Waher fills then shuts down. no ash no spin no drain
  • 29 Answers
Sounds like the belt or the motor.
Posted on Jun 15, 2009
Washer filled with water...will not agitate or spin or drain
You may have a bad or broken lid switch.The waher is thinking that the lid is open.
May 02, 2011 | Washing Machines
GE front load waher Model #: WSSH300GWW fills and agitates, but does not spin and drain.
take drain hose and lay it in a bucket to drain water or a wet vac works better. remove 2 scews from lower pannel it will drop down and come off. look for a accordian shaped black hose. disconnect it and remove junk in it. check inside the pump inlet for stuff it's the thing one end of the funny hose is hooked to. put back together and don't over tighten clamps nut driver tight is fine.
Feb 17, 2010 | GE Washing Machines
I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
Oct 19, 2009 | Asko Washing Machines
Water continues to fill after it should have
first does it over flow.if not pull your drain hose up from the drain till it is aleast the same level as the back of the waher control panel.
If the Drain hose is to far down in the pipe this will cause the water to drain out by gravity.the other least likely problem is a bad fill pressure switch.
Sep 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Waher won't spin
Either a bad lid switch or a bad direct drive coupling or a bad timer.
Fill the machine with water. In the wash mode observe the agitator. Is it moving back and forth? If no, replace the direct drive coupling.
If yes, it does move back and forth, with the lid closed, advance the timer to the spin cycle. If it does not spin, raise the lid then close the lid. Does it spin? If yes, replace the timer.If no, replace the lid switch..
Apr 08, 2009 | Kenmore Washing Machines
Waher fills up and empties at the same time
you definalty have a drain hose issue, id bet that either your drain hose is lower the nte hunit itself or even connected to and outside drain sorce with out any "air gap/brake" i the drain line.. your creating a siphon action, you drain line should drain into a stand pipe no lower the n the back of the units console
Feb 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine will not spin
If this is a Whirlpool washer, you have a broken motor coupler
Jan 23, 2009 | Washing Machines
Whirlpool Waher not working
does it make a humming noise if so there might be something in your pump
Dec 19, 2008 | Whirlpool Washing Machines
My Admiral waher model # LNC6762B71 will not spin or drain
with the belt off the pump pulley should turn freeley if it does then with the belt off and in the spin position start the washer with the lid down the motor should run
it it does then you have a transmission problem
if the motor does not run then there is a electrial componet problem
May 17, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
