Question about Garden
Landini tractor manuals
I EED THE SETTINGS ON A 14 INCH LUK PRESSURE PLATE , MAIN FINGERS AND PTO FINGERS FROM FLYWHEEL DISTANCE
    Champion:
  • 279 Answers
Contact dealership/service center or find a service manual online
Posted on Jun 03, 2014
  • 69 Answers
SOURCE: THE PTO LEVER ON A 210 JOHN DEERE GARDEN TRACTOR
I believe there is an adjustment for this. Check
www.weekendfreedommachines.com for specific info. Look in the Restoration and Repair Forum.
Posted on May 06, 2009
  • 394 Answers
SOURCE: DTY 4000 tractor dies when engaging pto, new
This is just a suggestion. Try pulling the choke out about one third to one half and then engage the PTO. Sometimes the air idle adjust screw port gets a tiny speck of debris in it. If with the choke partially out and the PTO engages the just grab a screwdriver and turn the air idle mixture screw counter clockwise a hair.
Posted on Apr 30, 2010
Testimonial: "Hit on the head with such a simple solution"
d_hubbs
  • 270 Answers
SOURCE: I have a 2510 John
Hi, I'm David .Hope i can give you some help.
First of all I beleive if you Make Sure you Don't Hahave the Clutches Backwards,Its Easy to do this.To line them Up your going to need a Helper,Trying this by your self will were you out.
Check to make sure The Splines are the Same as the Old Clutches.Includind the amount of Teeth in Each Clutch Have Got to be the Same.
Second make sure you have Plenty of Slack in your Clutch Adjustments.Remember you just removed a Work set of Clutches.So you'll need to Back off The Clutch Adjustments.
To give you plenty of Slack.You might also want to See if your Dealer Has a Pilot Tool or Clutch Alingment Tool to Help you .
Sir I hope i've Helped you.
Please let me Know by Voting on The Quality of my Solutiuons. Thank You:
Posted on Sep 23, 2010
  • 6468 Answers
SOURCE: pto, electric clutch
check the wires they rub on sharp edges
Posted on Mar 24, 2012
  • 117 Answers
SOURCE: pto light stays on, tractor won't start (4400)
I would check the PTO switch with a meter, some switches uses 3 or 4 wires 1 or 2 is for the light and the other goes to the clutch. Part of the switch could be bad. Check the voltage on the connector before the switch.
Posted on Apr 03, 2012
Can someone please help me with the torque settings for the flywheel of the Fiat 980 tractor?
FLYWHEEL BOLTS TORQUE SPECS
20R/22R/22RE MANUAL <80 FT-LBS.>
AUTO <10-15 FT-LBS.>
2RZ MANUAL <65 FT-LBS.>
AUTO <54 FT-LBS.>
3RZ MANUAL <19 FT-LBS. +PLUS 90?>
AUTO <54 FT-LBS.>
3VZ MANUAL <65 FT-LBS.>
AUTO <61 FT-LBS.>
5VZ MANUAL <63 FT-LBS.>
AUTO <61 FT-LBS.>
CLUTCH PRESSURE PLATE-TO-FLYWHEEL <11 TO 15 FT-LBS.>
Hope this helps, cheers!
Aug 16, 2016 | Garden
It's a 95 landini tractor and the tiller stops when it hits the ground
pto not properly engaged
spline stripped
sacrificial pin sheared
Jun 01, 2016 | Cars & Trucks
Isuzu 4fe flywheel and clutch pressure plate torque settings please
If this was in a basic workshop the flywheel would be as tight as you can reasonably pull with a 1/2 inch breaker bar, clutch pressure plate bolts with a 1/2 inch ratchet. Loctite the bolts. Tighten evenly across the bolts in sequence. If you really want to know hopefully someone will have a manual and sign in.
Nov 06, 2015 | Isuzu Cars & Trucks
Hey Timlifixit when I bolt the pressure plate to flywheel are those fingers to the pressure plate suppose to move all the best in
Yes. As you tighten the pressure plate mounting bolts the fingers should move toward the pressure plate.
Apr 18, 2015 | Cars & Trucks
"service manual for a Landini tractor
Couldn't find a freebe but this place has them for $10.
http://landini-tractor.servicemanualvault.com/
Dec 05, 2014 | Garden
Does a 1995 toyota tercel manual transmission or clutch have a filter, transmission slips when i exelerate. manualtransmission
If this is a manual transmission and you get slippage at acceleration, then your clutch is slipping.
An adjustment might help a little bit, for a while, but I think I'd prepare myself for having the transmission pulled and the clutch replaced.
The clutch assembly is made up of 4 main elements: (1) the flywheel (bolted to the rear end of the engine crankshaft), (2) the pressure plate bolted to the flywheel (a spring loaded device that applies pressure to the clutch disc), (3) the clutch disc (sandwiched between the flywheel and pressure plate) that connects, via friction, the engine to the transmission, (4) the throw out bearing, which pushes against the fingers of the pressure plate to release the clutch disc engagement.
I'd seriously consider having some one do this for you....having to remove the transmission is not something for the faint of heart. Serious injury could result if the transmission were to fall on you while pulled back from the engine bell housing.
Oh, and another thing...I'd replace the pilot shaft bushing while I was in there.
If you really want to do this yourself, then go to your local auto parts store and purchase a vehicle specific repair manual. It should outline the steps specific to your car.
Remember....be very careful!
Mar 02, 2011 | 1995 Toyota Tercel
1989 vette L98 external balance eng. w/6 speed ZF trans. installed new LUK (GM) dual mass flywheel w/ OEM replacement clutch/pressure plate assy. - eng. is out of balance. what is proper allignment for...
The clutch disk and pressure plate should be balanced and can be mounted in any position that the mounting holes line up. If there is a hole for an alignment dowl, then it is recommended to do so. otherwise it doesnt matter.
The internal balancing is taken care of by the flywheel only.
Jul 10, 2009 | 1989 Chevrolet Corvette
I have removed the pressure plate and clutch disc. how do i remove the flex plate to get to the flex plate bolts. 2007 dodge ram 3500 6 speed manual transmission
theres an access cover under the turbo on the front of the bellhousing (2 10mm bolts) that you have to remove to access the bolts that hold the flywheel to the flexplate. kinda like removing the bolts to a torque converter. flywheel is real hevy though, watch your fingers
Apr 27, 2009 | 2006 Dodge Ram 3500 Truck
Garden Logo
239 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
