Question about Hitron 2 12in Subwoofers loaded in Bandpass Enclosure Car Speaker
Hitron 600w 12' subs in a bandpass box
What would be the correct amp wattage for 2 12's in a BP box. They're 600w peak.
    New Friend:
  • 101 Answers
I think u mean ohms,amp wattage?wat r u trying to do>?
Posted on Jan 23, 2008
I want to cancel my Somnapure trial, It is under 18 days
To receive your refund, your return must be received at our shipping facility within 30 days of purchase. Be sure to clearly write the return merchandise authorization (RMA) number on the outside of the package. Our shipping department is NOT allowed to accept any packages without an RMA number. You pay for return shipping. Please send your package to the appropriate facility:
  • In the United States: Peak Life - BP 3, 105 Commerce Dr, Aston, PA 19014.
  • In Canada: Peak Life Returns, P.O. Box 1051, Fort Erie, ON L2A 6C7.
  • In Australia: Peak Life, PO Box 535, Braeside VIC 3195.
  • In the United Kingdom: Peak Life, PO Box 1417, Bedfordshire MK41 0QB.
Peak Life Refund and Return Policy
Sep 29, 2014 | Computers & Internet
My woofer is 18' 600w rms power. so what is the
Basically you cannot break you woofer with too powerful amp, but you can break it using too weak amp. This is because if you don't have enough watts going to you woofer the cones movement isn't controlled properly. I'm usually using +20% to the woofers RMS and peak power. This will also make the amp last longer because you won't use it at it's peak performance all the time. If possible use manufacturer whose prising policy matches your woofers manufacturers, that way you won't end up with "2000w peak power" cheap amp with real output of 30w. and in the other end cheap woofer won't handle expensive amp with real 600w rms so well, you need to find a midlle way here. Hard to say without knowing the make and model of the woofer.
This is a taste question for some people, and I haven't build a system to match so powerful woofer ever in my life. But I'm pretty sure you won't go wrong with this one.
May 20, 2011 | Audio Players & Recorders
Can you run a 1200w pioneer sub and 2x9x9 inch car speakers to a 600w pioneer 4 channell amp??
depends on what the RMS is for the subs because although the subs are 1200 watts, there is a minumim standard you have to follow. If you don't atleast run the lowest wattage thru them, then you will most definately damage the should also be aware of the fact that your "600w Pioneer-4 channel amp doesn't even push a true 600 watts... Your best bet is to upgrade ur amp, or add an additional amp to your set-up. And you really need to pay close att to over or under running your power to your stereo system because you'll burn out ur altenator rather quickly. Use proper wattage , and you should also look into getting a power-cell which lessens the chances of destroying your altenator and helps to ensure that your stereo system sounds to its full potential.....
Feb 15, 2011 | Pioneer DEH-P6400 CD Player
How can i get more power through 8 ohm speakers?
In addition to the impedance rating of a speaker, there is also a wattage rating. Ideally, power output of the amplifier should not exceed the power handling rating of the speakers. The input impedance of the speakers should match the amplifier output impedance for maximum power transfer (Rin = Rout where R is resistance in Ohms). Supplying more power or wattage to the speaker than it can handle will result in distortion, and if the output of the amp is high enough and present long enough, it will damage the voice coil of the speaker. Make sure that when comparing wattage ratings, you are comparing the same rating between amps & speakers. Watts can be expressed three different ways: "Peak", "Peak to Peak" and the industry standard "RMS". The relationship is such: an industry standard value of "70 Watts RMS" (70W RMS) equals "100 Watts Peak" (100W P) *and* also is the same as "200 Watts Peak to Peak" (200W P-P). Furthermore, there is no such thing as 200W "Music Power" (but is often expressed this way to inflate the RMS wattage rating (and usually is close to the P-P rating). A speaker is an electrical device, so most the things that happen to electrical devices when over powered can happen to speakers and amplifiers, too.
