Question about Homelite Garden
Black and Decker GK1640T Worked well then after topping up oil (too much) motor works but chain does not engage
With chain removed the sprocket rotates but with the chain fitted it does not engage.
  • Homelite Master
  • 9,587 Answers
Clean the clutch or replace it if it has a lot of oil on it.
Posted on Dec 05, 2014
  • 24 Answers
SOURCE: poulan 2600 chainsaw
check and make sure you have the correct sprocket.is your chain .325,3/8?sprocket has to match as well as chain and bar
Posted on Oct 20, 2008
  • 226 Answers
SOURCE: Poulon Pro 16-inch 38cc no longer auto feeds chain oil.
Try using carb cleaner or WD40. I hope that you removed the oil cap and oil before you tried... hope this helps, rick
Posted on Apr 17, 2009
  • 188 Answers
SOURCE: Craftsman 16 inch cain saw sprocket wont turn
Sounds like the sprocket could be stripped. If so, then you would need to replace the sproket. I suggest you contact Master Parts at 800-466-1446 or online at www.masterparts.net. They may be able to help you.
Posted on Jul 01, 2009
  • 4088 Answers
SOURCE: Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Posted on Jul 08, 2009
dontbother10
  • 2220 Answers
SOURCE: CHAIN SAW QUITS CUTTING AS IT HITS WOOD.
The make, model, and occationally the serial number help us solve your problem.
Does the engine quit running? (Carburator needs adjustment)
Or does it continue running and chain stops? (need clutch refaced or replaced.) (to aggressive a chain for the size of the engine)
I think you replaced parts unnecessarily. Maybe quicker and cheaper to visit your friendly neighborhood chainsaw shop. A good one can repair it even if they do not sell your brand.
HTH
Lou
Posted on Sep 09, 2009
I require a circuit diagram how to set my polo vivo 1.4 16v timing chain
THESE ARE THE TOOLS U NEED TO HAVE AND PROCEDURE!!GOOD LUCK AND BEWARE THE TIMING..REPLACE BOTH CHAIN AND TENTIONER!!!!!!
Special tools and workshop equipment required
t Dial gauge -VAS 6079-
t Puller -T10094 A-
t Dial gauge adapter -T10170-
t Camshaft clamp -T10171-
t Counterhold tool -T10172-
t Locking pin -T40011-
t Spark plug spanner -3122 B-
t Counterhold tool -3415-
t Torque wrench (5...50 Nm) -V.A.G 1331-
Procedure
- Remove valve timing housing > Chapter.
- To turn crankshaft, reinstall bearing bush, crankshaft pulley -2- and crankshaft bolt -3- and securely tighten crankshaft bolt (use counterhold 3415).
- Remove spark plug from No. 1 cylinder. Use puller -T10094 A- and spark plug wrench 3122 B.
- Screw dial gauge adapter -T10170- into spark plug hole to stop.
- Screw dial gauge -VAS 6079- and extension -T10170/1- in to stop and lock in position with lock nut -arrow-.
- Turn crankshaft in direction of engine rotation, to TDC No. 1 cylinder. Note position of small needle on dial gauge.
- Then turn crankshaft back 45° opposite direction of engine rotation.
- Press tensioning guide rail -1- in direction of arrow and lock piston with locking pin -T40011-.
- Mark direction of rotation of timing chain -3- using felt-tip marker.
- Remove bolts -2- and remove camshaft sprocket -1- with timing chain -3-. Counterhold using counterhold tool -T10172-.
- Renew bolts -2-. Tighten bolt -2- to 50 Nm (use counterhold -T10172-).
- Turn inlet and exhaust camshafts until camshaft clamp -T10171- can be pushed into holes in camshaft to stop.
Locking pins -arrows 1- must engage in holes -arrows 2-. Inscription "TOP"-arrow 3- must be readable from above.
Note
Camshafts must not be pushed axially whilst turning.
- Install a M6 bolt -arrow- hand-tight (do not tighten) to secure camshaft clamp -T10171-.
- Remove camshaft sprocket bolts. It is absolutely necessary to use counterhold tool -T10172- for this.
Note
Camshaft clamp -T10171- must not be used as a counterhold tool.
