Question about Avanti W757-1 21" Top-load Washing Machine
Top cover how do you change the top cover
I want to change my facebook profile cover
If you click on the tag at the top right hand side of the screen that says your name next to a thumbnail of your profile picture (In my case, it would have a little photo next to "Matthew Harris"), it will take you to your timeline. At the top of your time line is your Profile picture inset into your Cover picture. Hover your mouse over your Cover picture, and a little button will pop up that says "Change cover". Click on the button and it will give you several options to edit or change your cover photo.
Feb 11, 2014 | facebook.com
Tip
How to change toner in laserjet printers
First Turn the printer's power off. Some power button is located on the control panel on the top of the printer, on the right side. Open the printer's top cover by pressing the top cover lever, which is located on the bottom side of the top cover. Lift the cover all of the way open. Locate the toner cartridge. It will be right in the center of the printer and has a handle on the top of it. Grab the handle and pull the cartridge out. Hold the replacement cartridge at its side and gently rock it back and forth. This will help to distribute the toner equally throughout the cartridge.Remove the paper cover from the top of the cartridge.Insert the replacement cartridge into the printer and close the printer's top cover.
on Mar 31, 2010 | Office Equipment & Supplies
How to change the inside bulb in a ge spacemaker microwave that has a top vent fan
My Spacesaver bulb replaces from the top. You have to remove 2 screws that hold the upper vent cover. W/ cover off you will find a phillips head screw about the center that holds the bulb cover. Remove the cover screw & lift up & remove the cover, then replace the bulb, the cover & screw then put the vent cover & it's 2 screws back. There may be some variance but they are all similar.
Mar 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
I want to chANGE THE PLUGS ON MY 1998 cABRIO BUT THE PLUGS AND WIRES APPEAR TO BE SHIELDED OR COVERED BY AN ALUMINUM CASING. hOW DO i CHANGE THESE PLUGS.
ON TOP OF ENGINES COVER IT HAS THREE PLASTIC PLUGS, REMOVE PLUGS WITH A SMALL FLAT HEAD SCREW DRIVER.THEN REMOVE ENGINE TOP COVER SCREWS.REMOVE TOP COVER THEN CHANGE SPARK PLUGS.
Jun 22, 2011 | 1998 Volkswagen Cabrio
How do i change the belt on the eureka 4703D
Changing the belt is quite easy on this unit.
First, you will need a phillips screwdriver looks like the X. there should be 2 screws on the top cover, and then MAYBE one more there by the hose where it attaches to the base at the back. The top cover comes off and you have full access to the belt underneath.
Also, side note, once you have the cover off there you should see a black and yellow sticker near where the belt rides, and it will go into more details to changing the belt.
Nov 03, 2010 | Eureka Power Plus 4703D Bagless Upright...
Error during 1st install of paper
konica minolta magicolor 1680mf service call 0094
Help me
May 30, 2010 | Konica Minolta magicolor 1680MF -...
How do I change the ink on my Canon MX320
Just open the top cover together with the scanner bed.
When the cartridge carrier move in the middle of the printer, that is the time you can replace the catridge. Lift up the top cover for the cartridge carrier and then the cartridges.
When replacing the cartridge. Push the cartridge down the carrier, you will hear a snapping sound. Return the top cover for the carrier and the scanner bed.
May 20, 2010 | Canon PIXMA MX310 All-In-One Printer
Changing power outlet on pc
Take out all of the screws on the bottom. Remove the hard drive and the dvd drive. Take out the keyboard, take out the screws from the top cover, remove the screws to the lcd assembly and take that out and any wires that are connected to the lcd.
Once this is done then take the top cover off and make sure you disconnect the ribbon cables before taking off the top cover.
Then after taking off the top cover remove any screws holding down the motherboard. After you get the motherboard out then find where the dc jack is and then you can either change it out with a new one or resolder the exising one back into place.
Then when your done you can put it back together again.
Jan 12, 2009 | Toshiba Tecra 8000 Notebook
B door open
There are two switches, so if you changed the one that was working....
Possible parts affected could be
- cover top
- cover fuser
- cover front assembly
- the switch
1) check the condition of the cover - top, front assembly and cover fuser closed?
2) on the cover top there is an "actuator", a plastic bit, which presses down on the switch assembly top - is that plastic bit broken, bent or deformed?
3) on the cover front assembly there is also an "actuator", check this
4) and of course same for the fuser cover
5) top cover, check the switch, disconnect the switch (P116-1) and press/release it - does that make a difference. If not replace switch
6) same procedure with the switch (P115-1) for front cover.
Feb 04, 2008 | Epson Aculaser C1100 Printer
Changing belt on hoover runabout
Found this info on the web...haven't tried it yet
Looking at the brush, remove the two screws from the black plate holding the brush. There are two clips that holds this plate once you remove the screws. This should be easy to remove with a flat type screw driver. Now is the tricky part to remove the top cover of the vacuum so you can access the compartment to put the belt on. The whole top part of this vacuum comes off. If you look above the part where black plate was, there are two more clips on the top left and top right hand corner. These two hold one end of the top cover. It is not as simple as pushing the clip to one end to slide out. You have to find a gap between the edge of top cover and bottom structure(right next to each clip) and shove the flat screw driver in and push the top cover away from the bottom structure and push down the top cover. You will notice that there are invisible hinges between the two which locks in the top cover.
Do the same procedure for the bottom right and left edges(right next to each end of the brush) of the vacuum and separate the two(bottom structure and top cover) out using the flat type screw driver..
Sep 07, 2007 | Vacuums
Avanti W757-1 21" Top-load Washing Machine Logo
Top Avanti Washing Machines Experts
Jim Thurston
Kolbrun...
Keith Poitier
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
