Question about HP 35s Scientific Calculator
Extremely short battery life
I've purchased two new HP 35S calculators in the last two months, and battery like has been extremely short (< 1 month) in each. Is this a know problem area?
4 Suggested Answers
  • 6 Answers
SOURCE: incorrect claculation
I get an answer of 366.91 in my 12C as well. You might try either putting in a zero for FV before hitting the [PMT] key, or clearing your registers before doing the problem, as you may be picking up an old value from a previous problem in the FV register.
Posted on Jan 30, 2008
  • 7993 Answers
SOURCE: how to fix a none responsive button in hp 35s calculator
Resetting the Calculator
If the calculator doesn't respond to keystrokes or if it is otherwise behaving unusually, attempt to reset it. Resetting the calculator halts the current calculation and cancels program entry, digit entry, a running program, a SOLVE calculation, an ∫ FN calculation, a VIEW display, or an INPUT display. Stored data usually remain intact.
To reset the calculator, hold down the C key and press GTO . If you are unable to reset the calculator, try installing fresh batteries. If the calculator cannot be reset, or if it still fails to operate properly, you should attempt to clear memory using the special procedure described in the next section. If the calculator still does not respond to keystrokes, use a thin, pointed object to press the RESET hole.
The calculator can reset itself if it is dropped or if power is interrupted.
CLEARING the MEMORY
If the calculator fails to respond to keystrokes, and you are unable to restore operation by resetting it or changing the batteries, try the following MEMORY CLEAR procedure. These keystrokes clear all of memory, reset the calculator, and restore all format and modes to their original, default settings (shown below):
  1. Press and hold down the C key.
  2. Press and hold down the R/S key
  3. Press i (You will be holding three keys simultaneously)
  4. When you release all three keys, the display shows MEMORY CLEAR if the operation is successful.
Posted on Mar 03, 2010
jas247
  • 844 Answers
SOURCE: Hey I'm Elena. See, I bought
Welcome to FixYa!
Here's a list of things to do if your HP49G calculator does not turn on.
1. Replace the batteries. (which you have done already)
2. Press and hold "ON" then press "+" several times, then release "ON".
If chacracters still doesn't appear in the main screen, reset the calculator:
1. Press and hold "ON" then press "F3", then release both keys.
The calculator should reset. If not:
1. Insert the of a metal paper clip into the hole at the back of the calculator. Insert as far as it goes. Hold for 2 seconds then remove the clip.
2. Press "ON".
If that does not fix the problem, the calculator needs to be serviced.
Note: always use alkaline batteries.
I hope this helps.
Thank you for using FixYa!
Keep me posted.
Jas247
Posted on Mar 23, 2011
HP 35s in OCT mode, calculations don't work
There are two separate issues here.
Your calculator is in Algebraic mode. To switch to RPN, press MODE 5 .
Your calculator is also in Octal mode. To switch to Decimal, press right-shift 1 1 .
Mar 24, 2014 | HP 35s Scientific Calculator
Purchased the new anniverary version and after about 9 months it just would not turn on , previous units lasted about 10 years at 99 .00 dollars i need to fix this one
Having gone over half a year without a response to my query, I assume a new set of batteries solved the problem.
The Anniversary Edition 12C uses a much faster processor than the original 12C. The new processor also uses more current, and thus you won't get battery life as long.
Jul 15, 2011 | HP 12c Calculator
I have an HP G60-235X that I purchased a little more than a year ago. About 6 months ago, I began to notice less charge life in the battery and a very high temperature from the battery pack. Now, and...
You need a new battery. One or more cells is defective. Obviously it's unsafe to continue using a battery pack if it gets hot enough to cause burns, so remove the pack from the computer. You can continue to use the computer on AC power until you get a replacement battery.
You might try contacting HP to see if there's any kind of warranty accommodation they can make. I've found several mentions in various forums about batteries in similar models going bad and that HP replaced them, but they were all within a year of purchase. Can't hurt to ask, though.
Jul 09, 2011 | HP G60-235DX Notebook
My HP35s keeps flashing MEMORY CLEAR. I removed the batteries and reset it with a paper clip. Nothing works.
I'm not sure if it is the only solution, but I had the same problem and I replaced the batteries. My HP35S works fine now.
Previously, however, there was no "battery" annuciator on the screen. This calculator went four years without a bettery change. My HP48GII, on the other hand won't go two months without a change. Go figure.
May 11, 2011 | HP 35s Scientific Calculator
Had great battery life for about 1 month. Now, with very limited use during day, battery life is extremely short. Have turned off WI-FI, have dimmed the backlight, changed the screen theme. Still sucks...
you didn't care for your battery i think you had connected the charger for long time to mobile and remember dont charge your mobile before whole battery ends...
Feb 18, 2010 | RIM BlackBerry Bold 9700 Smartphone
Min eis an HP 11C. flashing 0.00
If the asterisk is flashing, the batteries you put in are not good either.
Sep 12, 2009 | HP 12c Calculator
Dead Monitor
I do not what type of inverter you have is it true wave? some inverters are cheep as they are not a true waves and they do effect the life of the Tv/Computers, etc. Tv still covered take it back and do not tell them that you connected it to inverter
Jul 25, 2008 | HP Compaq WF1907 Monitor
Short Battery Life
it is the matter of battery life time-nothing wrong
Aug 05, 2007 | Sharp EL-9600C Calculator
HP 35s Scientific Calculator Logo
Seeker5211
Seeker5211