- Remove one camshaft sprocket.
- Place timing chain over camshaft sprockets, observing chain direction of rotation, and install camshaft sprocket again.
- Tighten camshaft bolts until camshaft sprockets can still just be turned on camshafts.
- Tension timing chain by removing locking pin -T40011-.
- Turn crankshaft in engine direction of rotation to TDC No. 1 cylinder. Permissible deviation from TDC No. 1 cylinder: ±0.01 mm.
Note
If crankshaft is turned more than 0.01 mm past TDC, then turn crankshaft back 45° against engine direction of rotation. Then turn crankshaft in direction of engine rotation to TDC No. 1 cylinder.
- Hold camshaft sprockets -1- and -4- in this position with counterhold -T10172- then tighten bolts -2- to 50 Nm.
Note
Crankshaft must not move and timing chain -3- must remain tensioned on both sides when tightening camshaft bolts.
- Remove camshaft clamp -T10171-.
- Turn crankshaft two rotations in direction of engine rotation to TDC No. 1 cylinder. Permissible deviation from TDC No. 1 cylinder: ±0.01 mm.
- Insert camshaft clamp -T10171- to stop in camshaft openings.
If camshaft clamp -T10171- cannot be fitted
- Repeat adjustment.
If camshaft clamp -T10171- can be fitted
- Remove camshaft clamp -T10171-, hold camshaft sprockets with counterhold tool -T10172- and tighten bolts -2- a 1/4 turn (90°) further with a rigid wrench.
Note
Camshaft sprockets must not move on camshaft whilst tightening.
- Turn crankshaft two rotations again, in engine direction of rotation, to TDC No. 1 cylinder. Permissible deviation from TDC No. 1 cylinder: ±0.01 mm.
Further assembly is basically the reverse of the dismantling procedure. In the process, note the following:
t Installing valve timing housing > Chapter.
t Installing poly V-belt > Chapter.
t Renew oil seals for camshaft sealing cover and oil them before fitting.
Mar 06, 2015 | 2010 Volkswagen Polo 1.4
How to remove sprocket and clutch from ms250 stihl chainsaw
Removal>
  1. Remove the clutch drum/chain sprocket
  2. Remove the air filter
  3. Take out the shutter.
  4. Pull boot off the spark plug.
  5. Unscrew the spark plug.
  6. Close the decompression valve, if fitted.
  7. Push the locking strip 0000 893 5903 into the cylinder. (Piston Stop)
  8. Unscrew the clutch from the crankshaft clockwise (left-hand thread).
Installation>
  1. Screw on the clutch and tighten down to 50 Nm (37 lb.ft).
  2. Install the clutch drum / chain sprocket .
  3. Remove locking strip from the cylinder.
  4. Insert spark plug and tighten down to 25 Nm (18.5 lb.ft).
  5. Fit boot on the spark plug.
  6. Fit the shutter so that its lugs engage the recesses in the handle housing.
  7. Install the air filter
Feb 22, 2015 | Garden
How do i set camshafts on 1999 duvil northstar
Remove camshaft covrs
Remove front cover
Remove or fully retract all three timing chain tensioners
Remove oil pump
Primary and secondary chain guides should remain in place. Rotate crankshaft until sprocket drive key is at about 1 o'clock position.
Set crankshaft and intermediate shaft sprockets into primary drive chain with their timing marks asjacent to each other.
Install crankshaft and intermediate sprockets over their respective shafts. Rotating crankshaft as necessary to engage crankshaft key in sprocket without changing the timing mark relationship.
Install Flywheel Holder Tool (J-39411) to lock crankshaft in position. Install intermediate shaft sprocket retaining bolt and torque to specifications.
Route secondary chain for left cylinder head over inner row of intermediate shaft teeth.
Route secondary drive chain over chain guide, and install exhaust cam sprocket to chain so camshaft drive pin engages the sprocket notch marked "LE" (Left Exhaust).
There dhould be no slack in the lower section of the chain, and the camshaft drive pin must be perpendicular (90 degrees) to the cylinder head surface.
