Question about Kids II Bright Starts Comfort & Harmony Baby Bouncer - Blue
Bright starts comfort and harmony bouncer backrest tube
Bouncer back rest tube broken
How do I Bend forward the back of the rear seats of a Nissan Pulsar 2014 to put the seat covers on?
Do not bend the rear seat back rests, they will never be the same again. On most (if not all) cars the rear backrests are bolted on by means of two bolts behind the seat, so first remove the seat (the bottom padding that keeps your backside from hitting the floor) by pulling the seat up. On some vehicles, the seat is bolted down with two 6mm bolts on either side. Once you have the seat out, you should see two bolts holding the back rest to the body of the car. Undo these, and the backrest comes off easily.
Now fit the seat covers and bolt the backrest back into place. It is not a difficult job, shouldn't take more than an hour or less.
Dec 14, 2014 | Nissan Cars & Trucks
I have a 2001 Chevy Tahoe. When I try to fold the
One of the cables that control the release is broken right where it hooks to the seat,, the cable has a loop made in from factory it wears threw there,,, this is just one of the causes but the most common,,, also could be bottle cap or small piece of something making it hang up,, hope this helps
Oct 10, 2014 | 2001 Chevrolet Tahoe
Comfort harmony swing wont swing
Is your swing still under guarantee? If so, you should take it back to the shop where you bought it or contact the manufacturer directly. When my baby swing broke, I took it to the local handyman and he was able to fix it for a very reasonable price. Good luck.
Feb 26, 2013 | Bright Starts Comfort & Harmony Duck...
Hi i am wondering how exactly to put on a passenger backrest on my 2008 boulivard c90
Well it depends on the model of back rest. But most have mounting screws that connect the back rest around the back fender under the back seat.
Regards,
GGrinds@clubsuzuki.org
Mar 19, 2011 | 2005 Suzuki Boulevard C90
Does anyone know of a drivers backrest for the dx
I doubt seriously if you're going to find a drivers back rest for your V-rod. The reason is the back rest is cnsidered to be a "touring" accessory and the V-rod is not generally considered to be a touring motorcycle.
I'd do a search online for "motorcycle seats" and see what comes up. Try Mustang Motorcycle Seats. They have good quality seats and reasonable prices. They also have the drivers backrest for a lot of their seats. If they offer a seat for the V-rod, maybe drop them an e-mail and ask about it.
Good Luck
Steve
Dec 22, 2010 | 2008 Harley Davidson VRSCDX Night Rod...
Red/ Bright Tint/Color on Sylvania SRCD227
Your Logitech Harmony 550 is able to learn commands that are not included in its command database.
To teach your Harmony 550 a new button follow these steps:
  1. Connect your Harmony remote to your computer to start the Harmony remote control software.
  2. Click Devices.
  3. Click a device.
  4. Select Learn Infrared Commands.
  5. Click Next.
I hope that helps.
___________________________________
Harmony 550 Manual Download
Logitech Harmony Firmware Update
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Feb 11, 2010 | Sylvania SRCD227 27 in. TV/DVD Combo
How to remove backseat backrest to change seat cover from 05 f150
u have to start by taking the bottoms out. then the back there should be two bolt to take out and it slides up and pulls off
Jun 15, 2009 | 2005 Ford F-150
Middel seatbelt will not loosen
I think you have to remove headrst bfore folding seat back down. You may have to unbolt seat from floor. 4 bolts.
Rear Seat Backrest —Split Bench Removal
NOTE: The 40% rear seat backrest must be removed before the 60% rear seat backrest.
  1. Remove the 40% rear seat backrest.
    1. Remove the nuts and bolts.
    1. Remove the backrest.
  1. Remove the 60% rear seat backrest.
    1. Remove the nut and bolt.
Installation
NOTE: The 60% rear seat backrest must be installed before the 40% rear seat backrest.
  1. NOTE: Do not tighten the nut and bolt at this time.
    Install the 60% rear seat backrest.
    1. Install the rear seat backrest.
    1. Install the nut and bolt.
  1. NOTE: Do not tighten the nuts and bolts at this time.
    Install the 40% rear seat backrest.
    1. Install the nuts and bolts.
60/40% rear seat backrest
  1. Tighten the 60/40% rear seat backrest nuts and bolts in the sequence shown.
40% Rear Seat Backrest
  1. Tighten the 40% rear seat backrest nuts and bolts in the sequence shown.
Jun 11, 2009 | 2005 Ford Escape
Kids II Bright Starts Comfort & Harmony Baby Bouncer - Blue Logo
479 people viewed this question
Top Kids II Baby Gear Experts
Dorel UK
Dorel UK
Are you a Kids II Baby Gear Expert? Answer questions, earn points and help others
