Question about Exercise & Fitness
Treadclimber error codeH-23
I have had my Treadclimber for a little over 2 years, this is my second. I workout 100 minutes every morning. I lubricate the treadles when I am told to by the machine. I also lube inbetween times. I use the silicon based lubricant from Bowflex. The machine has been running hot (Smell). I typically start out at a 3.1 speed and work up to 3.7. Yesterday it locked out with an error code of H-23. I think the worn belts have increased the loading on the motor and resulted in burning up the motor. I haven't been able to locate that error code in either the owners manual or the shop maintenance manual. I can only reset the error code by unplugging the machine and plugging it back up. This morning it stopped and re-displayed H-23. I figured I need new belts, but with the vibration and noise I heard this morning, I am wondering if I need to get a new machine. How many miles should they last. I figure I have about 3600 miles on mine. Questions; what is H-23? Should I get a new machine, or new belts for this one?
4 Suggested Answers
SOURCE: bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Posted on Jan 12, 2010
  • 12223 Answers
SOURCE: treadclimber centering
Dear Sir:
ecalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the TreadClimber by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Posted on Feb 16, 2012
  • 12223 Answers
SOURCE: Bowflex Treadclimber TC20 error messages
Dear Sir:
This is a common error in this kind of machine. You must call to the company bowflex, and claim the problem. The hardware design is defective, they will replace.
However you will the same problem, if you do not act right now.
God bless you
Posted on May 10, 2012
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
Jan 27, 2016 | Bowflex TreadClimber TC10
What is the problem with treadclimber malfunction 84 u 1.1?
Try to run the treadmill @ 10kph. W/o using it. If the problem comes up. The problem is only the speed sensor..
and if the treadmill is in normal condition with out someone using it. @ 10kph. The problem is only lack of lubrication. You need to lubricate the treadmill before you using it. To prevent the motor from breakdown.
Jun 09, 2014 | Bowflex Treadclimber
Treadclimber error code H-23
Answer from bowflex service line. H 23 means "no tac signal". which means, a signal cable is loose or disconnected. OR the motor needs replacing...estimated cost $350 Canadian.
Apr 01, 2014 | Exercise & Fitness
Treadclimber comes on then in workout shuts off
Over heating, check the vents and the motor for dust and debris
Sep 17, 2012 | Bowflex TreadClimber TC10
Bowflex Treadclimber tc 1000 turns off
Problem could be low colant, water pump, fan not kicking on (bad sen or bad fan motor) radiator dirty,
so the Treadclimber not working properly.
I hope this helps u
Thanks for using FixYa.
Jan 29, 2009 | Bowflex Treadclimber
Error Code E1
I had the same error message E1 at 10 seconds according to the LCD display on an older Treadclimber TC1000. I called Bowflex 1-800-792-6784 and first thing they told me was to check the drive sensor on the back left corner of machine. It is two wires connected by 2 white connectors that snap together. The end of the sensor has a rubber cap that is supposed to be approximately 1/8 inch from the drive pulley. The rubber cap plugs into a small hole within the "firewall" of the drive pulley, but the end of the cap does not actually touch anything. They can email you a picture of it. If it ever gets knocked loose, the machine will register this e1 error, in some cases- hope this helps.getattachment.aspx&hm__qs=file%3d3d2f2ee0-2668-46ea-b32c-db049d56cb37.jpg%26ct%3daw1hz2uvanblzw_3d_3d%26name%3daw1hz2uwmdiuanbn%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253aimage002.jpg%254001c99c08.13bd6320&oneredir=1&ip=
Jan 24, 2009 | Bowflex Treadclimber
Exercise & Fitness Logo
239 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