Install the intake camshaft sprocket into the chain so the sprocket notch marked "LI" (Left Intake) engages camshaft drive pin, while drive pin remains perpendicular to the head face. Minor adjustments can be made to camshaft position to get pin to engage by using a wrench on the hex cast into the camshaft.
Install sprocket retainer bolts and torque to specification.
Repet steps as above to install the right secondary chain to the right camshafts. The right camshaft sprockets are marked "RE" and "RI". In addition, the RE sprocket must contain the camshaft position sensor pickup.
May 27, 2012 | 2000 Cadillac DeVille
Tryed to put on a chain cant get it back togather right
Completely loosen the chain tensioner. When looking at the saw from the sprocket side(bar to the right) the chain WILL travel clockwise. Fit the chain on the bar.(ensure that the chain travels in collation with the sprocket at the end of the bar if equipped). When looking at the saw from the sprocket side(bar to the right) the chain WILL travel clockwise. With the chain still in the bar, fit the 5 or so links in the sprocket on the powerhead, engage the bar with the bar nuts, then lastly engage the chain in the tensioner. Place the sprocket cover and nuts. Tighten nuts then loosen about .5 turn. Adjust chain tensioner. Retighten nuts. See that tightening the nuts made your chain tighter, loosen nuts readjust chain, tighten nuts. With gloves on and the chain brake disengaged please ensure the chain travels around the bar. Put on your chaps and start cutting.
Sep 11, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Chain does not rotate around bar. Chain brake seems to engage/disengage as intended.
With a gloved hand can you manually pull the chain around the bar? if not the chainbrake is still engaged, pull the hand guard fully back to the top handle until you hear the click from the brake mechanism, if the chain does pull around manually then there is a problem with either the cluch or the sprocket, remove the side cover, check the clutch for damage, remove the drive sprocket and check the drive teath are not badly worn allowing the chain to slip within it, replace parts as required.
Jan 21, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Timing belt is broken is a belt or chain
chain. R&R instructions from autozone.com pasted below. let me know if you have any more questions.
REMOVAL & INSTALLATION
SOHC Engine See Figures 1, 2, 3 and 4
  1. Disconnect the negative battery cable.
  2. Remove the timing chain front cover.
During timing chain and sprocket removal, position the crankshaft 90 degrees past Top Dead Center (TDC), to make sure the pistons will not contact the valves upon assembly.
  1. Carefully rotate the crankshaft clockwise so the timing mark on the crankshaft sprocket and keyway align with the main bearing cap split line (90 degrees past TDC).
  2. Remove bolts, then remove the timing guides and tensioner.
  3. Remove the camshaft sprocket bolt, using a 7 / 8 in. (21mm) wrench to hold the camshaft. Then remove the timing chain and camshaft sprocket. Remove the crankshaft sprocket, if necessary.
To install:
  1. Inspect the chain for wear and damage. Check the inside diameter of the chain, it should be no more than 16.77 in. (426mm). Inspect the chain guides for wear or cracks and the timing sprockets for teeth or key wear. Replace components as necessary.
  2. Verify that the crankshaft is positioned 90 degrees clockwise past TDC from the keyway (keyway at 3 o'clock).
  3. Bring the camshaft up to No. 1 TDC by loosely installing the sprocket and rotating the sprocket until the timing pin can be inserted. The camshaft contains wrench flats to assist in turning the shaft. The dowel pin should be at 12 o'clock when the camshaft is at TDC and a timing pin ( 3 / 16 in. drill bit) should then install at about the 8 o'clock position.
  4. If removed, install the crankshaft sprocket, then rotate the crankshaft counterclockwise 90 degrees up to No. 1 TDC (keyway at 12 o'clock).
  5. Position the chain under the crankshaft sprocket and over the camshaft sprocket. If necessary remove the camshaft sprocket, then slide the camshaft sprocket into position with the chain already engaged. The timing chain should be positioned so that one silver link plate aligns with the reference mark on the camshaft sprocket and the other aligns with the downward tooth (at the 6 o'clock position) on the crankshaft sprocket. The letters FRT on the camshaft sprocket must face forward, away from the cylinder head and excess chain slack should be located on the tensioner side of the block.
