Question about HP LaserJet 4350 Printer
How come in the setup wizard the option to set up locally is not highlighted''
Are you logged in as an "administrator". Perhaps you have multiple accounts on your PC with different privileges assigned to some off them. Only "administrators" can make changes like installing printers
Posted on Jun 15, 2009
I have comfortlink xl 1050. How do I disable the screen saver option, thank you
Page 12 of the manual suggests the following to set a screen saver. Whether you can set none, I couldn't tell:
Begin wizard From Home Screen, Press: MENU > SETTINGS > USER SETUP WIZARD
Select User Setup Wizard to begin.
Press NEXT and set your preferred display brightness, backlight, screen saver and color theme settings.
www.nexiahome.com/wp-content/uploads/2017/03/1050-Trane-User-Guide.pdf
Apr 02, 2018 | The Computers & Internet
I have bad dvd writer i want to diable from bios What do i have to do Laptop Make:dell Model: studio 1537 Os: vista ultimate
Access the BIOS Wizard:
Turn off your laptop. Wait 15 seconds, then press the power button to restart the system. When the computer starts to reboot, press "F2" repeatedly until you see the message "Entering Setup" displayed.
Change the BIOS Settings:
Scroll through the BIOS settings using your keyboard's arrow keys to highlight the setting you want to change. Press "Enter." Use the the arrow keys to highlight the option you want within that setting, then press "Enter."
Save changes in the BIOS Wizard:
Press "Esc," then choose "Save and Exit." Press "Enter" to exit the BIOS with your changes saved.
Note:
You can disable the DVD Writer in the Device Manager also.
Start > Type " Device Manager" and then Enter > Double Click " CD/DVD ROM Drives" > Double click on the Device > Click on the "Drivers" tab > click on "Disable" to disable the Hardware.
Have a nice day.
May 30, 2011 | Dell Studio 1537 Laptop
I want to connect to internet using this unit please help me
  • Figure 1
    The strongest local wireless network connection
    is displayed on the N95's Active standby screen. In this case the phone has found a network called 'mat'
  • Figure 2
    To search for more WLAN connections, click Options, highlight Search for WLAN and click Select
  • Figure 3
    To connect to a WLAN network, highlight its name and click Connect
  • Figure 4
    If the wireless network is security-protected, you'll need to enter its hexadecimal WEP key to log on
  • Figure 5
    You can also connect to a WLAN using the WLAN wizard. This can be found in the Tools are of the Main menu
  • Figure 6
    When opened, the WLAN wizard displays a list of the available local wireless networks. Highlight one and click Options to log on
Feb 28, 2011 | Nokia N95 Cellular Phone
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
The store demo mode is stuck on my insignia tv. the user guide says go to menu and then setup and select plug & play. however the plug and play option is grey and it wont let me select it.
Are you using an HDMI cable? Go to input and select TV. Then you should be able to access the Plug & Play option and be able to turn off the Demo Mode.
Jan 03, 2011 | Insignia 42" Flat-Panel Plasma HDTV
How setup internet settings
You'll need to complete all steps for this to work.
The phone has a 4-way directional 'Navi' key and 2 soft keys on either side of this. The Navi key can also be pressed in to select options.
1. Press the 'i' button (press navi key).
2. Highlight 'Browser' and press 'Select' (left softkey).
3. Highlight 'Browser settings' and press 'Select' (left softkey).
4. Press 'Options' (left softkey) , highlight 'Add new connection' and 'Select' (left softkey).
5. Highlight 'Profile Name' and enter 'giffgaff GPRS WAP'
6. Highlight 'Homepage URL' and enter 'http://giffgaff.com/mobile'.
7. Check that 'Proxy' is ticked (press Navi key to tick/untick).
8. Highlight 'IP Address' and enter '193.113.200.195'.
9. Highlight 'Port' and enter '8080'
10. Ignore 'Linger time' (this is preset at 90).
11. Check that 'DNS' is unticked (press Navi key to tick/untick).
12. Highlight 'Bearer' and select 'GPRS' by pressing the Navi key right or left.
13. Highlight 'Advanced settings' and select using center Navi key.
14. Highlight 'APN' and enter 'giffgaff.com'.
15. Highlight 'Login ID' and enter 'giffgaff'.
16. Highlight 'Password' and enter 'password'.
17. Press 'Save' twice (left softkey).
18. Highlight 'giffgaff GPRS WAP' and press 'Options' (left softkey)
19. Highlight 'Activate' and 'Select' (left softkey).
20. Press 'Back' (right softkey) 3 times to return to the main screen.
The GPRS WAP settings are now complete.
Dec 21, 2010 | Samsung SGH-J600 Cellular Phone
How to activate componenets input on beovision 7 TV
Disable the tuner first. Here are the steps:
To disable the internal tuner …
> Press TV to switch on the television.
> Press MENU to bring up the TV SETUP menu
and press to highlight OPTIONS.
> Press GO to bring up the OPTIONS menu, and
press to highlight TUNER SETUP.
> Press GO to bring up the TUNER SETUP menu,
TV TUNER is already highlighted.
> Press or to switch between the settings ON
or OFF.
> Press to highlight DVB.
or OFF.
> Press GO to store the settings, or …
> … press EXIT to leave all menus without storing.
May 05, 2010 | Televison & Video
DI 524 Connection Problem
Try the DSL modem directly connected to the PC.No D-Link Router (powered off and disconnected). Verify that the PC couldsurf/browse/connect to the Internet. Go to Start, Control Panel, Network Connections, right click Local Area Connection, Properties, scroll down to/highlight Internet Protocol (TCP/IP), Properties button. Get the IP Add, Subnet Mask,Default Gateway and DNS assigned to the PC (write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router. Go again to Start, Control Panel, Network Connections, right click Local AreaConnection, Properties, scroll down to/highlight Internet Protocol(TCP/IP), Properties button. Tick "Use the following IP address". Enter this IP Add 192.168.0.10, Subnet Mask 255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what you have written down earlier). This willbe your LAN IP settings. OK, close, save or whatever is applicable.
Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Use the IP numbers previously assigned to PC that you have writtendown as the router's WAN/Internet/Modem IP settings. OK, close, save or whatever is applicable. Rebootrouter. Connect DSL modem to router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Aug 02, 2008 | D-Link AirPlus DI-524 Wireless Router
The setup wizard on the CD will not automatically run when inserted in the CD-ROM drive, what do i do?
  1. click on start
  2. My computer
  3. right click on CD/DVD Drive
  4. Left click auto run
selecting My Computer, right-clicking the drive that contained the CD-ROM, and selecting Properties. click the AutoPlay tab and select the Select an action to perform option, then double-click the program to use to run the CD-ROM. This action launched the program on the CD-ROM. Note that simply highlighting the program you want to use and clicking OK or Apply doesn't work; you must double-click the program and force it to launch on the CD-ROM or DVD in the drive. The CD-ROM then ran automatically, using the program associated with it on the AutoPlay tab.
Apr 15, 2008 | Computers & Internet
HP LaserJet 4350 Printer Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
