Question about Ovens
We have a neff b44s42n3gb, why do we get a fan noise,(not rear fan) when we try to set auto timer is this normal?
Is this normal or am I missing something,nothing mentioned in manual
5 Suggested Answers
murdozzz2
  • 75 Answers
SOURCE: Auto Timer
hi there switch your oven off at the mains switch for one minute thenswitch back on and set the time this will disable the auto on the timer.
Posted on Dec 09, 2007
carmin77
  • 113 Answers
SOURCE: My Neff B1451 oven is
Yep. Could be the heating element.
Posted on Jun 03, 2011
SOURCE: How do I set auto timer on my neff oven to come on
Here is the link to a short PDF file that explains a couple of setting on the Neff oven, including the automatic timer:
http://www.neff.co.uk/files/Getting_Started_Leaflet.pdf
Hope this helps. :)
Posted on May 20, 2012
omiga man
  • 452 Answers
SOURCE: Neff B1593NOGB/07 not working, clock is set, no selected function does anything, no fan noise, heat from anything, the only noise is from the selector moving??
check time delay i had this problem i mistakenly selected it once time ran out it worked but make sure nothing is in or on heating surface u might not b there when it runs out, another way is some times it works..... completely turn of power to cooker un plug or turn of supply 5 minits shud do it..then back on it shud reset and try again Rob hope this helps u all the best Alan
Posted on Jan 19, 2014
Cooling fan on my neff oven stays on when I set it in auto is this normal
Are you sure you mean 'C ooling Fan' and not 'Circulating Fan' which should come on if the temperature selection is higher that the current temperature.
Oct 10, 2016 | Neff Ovens
Tip
Neff U1452 Double oven Common heating faults,
For all Free appliance repair videos visit our VIDEOTUTORIALS
1, If the Neff fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1452 Double circotherm plus Electric...
How do I set auto timer on my neff oven to come on In a couple of hours ?
Hope this helps. :)
May 20, 2012 | Neff Ovens
Replace fan motor in an electric fan oven
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Neff B1421 Electric Single Oven
Oven on fan setting not working ;fan is still working but oven is not getting hot on large oven
The oven element is faulty, and needs replacing.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thankyou.
Jan 12, 2010 | Neff U1452 Double circotherm plus Electric...
Need to put new bulbs and elements in fan oven
the bulbs are screw fit normally Neff fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
Jan 12, 2010 | Ovens
NEFF B1320 OVEN DOES NOT HEAT UP. POWER ON FAN WORKING
For all Free appliance repair videos visit our VIDEOTUTORIALS neff video
1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
Dec 25, 2009 | Neff B1641 Single circotherm super...
The bottom (fan oven) of my Neff U1721 made soft bang noise and failed. The fan stopped, the oven light went out and the thermostat light. I replaced the burnt out heating with a new element with a 32.5...
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
Dec 15, 2009 | Neff U1721 Double circotherm Electric Oven
Neff oven fan not turning and element blown. Is the motor bad as well?
it might also be the timer For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
Jun 19, 2009 | Neff U1452 Double circotherm plus Electric...
Ovens Logo
42 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