  6. Temporarily install the timing pin to verify proper alignment of the camshaft and sprocket, then install and tighten the sprocket bolt to 75 ft. lbs. (102 Nm). Again, use a wrench on the camshaft flats to hold the shaft in position while tightening the bolt. Do not allow the camshaft retaining bolt to torque against the timing pin or cylinder head damage will result.
  7. Install the chain guides with the words FRONT facing out. Install the fixed guide first and verify the chain is snug against the guide, then install the pivot guide. Tighten the bolts to 19 ft. lbs. (26 Nm) and verify that the pivot guide moves freely.
  8. Retract the tensioner plunger and pin the ratchet lever using a 1 / 8 in. No. 31 drill bit inserted in the alignment hole at the bottom front of the component. Install the tensioner and tighten the bolts to 14 ft. lbs. (19 Nm), then remove the drill bit.
  9. Make one final check to verify all components are properly timed, then remove all timing pins.
  10. Install the timing chain front cover.
  11. Connect the negative battery cable, start the engine and check for leaks.
Fig. Fig. 1: At 90 degrees past TDC, the crankshaft sprocket timing mark and keyway will align with the main bearing cap split line
Fig. Fig. 2: Exploded view of the timing chain and sprocket assembly-SOHC engine
Fig. Fig. 3: Insert the timing pin to ensure that the camshaft is at No. 1 TDC-SOHC engine
Fig. Fig. 4: When the camshaft is at TDC, rotate the crankshaft counterclockwise 90 degrees to achieve TDC
Nov 02, 2010 | 1997 Saturn SL
How do i reset the timing in a 1997 z24 Chevrolet Cavalier 2.4 twin cam? Where are the timing marks on the cam gears?
2.3L and 2.4L Engines Before attempting to remove the timing chain, read the entire procedure.
  2. Remove the timing chain front cover, as outlined earlier in this section.
  3. Rotate the crankshaft clockwise, as viewed from the front of engine/normal rotation, until the camshaft sprocket timing dowel pin holes line up with the holes in the timing chain housing. The crankshaft sprocket keyway should point upwards and line up with the centerline of the cylinder bores. This is the "timed'' position. Fig. 8: The chain must be in the "timed'' position - 2.3L and 2.4L engines 87953108.gif
    Fig. 9: Remove the timing chain guides 87953109.gif
  4. Remove the timing chain guides.
  5. Raise and safely support the vehicle.
  6. Make sure all of the slack in the timing chain is above the tensioner assembly, then remove the tensioner. The timing chain must be disengaged from any wear grooves in the tensioner shoe in order to remove the shoe. Slide a suitable prytool under the timing chain while pulling the shoe outward. WARNING
    Do NOT attempt to pry the socket off the camshaft or damage to the sprocket or chain housing could occur.
  7. If difficulty is encountered in removing the chain tensioner shoe, remove the intake camshaft sprocket, as follows;
    1. Carefully lower the vehicle.
    2. Hold the intake camshaft sprocket with a suitable tool and remove the sprocket bolt and washer.
    3. Remove the washer from the bolt and rethread the bolt back into the camshaft by hand. The bolt provides a surface to push against.
    4. Remove the camshaft sprocket using a three-jaw puller in the three relief holes in the sprocket.
  8. Unfasten the tensioner assembly retaining bolts, then remove the tensioner. NOTE: The timing chain and crankshaft sprocket MUST be marked before removal. If the chain or sprocket is installed with the wear pattern in the opposite direction, noise and increased wear may occur.
  9. Mark the crankshaft sprocket and timing chain outer surface for reassembly, then remove the chain.
  10. Clean the old sealant off the bolt with a wire brush. Clean the threaded hole in the camshaft with a round nylon brush. Inspect the parts for wear and replace as necessary. Note that some scoring of the chain shoe and guides is normal. To install: WARNING
    Failure to follow this procedure may result in severe engine damage.
  11. Position the intake camshaft sprocket onto the camshaft with the surface marked during removal showing.
  12. Install the intake camshaft sprocket retaining bolt and washer, tighten to 52 ft. lbs. (70 Nm) while holding the sprocket with a suitable tool. Use GM sealant 12345493 or equivalent on the camshaft sprocket bolt.
