensor when the gear turned. That could be due to component aging, or even if the light pipe started to cloud due to age, I don't know. However I was able to get the thing working...
In short I got the unit working by adding 3 resistors.
To do this you'll have to remove all the covers and remove the main PCB from the bottom chassis, unplug the power supply from the PCB, and the two ribbons going to the DVD unit. But you won't have to take off the VCR assembly, which is a pain. You just need some basic soldering skills, and remember where all those screws go...
First, I adjusted the voltage across the right-hand side load sensor diode to get the diode to switch on and off. I recall that I added 1meg across the diode. So the voltage then went from about 0.5v up to 2.8v from light to dark condition.
Second, I increased the current to the IR LED. I added a 330ohm resistor across the feeder to the LED. I recall that was R511 and was originally 220ohms. That was not quite sufficient to get the reel sensor working reliably. I didn't want to stress the LED by putting too much more current through it so looked for another idea.
Third I added 56k across the reel sensor diode to bring the voltage across it down so it would switch on and off as the reel sensor gear turned.
I now have a tape playing continuously in the unit and it seems ok for the time being. Hope that might work for you too.
Craig Townsend
Posted on May 26, 2009
  • 57 Answers
SOURCE: DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Posted on Jul 06, 2009
I need the universal remote control codes for it
There are four codes for Sanyo DVD players. They are 0670, 1967, 0873, 0695. Try these, if they don't work then something is wrong. But if the VCR side of your player works from the universal remote, the code is not the problem. It's a problem with the remote itself or the player. If the remote communicates with the player, whether it be the VCR or DVD, then the code you used is correct.
Dec 10, 2010 | Sanyo DVW-7200 DVD/VCR
Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
May 07, 2010 | Sylvania DVC840G DVD Player/VCR
Sansui DVD/VCR remote control issue, VCR works/DVD does not-black
There should be a DVD/VCR button on the remote control which will toggle the machine from one playback source to another. If she has pressed the VCR button then the machine will only playback tapes & not show DVD's. Press this button & the DVD's should play. If you look closely at the front window of the machine it will show what mode it is in ie VCR or DVD, set this for the DVD to get it to play.
Sep 16, 2009 | Sansui VRDVD4000 DVD Player/VCR
Can't see "Setup" screen, or any other screens on t.v. monitor
There should be a tv vcr button on the remote control. What you done was you accidently shut off the VCR function. If you hit that button again the tv vcr button it will come back on.
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Remote control doesn't work
The only thing that comes to mind is somehow the remote became unprogrammed. This happens with some factory remotes, if you reset the code for the remote it may start working again.
There are other times (both of these Ive had experience with) when the remote will just stop working due to a defect.
Post back for any further help, thank you for stopping by Fixya!
Jun 21, 2009 | Samsung DVD-V5500 DVD Player/VCR
MWD2205 remote stopped working for DVD functions
not sure but it sounds like you need to push the dvd button itself before dvd functions will work-it's to the left of the pause button. same thing happened to me and when i try that it works. remote seems to default to vcr i guess ....
Mar 23, 2009 | Philips MWD2205 DVD Player/VCR
Panasonic dvd/vcr DMR-EZ47V model.Code OOOOOO keeps going across.
You must manually hold in the on/off button on the machine itself (NOT on the remote) for approximately 30 seconds. This will shut the unit off. Then you can restart it.
Jan 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVD-V4600 DVD Player ... no remote
hi hallrmach
this might explain . some one posted the manual on fixya
Online User Manual and Guide for Samsung DVD-V4600 DVD Player / VCR Combo by FixYa, Page #1
riz.
Mar 22, 2008 | Samsung DVD-V4600 DVD Player/VCR
Remote Control
Go to http://www.remotes.com and get a new remote.
Sep 27, 2006 | LG XBR342 DVD Recorder / VCR Combo
Philips Magnavox DVD/VCR Dual Player Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
