Question about Hozelock 2490 Auto Reel 20m Hose 12.5mm
Just installed new auto reel 2490 lock disenged , when you pull out hose 2 metres four clicks and then will not pull out anymore
Out hose 2 metres hear four clicks ,then unable to pull out anymore.
Pope hose reel jams whilst extracting and on return,also very hard to pull out hose
The spring unit either needs replacing or lubricating.
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 07, 2017 | Vacuums
My hozelock auto reel has stopped locking. Have tried pulling it all the way out and then releasing but it does not solve the problem.
40 meter Hozelock auto reel would not lock when winding back into the drum.
1, Make sure the Hozelock hose has fully retracted into the drum.there should be no tension on the hose reel spring.
2, Use a Black & Decker Workmate.
3, Carefully opened the side cover taking out all of the Torx screws (10 in total) remove handle.
4, Turned the reel over and placed the auto reel onto the Black & Decker Workmate.
5, Placed a socket into the Workmate vice then line up the centre shaft bolt on the auto reel onto the socket, this will hold the steel spring in place so that I could undo the 2 security Torx screws. Slowly remove the 2 screws- there will be a little spring tension when removing the 2 screws, take care.
6, Lever up the centre shaft up out of the reel to expose the internal hose reel, take note the rotation of the plastic cog inside the cover.
7, Remove the brake locking arm from the side cover.
the arm had broken in half, I used a soldering iron to weld the two halves of the brake lever back together.
8, Rebuild in reverse order.
8, When rebuilding the auto reel use the ratchet and socket to tension the steel spring, I unwound the hose out of the drum then slowly wound the spring using the ratchet and socket. This wound in the hose onto the drum up to the hose stop then a couple more turns on the ratchet for a little more tension.
9, Whilst holding the ratchet keeping the tension on the spring. Replace the 2 security screws on the centre shaft .
10, This link on Youtube I found very helpful (46 sec into video) you can see the internal working and the brake lever.
Apr 24, 2015 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
Auto reel will not rewind anymore
then you will have to repair it the spring has no doubt broke
Mar 22, 2015 | Garden
How can I fix a hozelock hose reel that has been pulled out too much and jammed?
you have to take the cover off and redo the hose you can re reel back in
Jul 19, 2014 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
How can i fix a leak inside my hozelock auto reel
adcccc13-7653-4a1a-83fe-508669c9a82e.jpg3187e97b-8b8e-4ed3-a2a0-0cad5211d982.jpg94e5325e-ed0d-4067-ba2e-15c982ded717.jpg350c6d53-8941-4e5f-937d-9425b18f4c89.jpgb9a1ffa9-99fa-4f32-9be1-717dd9251c09.jpg961cd592-0df3-420b-b7df-1b0ff17df252.jpg79809fc2-3e1f-4099-a3c7-00615892aa40.jpgd539f880-39af-40f4-850d-ad70e7f5948f.jpg7ce9923d-118a-4f30-9f13-20afc72d3ee9.jpg6d0fe000-779a-4d41-b1cc-81a243223d36.jpg2123ca49-4e92-4d43-a6cb-d6dab2644c3d.jpg9bcb85f0-f600-42e0-a249-d54524038b72.jpgea7bcfd2-840a-4496-a010-53e4229d922a.jpg6b9a17a9-5cc9-4ef8-8b28-3ddaee1a2172.jpgf3a3c78c-6856-4c78-bf68-90484825b7a0.jpgJust replace the O-rings inside. See pictures how to take it apart.
Jun 01, 2012 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
Lost return tension when replacing hose
Where can I get a replacement tension spring for my auto reel hoselock 2490 ? I have tried everywhere but without success. Any help is much appreciated
Mar 19, 2012 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
How to Replace New Hose at Auto-Reel 2490. Please let us know, we have 5 sets to be replace. Thank You and Best Regards, Neo Aik Kheng Novomatrix Pte. Ltd. Singapore Mobile 65 - 9641 5921
The auto reel is guaranteed for 2 yrs against faults arising from defective manufacture or materials. the hose is guaranteed for 15 yearsaginst defective manufacture or materials. all that is needed is the purchase reciept. if this is available with you you can contact hoselock cunsumer care.
as an added advantage here is the download link with instructions for assembly,installation, use and maintenance with diagrams in pdf format hope this helps http://www.hozelock.com/uploads/pdf/instructions/watering%20instructions/2490%20Auto%20Reel%20instructions.pdf
Thanks for using fixya
Oct 04, 2010 | Computers & Internet
Ratchet/click stops do not work,but spring still reels in,no rust or dents in any part
catch pawl in the reel is shot. I used to work in places where this happened. The only solution is tie the hose off on to a stationary object.
The only other solution is replace the reel..
May 10, 2009 | Toolshopusa Retractable 25' Air Hose
Auto-stop malfunction and stuck cassette door
Hi I'm not familiar with your particular model, but the auto stop problem is common and is usually the result of a slipping drive belt, or bad idler/reel drive. The auto-stop works by popping a small tooth like plastic or nylon piece attached to an arm, when you runout of tape and takeup reel pulls the tape tight. The auto-stop mech can get contaminated with dust, and not work, or the reel for some reason does not pull the tape tight enough to fully engage that piece and the result is a ticking sound. As the deck now has your tape, I suspect the main drive belt is broken or probably slipping, and all will work fine if it is replaced. Although changing the belt is not difficult, you should probably take it to a repair shop, as getting the right size is important, and the deck may have to be dismantled to change it. Hope this helps, good luck!
Apr 28, 2007 | Sony PSYC ZS-D55 Cassette/CD Boombox
Hozelock 2490 Auto Reel 20m Hose 12.5mm Logo
52 people viewed this question
Top Hozelock Garden Experts
richie46
J Walsh
Level 1 Expert
Bill Boyd
Are you a Hozelock Garden Expert? Answer questions, earn points and help others