  13. Place GM tool J 36008, or equivalent camshaft aligning pins, through the holes in the camshaft sprockets into the holes in the timing chain housing. This positions the cams for correct timing.
  14. If the camshafts are out of position and must be rotated more than 1?8 turn in order to install the alignment dowel pins, proceed as follows:
    1. The crankshaft MUST be rotate 90°clockwise off of TDC in order to five the valves adequate clearance to open.
    2. Once the camshafts are in position and the dowels installed, rotate the crankshaft counter clockwise back to TDC. WARNING
      Do not rotate the crankshaft clockwise to TDC; valve or piston damage could result. NOTE: The side of the timing chain that was marked during removal must be showing when the chain is installed.
  15. Place the timing chain over the exhaust camshaft sprockets, around the idler sprocket and around the camshaft sprocket.
  16. Set the camshafts at the timed position and install the timing chain. Remove the alignment dowel pin from the intake camshaft. Using GM tool J 39579, rotate the intake camshaft sprocket counter clockwise enough to slide the timing chain over the intake camshaft sprocket. Release the camshaft sprocket wrench (J 39579 or equivalent). The length of the chain between the two camshaft sprockets will tighten. If properly timed, the intake camshaft alignment dowel pin should slide in easily. If the dowel pin does not fully index, the camshafts are NOT timed correctly and the procedure must be repeated.
  17. Leave the alignment dowel pins installed. Raise and safely support the vehicle.
  18. With the slack removed from the chain between the intake camshaft sprocket and the crankshaft sprocket, the timing marks on the crankshaft and cylinder block should be aligned. If the marks are not aligned, move the chain one tooth forward or rearward, remove the slack and recheck the marks. Fig. 10: Timing chain assembly retaining bolts - 2.3L and 2.4L engines 87953111.gif
  19. Reload the timing chain tensioner assembly to its "zero'' position as follows:
    1. Form a keeper from a piece of heavy gauge wire, as shown in the accompanying figure.
    2. Apply slight force on the tensioner blade to compress the plunger.
    3. Insert a small prytool into the reset access hole, and pry the ratchet pawl away from the ratchet teeth while forcing the plunger completely in the hole.
    4. Install the keeper between the access hole and the blade. Fig. 11: Reloading the tensioner to its "ZERO'' position, then install to the chain housing 87953110.gif
  20. Install the tensioner assembly to the timing chain housing. Recheck the plunger assembly installation, it is correctly installed when the long end is toward the crankshaft. Install the tensioner retaining bolts; tighten to 89 inch lbs. (10 Nm).
  21. Carefully lower the vehicle enough to reach and remove the alignment dowel pins. WARNING
    Severe engine damage could result if the engine is not properly timed.
  22. Rotate the crankshaft clockwise (normal rotation) two full rotations. Align the crankshaft keyway with the mark on the cylinder block and reinstall the alignment dowel pins. The pins will slide in easily if the engine is correctly timed.
  23. Install the timing chain guides, then install the front (timing chain) cover.
  24. Connect the negative battery cable.
Oct 02, 2010 | 1997 Chevrolet Cavalier
How do i set the timing marks on a 3.4 liter engine
3.4L Engine Fig. 7: View of the timing chain and related components with the front cover removed — 3.4L engine 88003gb7.gif
Fig. 8: Retract the timing chain tensioner 88003gb8.gif
Fig. 9: The special tools must be used . . . 88003gb9.gif
Fig. 10: . . . to remove the timing chain, crankshaft sprocket and intermediate shaft sprocket 88003gc1.gif
Fig. 11: Slide the sprocket and chain on the shafts, maintaining the proper alignment 88003gc3.gif
Fig. 12: The crankshaft sprocket must be pressed on to specifications using a special tool 88003gc4.gif
  2. Raise and safely support the vehicle.
  3. For 1991 vehicles, perform the following:
    1. Remove the starter motor and flywheel cover.
    2. Remove oil pan retaining nuts and bolts. Remove lower frame and powertrain onto transmission table.
  4. Remove the front cover, as outlined earlier this section.
  5. Matchmark the intermediate sprocket, chain link, front face of cylinder and crank sprocket for reference.
  6. Retract the timing chain tensioner shoe by using J–33875 or equivalent, on both sides of the tensioner and pulling on the thru pin in the tensioner arm to retract the spring. While spring is retracted, insert a holding tool to hold it.
