Oce tcs500 error 4563
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: I have TCS500 Oce plan
Hi.
The code is not reported in service documentation, but the problem is likely the encoder ruler.
Clean and check position and state of the encoder strip. This is the plastic ruler located behind the printheads, and it is the part that determines the position of the printheads.
Encoder Strip. Wipe clean with a lint-free cloth and alcohol only. Take extra care to not bend the strip.
In case the part is broken (you will notice), I think that it is listed as encoder ruler here. Call Oce to confirm before replacing.
If you think that the comment was helpful, then please do not forget to accept the solution. Your feedback is important for us.
Posted on Sep 21, 2010
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
Oce tds error code 12502
Error 12501, Error 12502, Error 12503, Error 12504, Error 12505, Error 12506, Error 12507, Error 12508, Error, 12509, Error 12510, Error 12511, Error 12512, Error 12513, Error 12514, Error 12515
Error codes related to External Paper Input Module
Oce VarioPrint 110
Oce VarioPrint 120
Oce VarioPrint 135
Apr 28, 2014 | Office Equipment & Supplies
Oce tcs500 scanner - error code 10514-246 scan failed. any solution for fix?
Repair of oce scanner with error code 10514-246:
The customer Service said that this error means there is not enough light reaching the camera and we have to let them replace the lamps. cost:1500€ :(
solution: i removed the backplate of the scanner (3 screws) and cleaned the lower mirror. it was that dirty that i nearly didnt find it. it is placed on the groud of the lower big hole behind the backplate.
After that i recalibrated the scanner and now it works fine again.
I hope this helps since there is no correct exlanation of this error on the web.
Nov 01, 2013 | Office Equipment & Supplies
My Oce Scanner has the 10514-246 error. Please help me !
my oce tcs500 error code 10514-246 start of scan failed
Sep 07, 2011 | Office Equipment & Supplies
What is a error m1104 on my Oce 31x 5e
From what I gather from Oce' this is a "Master Cylinder Error". It's an internal issue that a tech needs to come out repair. Attempting the repair yourself (if you are looking at doing it yourself) will actually void your service contract with them.
Jun 03, 2010 | OCE 3140 Copier
Error code E020 0181 on oce cs115 how do we remove the code
Hello sir; Try to replace yellow color developer and then running"stir" or "install". should removed the error code.
Oct 09, 2009 | OCE Office Equipment & Supplies
OCE TDS600 Error Codes
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC.
Jul 13, 2009 | OCE Office Equipment & Supplies
Oce7050/error code 2205
what is oce 9400 error code 0813 ?
plase help me??
msmSAS@YAHOO.COM
Dec 20, 2008 | OCE 3140 Copier
137 people viewed this question
k24674
