Question about iLO (2 GB) MP3 Player
HOW TO REMOVE WRITE PRTECTED OR AUTORUN.INF FILES
Hi everyone
i have a little problem with my 8g flash drive (apacer)
i can open it copy files from it but i cant delete files or format it and when i try doing that a message appears telling me (that the file or the drive is protected or locked)
and i need to format it very bad
so please help me A.S.A.P
  • 51 Answers
Removing write protection in pen drives is impossible..because tht is due to some hardware problemsi and no software can remove writ protection..anyway try this..logon to a linux machine(i prefer ubuntu )
and in terminal route to your drive and type sudo chmod-R 777/media/ and press enter..if one failes to delete files again..then throw away the pendrive.he heh..!!
Posted on Feb 09, 2010
Kingston datatraveler 8G shows write protection error, contain a virus outorun.inf, cannot save, cannot be formated and cannot delete. Please help.
1. Open Notepad and do not write anything in it. Just go to File > Save as (save it with the name: autorun.inf)
2. Copy the autorun.inf file that you have created in the above step and paste in your "Pen Drives"
3. Remove your pen drive.
After removing the pendrive, re-insert in your PC. Now your anti-virus will not detect any virus in your PC. And Your pendrive is 100% safe to use.
Jun 01, 2011 | Kingston Digital DataTraveler 4000 8 GB...
Whenever i used to insert chip drive with chip it is showing autorun.inf virus
How to remove autorun.inf in your flash drive or hard disk
Sometimes for virus or trojan horse you may difficulties opening your drives. Your autorun.inf is infected if you find any abnormal language when you right-click on a drive. This autorun.inf file is hidden and you will not see the file even though you select to show your all files from Folder Options.
1. Goto Start --> Run and type cmd then click OK.
2. If you want to remove the infected file from drive C: then type C: then press Enter.
3. Type "autorun.inf" and press Enter.
4. Type "del autorun.inf" then press Enter. The file is in the drive but not showing or you can't delete it now.
5. Now type "attrib autorun.inf -s -h -r" and press Enter.
6. Now delete the file by typing "del autorun.inf" and press Enter.
7. Restart the computer.
Good Luck!
Mar 02, 2011 | Computers & Internet
How to remove write protect on my usb flash drive
Maybe you are infected with a virus. Run CMD on rrun command or get to run the Windows Dos Prompt. Goto flash drive drive letter. Then type DIR/AH, this will show you list of hidden files in your flash drive usually if you get an autorun.inf you are infected with a virus. Type TYPE AUTORUN.INF with the space in between.This will show you the script if it will run an exe command usually untrusted one. Usually the autorun.inf and the linked exe is attributed to be hidden, system, and read only.
If the files in your flash drive is not so important you can try to delete the autorun.inf only. But you will gonna do this first. In its drive letter type ATTRIB -H -R -S AUTORUN.INF hit enter. Then type DEL AUTORUN.INF. trying to access the flash drive in windows screen you can get that something is cannot be found. But you could actually delete and load files into it. Or try to access the drive rightclicking it then select EXPLORE.
Hope this help. Post comments if this does not help.
May 31, 2009 | iLO (2 GB) MP3 Player
Autorun.inf doesn't open file in internet browser
Hello ksharp628,
I use a program called autorun.exe One limitation of the standard AutoRun facility is the fact that it will only run executable programs; it will not by itself open document files such as web pages or text files. AutoRun.exe is designed to circumvent this restriction: it will open any number of document files or start executable programs. Moreover, it is smart enough to use a sensible fall-back strategy if no documents can be opened, perhaps because the target system does not have the required support for those document types.
example of my autorun.inf
[autorun]
open=autorun.exe msn.html
action=Run MSN.com
icon=msn.ico
in root of thumb drive I have Autorun.exe Autorun.inf MSN.html and my ICON msn.ico wich i did a search for on my computer
I hade t make and msn.html
my edited msn.html file open in txt format
<meta HTTP-EQUIV="REFRESH" content="0; url=http://www.msn.com">
You can replace with what ever website you want and rename it to that.
This autrun.inf setup will popup the autrun box and ask you pick an option. this is as close to running the webpage when inserting the usb drive. The program comes with a .pdf on many options wich can be used with autorun.exe.
the link to the autrun.exe program is found below.
http://www.tarma.com/products/autorun/
Hope this helps you, take care.
May 05, 2009 | Dell Dimension 4600 PC Desktop
Usb flash drive icon changes into folder icon
This issue may have resulted from a virus infection on the machine the drive was plugged into.
You’ll need to delete the file autoruns.inf located on your flash drive.
By default, Windows hides this file, so before you can delete it you must make a couple of changes (you may reverse these after you’ve finished):
Open My Computer
Tools
Folder Options…
Click on the View tab
Under “Hidden files and folder” choose “Show hidden files and folders”
Remove the tick from “Hide protected operating system files (Recommended)
OK
Go back to My Computer and click on your flash drive. If you can’t open it that way, try right clicking on it and choose “Explore.”
Find the autoruns.inf file, right click on it and choose “Delete.” Confirm “Yes.”
Unplug and re-plug the drive in. You should be back to normal.
Hope that helps.
Feb 26, 2009 | LG KU250 Cellular Phone
Unable to delete the autorun.inf
hi azhar here form Karachi it is very easy. do, the below steps
reboot ur PC in safe mode with command prompt
when u bring a dos screen just move to ur drive mostly virus stayed in d: drive got d: drive and type
d:dir/ah and press enter
if u see there any auto run.inf file there also should be another file like .exe file or .bat or any kind of unknown , file so for delete the auto run file type attrib -s -h -r autorun.inf and press enter
then type del autorun.inf and hit enter here u go u have done.
do the samr process in all drives because mostly autorun.inf file make copy in all drives
remember autorun inf is just a file which help the virus to run autometicly
Feb 12, 2009 | Microsoft Windows XP Professional With...
iLO (2 GB) MP3 Player Logo
1,051 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