  7. Remove the timing chain tensioner retaining bolts.
  8. Raise and safely support the vehicle.
  9. Remove the timing chain, crankshaft sprocket and intermediate sprocket using tools J 8433 and J 28611, as shown in the accompanying figure. If the intermediate gear does not slide off easily with the timing chain assembly, rotate the crankshaft back and forth to loosen the tight fit.
  10. If necessary, remove the timing chain tensioner. To install:
  11. Check to ensure that crankshaft key is installed and fully seated and the chain tensioner is fully installed and blade retracted.
  12. Slip both sprockets and chain over the proper shaft and engage the slot in the key. The intermediate shaft may move against the rear cover. Slide the sprocket and chain on the shafts, maintaining the proper alignment shown in the accompanying figure. While installing note the following:
    1. Make sure the rubber and tension blade of the tensioner does not become caught, misaligned, or dislodged.
    2. The large chamfer and counterbore of the crankshaft sprocket are installed towards the crankshaft. The intermediate sprocket spline sockets are installed away from the case.
    3. The crankshaft sprocket must be pressed on for the final 0.31 in. (8mm) to the seated position using tool J38612 or equivalent, as shown in the accompanying figure.
    4. Check to make sure timing was maintained. Remove the retaining pin from tensioner.
  13. For 1991 vehicles, install the oil pan retaining nuts and bolts, and the flywheel cover and starter.
  14. Install the front cover, as outlined earlier in this section.
  15. Connect the negative battery cable. Start the engine and check for leaks.
Jul 09, 2010 | 1995 Chevrolet Monte Carlo
I need a diagram of timing chain replacement Thank You
During most engine rebuilds, a completely new timing assembly should be installed. If wear exists on any component, replacement of the entire assembly is necessary. Wear in the chain, gears, or sprockets means a timing lag, which results in poor engine performance.
The timing chain or belt is generally installed with the gears in their correct positions. Before installing a new chain, soak it in oil.
OHC (Overhead Cam) Engines
Some OHC engines use a chain drive; others use a belt drive. Removing the cover on some OHC engines that have timing chains is more difficult, because the cover often fits between the oil pan and the cylinder head. There are special procedures for replacing cam timing components in these engines.
Before a chain repair job, perform a leakage test on non-freewheeling engines to check for bent valves, so that an accurate repair estimate can be made.
OHV (Overhead Valve) Pushrod Engines
On many OHV pushrod engines, the crankshaft sprocket is installed on the crankshaft nose and the crankshaft is rotated to position piston #1 at TDC. At this point, a mark stamped onto the crankshaft sprocket is pointing directly upward (toward the camshaft).
The camshaft sprocket is then temporarily bolted to the cam and used to rotate the cam until a mark stamped on the cam sprocket is pointing directly downward (toward the crankshaft). The sprocket is then removed from the cam (without allowing the cam to rotate).
The timing chain is looped over the cam gear, the mark on the cam gear is positioned directly downward, and the chain is looped around the crankshaft sprocket. When the cam sprocket is attached to the cam, the timing marks on the crank and cam sprockets should be pointing toward one another. NOTE THIS IS FOR 2WD 4.0
May 22, 2010 | 2005 Nissan Pathfinder
Timing specs
Here is All Lititure But Pictures Wont show up on FixYa for some reason, I can Email it ALL to you Just Send Me A Request to my Nickname here @aol.com
SPECIAL TOOLS REQUIRED (or equivalents)
  • J-36008, Camshaft sprocket timing alignment pins.
  • J-39579, Camshaft sprocket wrench.
CAUTIONS:
  • The timing chain on the 1996 LD9 (VIN T) Twin Cam Engine is not to be replaced with the timing chain from any other model year. The timing sprockets are different on the Twin Cam Engine and the shape of the links matches the sprockets. Engine damage may result if the wrong timing chain is used.
  • The timing chain and crankshaft sprocket MUST be marked so that they are reinstalled with the same side facing out at the time of reassembly.
