Question about Toro Garden
I have a 1987 Toro GTS Self propelled walk behind mower- My question is that it runs fine but but seems to be slippling and can't get out of it's own way
Good belt but self-propelled ( rear drive )slipps and I am almost better off pushing it.
  • 27 Answers
  • Check for belt stretching even if it looks good. Next possibility
Is worn smooth, or oily surfaces on drive wheels. Can you tell if it slips on drive wheel, or those driven. Some Hondas have belt tensioners which can be too loose. See if axle on drive wheel is in a slotted, rather than round whole, meaning you could loosen/retighten while putting pressure on it to lengthen distance to driven wheels.
Posted on Apr 02, 2014
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Toro 6.5 HP Self propelled walk behind 22
take the top cover off the engine. you will see the coil on top there. unplug the wire that plugs into it. put the cover back on and try to start it. if it starts it is not the coil. try a different spark plug first. pull the cord with the plug out to get all the gas out of the engine.
Mar 20, 2017 | Garden
My toro walk behind self propelled blade disengages how do I adjust it
No adjustment, ensure no obstruction on drive end of cable, replace cable, probably stretched over time.
Jun 17, 2012 | Toro Power Lawn Mower
Have a walk behind 22"
Sounds like the rewind spring is broken in the recoil starter.
Aug 04, 2011 | Toro Power Lawn Mower
I have a self-propelled walk behind number and the wheels quit spinning and the mower becomes very difficult to push. I am so frustrated. The mower has only been used five or six times and is brand new,...
I would probably take it back to where I bought it to begin with. But, I have an old Huskavara mower self propelled, at times if I set it on top of two 4 x 6 blocks (6 inches up) I have to take off the wheels and clean up the axles using thinner, degreaser, or gas, anything to break down oil or dirt. Then I oil the surfaces and reassemble, and the wheels work for a while.
Jul 04, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Toro 6.5 GTS does not self propel
The self propel part does not work on my Toro 6.5 GTS. How to fix?
Apr 03, 2010 | Toro Lawn Mower With Toro Power Tools
6.5 toro walk behind self propell b&s engine. self propel does not work
Try adjusting your self propel cable. A slight extension of the cable (1/4 inch) will double speed, so do a little at a time. Take the back guard off and clean debris 2 or 3 screws and it is just a cover so nothing will pop out unless that is your real problem. You should have grease fittings behind rear wheels so squirt 2 times with grease gun in each wheel and 1 squirt every 3rd mow.
Aug 05, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
121 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
