Question about Samsung 24.5 Cu. Ft. Counter-Depth Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel RSG257AARS
Samsung refrigerator Temp says 0F?
    Sergeant:
  • 479 Answers
This means 0deg Ferenhite
Posted on Jun 26, 2014
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
My Samsung Refrigerator is making a noise that sounds like an old style door bell. It a loud buzz that occurs several times a day. Do you have any ideas?
User manual and parts list and diagrams.
SAMSUNG Refrigerator Parts Model RF217ACPN XAA
Your refrigerator has at least three motors with fans in addition to the compressor motor. The one most suspect is the one that passes air from the freezer to the refrigerator.
samsung refrigerator noise YouTube
Oct 19, 2014 | Samsung RF217ACPN - 20 cu. ft. French Door...
Freezer keeps beepimg
if the temp. in the refrigerator side is 20f, its to low, set the ref. to 40f and freezer to 0f.
Sep 23, 2012 | Liebherr CI1651 30" Built-in...
Frigidaire FKFH21F7HWA Freezer Control Panel Stuck at 0F
did you press and hold the freezer off symbol for three seconds
Jul 31, 2012 | Frigidaire Freezers
What is the highest temperature for the freezer
If you mean the lower temp. for the freezer, is between 0f to 16f.
Sep 15, 2011 | Maytag 15 cu. ft. / 425 liter Upright...
Samsung Refrigerator with bottom freezer model # RB195BSBB freezer will not hold temperature. There is a fan running a loud and constantly, and freezer will work it's way down to 8 degrees but will not get...
Check for ice build-up in and around the freezer fan where the blades are, if you can see ice in there (some times it may look like white foam but dont be fooled, it will be ice), the fan will be hitting it, defrost the freezer and check defrost element, (you will have to dismantle freezer section to get to it but reletively simple job) disconect from mains first. Good luck
Dec 18, 2010 | Samsung Freezers
Frigididaire uprite freezer How does one figure the appropriate temperature setting
If you have a digital readout then set it for 0F...if you do not have the temperature read out then place a thermometer inside and adjust the thermostat till you get to the 0F mark..
heatman101
Sep 16, 2010 | Frigidaire Freezers
Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting up.it should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Feb 17, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
Glfh21f8hw freezer - tried to bring the temp down off extreme freeze and it went off (display shows OF and compressor stopped). Just loaded it with lots of food, can't get it to come back on and the...
At 0F it will go off because it is at 0 so it is ok later when it warms up again it will start up and bring the temp down again. Just check your temp for a couple of days so you have it at the right temp.that you need it at. It should be OK at 0F
Dec 06, 2009 | Freezers
Freezer will not turn on
Sounds like the sensor circuit may be open. Here is the problem, either it has a board that's bad or the sensor is out. Ohm the sensor circuit and record the temp the box is at in refrigerator and freezer. then the ohm reading. Contact manufacturer or representative of manufacturer, and ask what the sensor should read at the temps you have.
Generally if you get a reading on the sensor circut the sensor is ok, and the board is out BUT not always. this is why you need the temperature and the ohm readings. Sometimes the wire diagram has a legend with these reading on it. Look all around the underneath and behind sections for an envelope containing the wire diagram.
Apr 16, 2009 | Freezers
Samsung 24.5 Cu. Ft. Counter-Depth Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel RSG257AARS Logo
114 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