Increasing the signal source level (input signal to the amp via volume control) in an attempt to get more audio power to the speaker can overdrive the amplifier - resulting in "clipping". This is plainly heard as "muddied" sound. The otherwise loud, crisp, clean passages in music end up sounding garbled and unpleasant when an amplifier is over driven in this way. This can damage both the amp and the speaker.
Cheap amps with higher THD (total harmonic distortion) ratings sound worse than their counterparts with a lower THD rating - when all other variables are the same. You'll pay extra for lower THD values.
You might be able to make a speaker seem louder by positioning the speakers against a wall, on the floor, etc. Experiment; as it can make a significant difference in sound levels and low frequency bass sounds.
I hope this was helpful!
Jun 11, 2010 | Yamaha Emx62m Powered PA Mixer System
What wattage amp do I need to get good sound in a toyota corolla
Make sure it's a RMS 1200 wats not MAX watts also the Ohms of this speakers and them you can buy any amp. with the same RMS watts of your speaker and same Ohms of resistance.
Jan 27, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
You guys was helpful last time so I thought I would ask more!!!! DJ equipment Gem Sound amp EVA-3955 at 8ohms 2x250w blew 2 Tr-150 15'' 8ohms rated at 600w blew. what replacement should I go with same size...
Typically large speakers like that blow up because you are trying to put frequencies into them that they can not reproduce. How are these units connected? Is the crossover frequency correct for these 15" speakers? Putting signals higher than about 1000Hz will start to heat them up. too much heat = blow-up.
Also, I'm not familiar with the tr-150s. Is the 600W rating a PEAK rating or continuous?
Jan 06, 2010 | Audio Players & Recorders
1 Answer getting a speaker that has an 8 nominal load and 600W peak 400Wprogram and 200W RMS...two...what is RMS and what kind of amp do i need so that i dont get screwd over. thank you bunchesand also i...
RMs is the average power (really basically) > You need to get an amp that is around 150W - 180 WRMS. You need to be really specific about the rms. Dont let guys tell you 1000 W peak etc. Peak is term that can often have several meanings, but true RMS is the norm standard for assesing proper power in pro gear. Whatever you find check out the specs for yourself in writing!!!
Hope it helps
Jul 26, 2009 | Audio Players & Recorders
Logic alx1280 2 ch amp
Amps can be rated based on their RMS power or their peak power. In this case, the amp's rated RMS power is 300x2 at 2 ohms (total 600W RMS) with a peak power rating of 600x2 (1200W peak). For the most part, peak power means almost nothing.
If your head unit didn't have RCA preamp outputs, you would used the standard speaker outputs from the head unit and connect them to the hi input plug of the amp.
Mar 17, 2008 | Logic Soundlab ALX1280 Car Audio Amplifier
Compatible amp for subs
hi there. yes it should work providing you have the correct wiring it for it, if you buy the LV 416 enquire about a wiring kit to fit, most will. theyre normally around 20pounds. most amps will be compatible with most subs. i run both my 12inch 1000w off one 1200amp at half power, they kick lovely and i have no problems.
any other quiries please ask
Nov 10, 2007 | Legacy 2CH 1000W AMP Car Audio Amplifier
2 12" Hitron 600w subs in a BandPass box
Remember that driving a load with an underpowered amp will probably cause more problems than having a more powerful amp that is not running flat out. 200-300W amp would be ok, but I would suggest going for the biggest you can afford. If you crank up the volume on the smaller amp you will probably get a fair amount of distortion, which may actually damage the speakers. A larger amp will not give as much distortion for the same loudness/volume and give better control of the speakers for a tighter bass..
Oct 31, 2007 | Hitron 2 12in Subwoofers loaded in...
Car Audio & Video Logo
200 people viewed this question
Top Hitron Car Audio & Video Experts
xxxxxx xxx
Are you a Hitron Car Audio and Video Expert? Answer questions, earn points and help others
