Question about Craftsman 5600 watt Generator
White smoke Generator starts well but then becomes sluggish and produces large claods of white smoke. Any ideas?
    Sergeant:
  • 415 Answers
You are getting oil into the cylinders. Possibly bad seals on the valves or bad rings on the pistons.
Posted on Apr 03, 2014
My generator is smoking white smoke and almost dies out. had to shut off because of so much smoke. starts fine then within seconds starts acting up
if its squealing or making noise then the bushings inside the generator are bad. if not the windings inside the generator are not working properly. sounds like the generator is bad.
Apr 24, 2016 | Cars & Trucks
I changed the turbo now white smoke coming out of my exhaust
This seems to be a symptom of a blown head gasket.
White exhaust smoke is an indication of water / coolant in the exhaust. The car running sluggish and using lots of fuel can be caused by compression loss.
Look at the coolant level color and smell (with cold engine - don't open the high pressure reservoir with engine hot as hot coolant may spray you in the face). If you have a blown gasket, the coolant color may become brownish and it may smell bad or the level will get lower even if you have just refilled the cooling system.
What you can also check for is bubbles in the reservoir. With engine cold, remove the reservoir cap. Start the engine. Try to rev the engine (or have someone do it) and observe if there are bubbles in the reservoir tank. If you see lots of bubbles, you have a blown gasket.
Dec 05, 2013 | 2001 Oldsmobile Intrigue
Craftsman 5600 watt generator won't stay on and white smoke pours out when started.
try running it with nothing hooked up if it runs fine, then the power draw is to much for it that would cause it to hunt !!!
Jan 30, 2013 | Craftsman 5600 watt Generator
42" MTD riding mower. Won't start. Had a tough
White smoke or semi white can be produced in several ways. One way is oil this is normally a whitish blue to blue smoke and has the apparent smell of oil being burned.
Read more: http://wiki.answers.com/Q/What_can_cause_white_smoke_from_the_exhaust#ixzz1ZTQwS4Al Hope this helps
Sep 30, 2011 | Mtd Garden
I have a 2.4kva generator, but some few days back it produces white smoke from the exhaust on start up which stops after 5 minutes. I don't know the cause of the problem and how to resolve it.
White smoke means you burn oil.
You need to have it fixed, the springs need replaced. Most likely it run too hot. If the cylinder is scratched then repair is more expesive than replacement,
good luck
rene
May 27, 2011 | Champion 2.4 HP Gasoline Generator
My daughter's 2003 Oldsmobile Alero was blowing white smoke from exhaust. She said that it was a bit sluggish when accelerating. I started it when I got home this evening and it blew white exhaust so I hit...
white smoke is normaly an indication of water entering the combustion chamber of your engine due to a broken head gasket. I am surprised that it stoped but I think that the probelm will come back.
Oct 12, 2010 | Oldsmobile Alero Cars & Trucks
Heap of white smoke on startup but not always
White smoke usually occurs when there is not enough heat to burn the fuel. The unburned fuel particles go out the tailpipe and typically produce a rich fuel smell. It's not unusual to see white smoke in the exhaust during cold weather until the engine warms up.
Faulty glow plugs or control module can cause white smoke on engine start up.
Low engine cranking speed may also produce white smoke.
If white smoke is still visible after the engine has warmed up, the engine may have one or more bad injectors, retarded injection timing or a worn injection pump.
Low compression or air in the fuel system can also be a source of white smoke.
May 20, 2009 | 1992 Daihatsu Charade
I have a 1992 honda prelude. During a hard acceleration, the car fails to accelerate. Instead, it produces rough sound as if it is not getting a consistant amount of fuel. Slow acceleration is OK. Also...
Check for free play on distrubtor.
If you has a known good disturbutor then do the swap.
===== Lite white smoke during warm up is OK.
If the white smoke is still noticable after 15 minutes of start up then you should start monitor the coolant level and oil level.
If the temp. is raising then it can be stage one of blown headgasket.
Keep track of the temp. and make sure the oil is not getting a white/creamy texture.
DO NOT drive it if it's overheating.
Apr 09, 2009 | 1992 Honda Prelude
Large amount of white smoke on first start of the day
Have you had the injector recall check carried out? There is a problem with these injectors and this produces the symptoms you are describing. I suggest that you contact Isuzu direct for help. They have been very helpful in the case of my trooper
Nov 12, 2008 | 1999 Isuzu Trooper
Craftsman 5600 watt Generator Logo
193 people viewed this question
Top Craftsman Electrical Supplies Experts
BJ Russell
wadingriver
wadingriver
Chuck Graybill
Are you a Craftsman Electrical Supply Expert? Answer questions, earn points and help others