  • Failure to follow the removal and installation procedures could result in severe engine damage.
REMOVE OR DISCONNECT
  1. Negative battery cable.
  2. Front cover, refer to Timing Cover / Service and Repair .
  3. Rotate crankshaft in clockwise direction until camshaft and crankshaft timing marks are aligned.
  4. Timing chain guides.
  5. Raise and support vehicle.
  6. Ensure slack in timing chain is above tensioner assembly, then remove chain tensioner. The timing chain must be disengaged from grooves in tensioner shoe to permit removal of shoe. Position a suitable screwdriver under timing chain while pulling shoe outward. If difficulty is encountered in removing tensioner shoe, proceed as follows:
    1. Lower vehicle, then while holding the intake camshaft sprocket with J-39579, remove sprocket bolt and washer.
    2. Remove washer, then install bolt into camshaft by hand.
    3. Position a suitable three jaw puller into intake camshaft sprocket relief holes and remove sprocket. CAUTION: Do NOT pry on camshaft sprocket as damage to sprocket or timing chain housing may result.
  1. Tensioner assembly attaching bolts and tensioner assembly.
  2. MARK CRANKSHAFT SPROCKET AND TIMING CHAIN outer surface for reassembly.
  3. Timing chain.
INSTALL OR CONNECT
  1. Intake camshaft sprocket onto camshaft with surface marked during removal showing.
  2. Intake camshaft sprocket retaining bolt and washer, torque to 70 Nm (52 ft lbs) while holding the sprocket with J-39579 (if removed).
  3. Timing pins, J-36008, through holes in camshaft sprockets into holes in timing chain housing to position camshafts for proper timing. If camshafts are out of position and must be rotated more that 1/8 turn to insert timing pins:
    1. Crankshaft MUST be rotated 90°clockwise off of TDC in order to give the valves adequate clearance to open.
    2. Once the camshafts are in position and the timing pins have been installed rotate crankshaft COUNTERCLOCKWISE to TDC. CAUTION: Do NOT rotate the crankshaft clockwise to TDC, valve or piston damage could occur.
  1. Timing chain over exhaust camshaft sprocket, around idler sprocket and around crankshaft sprocket.
  2. Set camshaft sprockets at timed position and install timing chain. Remove timing pin from intake camshaft. Using J-39579, rotate the intake camshaft sprocket counterclockwise until timing chain can be installed over sprocket. Release J-39579 after timing chain has been installed over sprocket. The length of chain between intake and exhaust camshaft sprockets should tighten. The timing pin should easily fit through intake camshaft sprocket timing hole into timing chain housing timing hole. If timing pin does not fully index, the camshafts are NOT timed correctly and the procedure MUST be repeated.
  3. With timing pins installed, raise and support vehicle.
  4. With slack removed from timing chain between intake camshaft sprocket and crankshaft sprocket, timing marks on crankshaft and engine block should be aligned. If the marks are not aligned, move timing chain one tooth forward or rearward to align marks. Remove slack and recheck marks.
  5. Reload tensioner assembly to zero position as follows:
    1. Form a keeper out of heavy gauge wire into a U-shaped piece with a half inch opening.
    2. Apply slight force on tensioner blade to compress plunger.
    3. Insert small screwdriver into reset access hole and pry rachet pawl away from ratchet teeth while forcing the plunger completely in the hole.
    4. Install keeper between access hole and blade.
  1. Tensioner assembly to chain housing and recheck plunger assembly installation, noting long end is toward crankshaft.
  2. Tighten timing chain tensioner bolts to 10 Nm (89 in lbs) .
  3. Lower vehicle to point where timing pins can be removed from camshaft sprockets.
  4. Rotate crankshaft two revolutions in the clockwise direction. Align crankshaft keyway with the mark on cylinder block and reinstall timing pins through camshaft sprockets into housing timing holes. Timing pins should slide easily through timing holes. If timing pins cannot be inserted easily, repeat procedure to properly time engine. CAUTION: If the engine is not correctly timed, severe engine damage could occur.
  5. Timing chain guides.
  6. Engine front cover.
  7. Negative battery cable.
Nov 15, 2008 | 1995 Pontiac Grand Am
Garden Logo
120 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
