Question about GMC 02 03 04 05 Envoy Chevy Trailblazer Transfer Case Computer Tccm 4x4 12590220
Power windows power seats radio dome lights do not work
Seats windows dome lights
  • 1,511 Answers
The controller has failed and needs to be replaced or reset by the factory technician.
Posted on Apr 15, 2014
2002 Ford F-350 super duty relays. Having trouble with power windows,radio,dome light and gauges. Wondering what each relay controls
You don't have any fuse panel relays that control any of these. Only fuses. You won't like this. But here I go. Windows, bad master switch, regulators/motors, or broken wires at the drivers door. Radio, most likely it died. Check the fuse..Dome light, If any light works in the dash, It is the light or a bad wire. No lights check fuse and wiring. Gauges are from the electronics. Can be from corrosion at the cluster panel plug or a bad PCM.
Dec 13, 2016 | Ford Cars & Trucks
2003 expedition radio and Windows have power with key off and door opened
You are the 3rd person w the same problem. I would lean toward an electrical short in the ignition system wiring harness. They are very popular for that. Ask them of any recalls or technical service bulletins about this.Do you have any dome light , power window or power seat issues too? That's another popular one.Good luck
Sep 20, 2015 | Cars & Trucks
My car is dead. The radio, windows, sunroof, seats, and mirrors don't work. Also it doesn't come out of park. Head light and dome light works
I believe you posted twice, check fuses like I mentioned before. You may have a main fuse that is blown, these are often under the hood. If it's not coming out of park, this could also be a symptom of the fuse because the brake pedal safety switch is not working without power. Usually a car wont shift out of park without power.
Nov 13, 2013 | 2006 Lexus Es 330
No power to cd player or ceiling light grand vitara 2003
fuse, called dome fuse is blown, or radio fuse.
fuses that look bad, are, fuses that look good, may be...........
check fuses with an ohmmeter, fuses that look good can have very tiny cracks and are not good, only an ohmmeter works, on fuses with 100% accuracy. (a volt meter works in circuit even better !!!)
Did you test the dome lamp to see if it really works?
pull it , put across 12v battery ,does it glow?
did you look at the radio. and see if it has its own inline fuse?
did you hot wire the radio power wire to see if the radio even works at all?
if you have DMM with voltmeter this is so very easy to trace.
ask.
Feb 24, 2013 | 2003 Suzuki Grand Vitara
98 toyota corolla radio, dome light, and power locks don't work
2005 toyota corolla radio,dome light,alarm and power locks dont work.
Apr 26, 2009 | 1998 Toyota Corolla
Radio, dome lights and EVIC power problem
I found a paritally blown fuse. When the fuse blew metal pieces ended up partially making contact. After replacing the fuse everything worked great.
Jan 07, 2009 | 1994 Jeep Grand Cherokee
2000 Ford Expedition, power windows and dome lights won't come on
first of all you may not be looking for a fuse if you have an owner manual check the fuse box under the hood as well it maybe one of the little boxes called a relay
Jan 02, 2009 | 2000 Ford Expedition
When I shut off the ignition the radio and dome light stayed on
I have the same truck. The thing is designed so that the radio and dome light and even the windows will operate for a time which should expire immediately when you open the door. Try turning on the radio with engine running and then turn off the engine and just sit there and the radio should still play. Try the power windows - they too should go up and down. Finally open the drivers door and that should immediately kill the radio, windows and dome light. If it does not - you will need to report that problem to your dealer since the problem is in that timer feature which is part of the vehicles "brain". Sorry I can't be more helpful.
Dec 19, 2008 | 2003 Ford F250 Super Duty Crew Cab
GMC 02 03 04 05 Envoy Chevy Trailblazer Transfer Case Computer Tccm 4x4 12590220 Logo
Top GMC Computers & Internet Experts
Alun Cox
Jeff Armer
David Ellis Rhea
Are you a GMC Computer and Internet Expert? Answer questions, earn points and help others
