Question about FPS 4 Channel Standalone DVR system, 120FPS Display/ 30FPS record,120GB HDD)
I forgot ths password of dvr(h264) mycam 380v,how could i recover my system
Forgot password mycam 380v.
Forgot admin password in Hifocus H264 DVR, unable to enter main menu
Hi. Put here some images of the DVR's front side, the login screen and the WEB interface.
Jun 15, 2015 | Home Security
Lost password h264 dvr
If you had changed the default password that came with your system-
#1. Contact either the manufacturer, installer, or vendor from where you purchased your system from; they should be able to walk you through the steps of how to reset the password to its default.
And then from there, you can change it to the password you want to use.
If you never changed the default password, your user manual will have it for you...in the event you lost the user's / owner's manual, see #1.
Mar 08, 2015 | Night Owl Optics Night Owl LION4500...
How to reset the password or the H264 DVR to factory settings for Digital ID view?
Will need a model number. H264 is the compression format.
Dec 11, 2014 | Home Security
How do i find the defult sender password to set up my H.264 DVR
Open up the password browser and enter...519070 that's the Default. I have years of experience with the night-owl system.
INSKIP
Jun 07, 2014 | Night Owl Optics Night Owl Scorpion 168500...
How do i reset password for h264 dvr
Hello, There are two things you can try, the default password for the system should be 000000. If that is not the password if you go into the System Menu under the "General" tab there will be an option that says Factory Defaults, this will reset the settings to the default and should remove any password that is in place, but be warned that this will possibly wipe the dvr.
May 08, 2014 | Digimerge H264 16 CHANNEL DVR WITH USB CMS...
I have a dvr model no. dyk4500 4ch h264 dvr i for got my password. How do i reset it
The DYK4500 is a DVR system and is not a Windows or traditional computer. It does not have an optical drive. You may first want to just hit enter and see if the password is not set. Try any other methods first, and if all else fails, you can attempt a reset by removing the BIOS battery and jumping the contacts for 30 seconds. This method sometimes has issues that are tough to recover from if you don't have the remote. You'll often get to a first screen that shows: HDD0 Detected, HDD1 No Device. Haven't figured out how to bypass this window without the remote. With the remote, you should be able to press '0' twice.
Dec 21, 2013 | Computers & Internet
How do you reset the admin password on a truvision dvr 30 16 channel.
how do i reset admin password on a truevision dvr.
I have changed it and i forgot it
Jun 29, 2011 | GE Security Kalatel TVR3008500 TruVision...
How to reset ie admin password for night owl scorpion
If your DVR is networked you can use this utility to recover the passwords
http://seanmsiegel.com/blog/raysharp-password-hack-exploit/
nightowl dvrs seem to be made by raysharp
Jan 10, 2011 | Night Owl Optics Night Owl Scorpion 168500...
Televison & Video Logo
228 people viewed this question
Top FPS Televison & Video Experts
Electro Med Services...
Are you a FPS Televison and Video Expert? Answer questions, earn points and help others
