Question about Microwave Ovens
I have Whirlpool amw 520 ix model and the Auto button is not working? I cant press the button
Only the auto button seems stuck
4 Suggested Answers
  • 8909 Answers
SOURCE: My built in 5 year
The display driver is faulty. A replacement display board may still be available. Try www.espares.co.uk or a Philips Microwave dealer.
Posted on Mar 09, 2011
  • 11800 Answers
SOURCE: How do I use my
The model number is just fine, it's AMW 502 ix.
Here you can find and buy the user manual - it has all you need in it
http://www.user-manuals.com/advanced_search_result.php?keywords=whirlpool%20amw%20520%20ix%20manual&forward=plist
Posted on Jun 02, 2011
SOURCE: I have a 2 month old whirlpool built in microwave, model no amw 498 ix. An alarm has just started sounding about every 10 minutes and the display shows code 'ERR2'. There is nothing about this in the
try to disconnect the electricity and remove any metal objects colse to it or mobile phones and reconnect it back again and see what happens.
Posted on Dec 03, 2012
What are matching models for Whirlpool Oven door model AKZ456/IX
As You may know, Whirlpool also builds Kenmore products, that being said, You would be far better off buying the exact model door for Your oven. The joy You may get from saving a "C" note on an alternative door option could turn into a Personal B*tt Kicking contest when You discover it almost worked, You CAN'T send it back and You still have to buy the right one. Best of Luck to You.
Aug 19, 2014 | Microwave Ovens
How many amps are required to install a whirlpool oven model AKP210/ix?
The specifications call for 2500 watt connections. The item is rated at 1100 watt hours. The amperage depends on what the voltage supplied is.
Jul 17, 2013 | Microwave Ovens
I can't open a microwave model AMW-20B
The actual door or the top/side covers?
Dec 13, 2012 | Microwave Ovens
Dec 03, 2012 | Microwave Ovens
I auto cleaned my oven the other day. I wiped it out with a damp cloth and later on that night went to turn it on and it would not heat up. The power turns on and the display seems to work normal and the...
Hi, Look at the home breaker box or fuse box to check for a tripped breaker or blown fuse. If your oven is not heating because there is no power, you may need to replace a fuse or reset a breaker. Also check the power outlet to confirm that the oven is plugged into the outlet securely.
Press the "START/ENTER" button to get the oven to heat after selecting your temperature, if you cannot get it to heat. If you do not press this button within five minutes of setting the temperature, the oven heating cycle will automatically be canceled and the oven control panel will return to displaying the sign.
Calibrate the temperature setting on the oven if it is not heating at a temperature that you like. Do this by holding down the "BAKE" button until the current calibration setting appears, which will be a temperature followed by "CAL." Use the up and down arrow button to increase the temperature and press the "START/ENTER" button once you are done. You can increase in five degree increments up to an additional 35 degrees.
Call the Whirlpool customer interaction center at 800-253-1301 if your troubleshooting fails to fix your heating problem. The customer service representative can give you contact details for a local service technician so that you can have the oven looked at by a professional.
Hope it helped
Aug 25, 2011 | Microwave Ovens
My built in 5 year old microwave AMW 520/IX display has gone wonky. Some of the LEDS stay on no matter what number should be showing.
Mar 09, 2011 | Microwave Ovens
Just moved into a new house, has a westinghouse electric oven, everything seems to be working but the oven itself. The timer is flashing and reads Auto down the side, pressing butting doesn't seem to help....
you have to reset oven to manual by holding down 2 buttons then reset time your user manual should explain the process if you still have it if not keep trying
Feb 01, 2010 | Microwave Ovens
Sharp R-9H56 Microwave convection oven
I have this model. Press clear then press Auto/Clock. Enter in the time eg 700 then press Auto/Clock again. The time should now be set
Jun 08, 2007 | Sharp R-1872 Convection/Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
