Question about Sony VPL-ES4 Projector
MY SONY VPL-ES4 PROJECTOR WILL NOT START, LIGHT COVER FLASHES AND ON BUTTON IS RED.
WHEN PROJECTOR IS SWITCHED ON, THE ON BUTTON IS RED, LAMP COVER FLASHES AND FAN WONT WORK
SOURCE: vpl-es4 sony projector-frequency out of range
change the screen resolution to 600x800,and switch to other monitor by hitting fn+F6 key (Laptop).if the screen get black use alt+Ctrl+F3 to switch it on .
thanks
Hussam
Posted on Dec 15, 2008
  • 4234 Answers
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Posted on Apr 09, 2009
  • 4 Answers
SOURCE: HOW TO SOLVE FREQUENCY OUT OF RANGE IN SONY LCD
get a life u fool
Posted on Dec 24, 2009
AJIN G
  • 6694 Answers
SOURCE: Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Posted on Dec 20, 2010
Testimonial: "Thanks! And please tell me where is the lamp cover located."
  • 59 Answers
SOURCE: I have changed the lamp
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
Posted on Feb 24, 2011
My Sony VPL ES4 switches on quite Ok, but after some seconds the bulb goes off and a red light just blinks
Sony VPL-DX100 projector red light blinking first focus coming after 20 second focus off than red light blinking now how to solve this problem
Jun 23, 2015 | Sony VPL-ES4 Projector
Sony bravia vpl-aw10 lamp come on runs for 2-3 mins then switches of and lam p cover light flashes 3 time repetedly
Here is a link to the manual. It states you need to replace the lamp because it has reached it end of life an over heating.
https://docs.sony.com/release/VPLAW10.pdf
Jan 28, 2015 | Sony Bravia® VPL-AW10 Projector
I have a Sony projector VPL-ES4 and the ON / Standby red flashes 6 flashes. I got the lamp, I cleaned the air filter, I tried to reset Left Right Enter key and the problem still persists. Can you help?...
check a small bord under the mother bord calld air sensor
its look`s like a transistor check the divice properly and change the projector frimware through computer
Aug 16, 2012 | Sony VPL-ES4 Projector
I have a sony SVGA VPL-ES4, when i turn it on it comes on only for a little while then goes off and the power button has this continuos blinking red button. HELP please..
hi,
Do one thing try to reset the lamp hour timer. for the same do the following.
Press the following keys on the remote in the following order for less than 5 seconds each.( on standby mode)
RESET then LEFT ARROW then RIGHT ARROW then ENTER
Remember on thing lamp reset is recommended only after replacing the lamp. if works try to replace the lamp as soon as possible.
ok
Apr 28, 2011 | Sony VPL-ES4 Projector
Blinking yellow light for lamp cover and will not start up
check that the lamp cover is not bent up slightly due to old age, and the little switch underneath is activated when the cover is installed
Mar 26, 2011 | Sony VPL-ES4 Projector
I have changed the lamp in a Sony VPL EX-1. I have fitted a YODN (LMP - C150) I cannot get the flashing light to go out which indicates `lamp,cover` and I cannot do anything with the projector.
Feb 22, 2011 | Sony VPL-EX1 Multimedia Projector
When you plug in power it indicates red but does not start the projection. The only thing i get is an orange brink from the point written lamp cover
make sure the lamp door is closed securely. if the door doesn't/ can't trigget the door switch, you'll need to replace the door, or the switch.
Dec 28, 2009 | Sony VPL-ES4 Projector
Focus Problem
the lamp of the device may be going to end its life, need replacement.
Jan 02, 2009 | Sony VPL-ES4 Projector
Sony VPL-ES4 Projector Logo
27 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
