When the labels print there is a gap in the print so the labels wont scan
I have cleaned the printed head
Inky
  • 691 Answers
SOURCE: problem with print outs from printer
Hey eastman You can do a manual cleaning using some kitchen paper and a little solvent and a small plastic bag. The first thing we need to do is get the head away from its parking position. Switch on the machine and when the head has moved away from its park position, remove the power lead. With the top of the machine open, you should be able to move the print head carriage by hand. Look to the right where the head carriage is normally parked and you should see the pump cap area. It will be a black looking spongy pad covered in ink. Now take a piece of kitchen paper and fold it over a couple times to make a pad approx 3"x1". Now lay this pad over the top of the pump cap and fold the left edge down toward the base of the machine as in image one (the tissue is the yellow bit in the image) Now take a syringe or similar and put some solvent into it. The solvent I use is JR Ink Jet Cartridge flush as seen on ebay and the like. If you have any ammoniated window cleaner like Windex you can use this. Put the solvent onto the tissue making it quite damp, but not totally soaked. Manually move the print head GENTLY back to its park position. The pump cap will try to raise up to meet the bottom of the print head as you move it back. Be careful no to force it or you may break something. What we are trying to do is bring the solvent dampened pad into contact with the print head. Once located, leave the pad for 5 or 10 minutes whilst the solvent does its trick. Now move the head away from park - again being gentle. You should now see the pad is a horrible black lump of mush. Pick it out and put it in the plastic bag ? where a glove or use tweezers or pliers. Repeat the process again but this time let it to soak for just about 1 minute. You should now see the individual ink colours soaking into the pad. If the pad is still black, repeat the process a couple more times. Once you have some evidence of the individual colours you can run a head clean via the driver or printer control panel. Then print a nozzle check sheet and if all has gone according to plan you should have a full complement of lines. This method is applicable ONLY for loss of a few lines on the nozzle check sheet. If you have loss of all the lines in a single or multiple colours, you need to investigate further. It is possible that the pump has failed, the pipes are clogged or something else is causing the problem.
Posted on Mar 12, 2007
kevin000
  • 1847 Answers
SOURCE: epson 1280 wont print
hi i was tring to chat with you where u getting my messages
Posted on Jun 08, 2008
  • 5 Answers
SOURCE: Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Posted on Dec 05, 2008
  • 10 Answers
SOURCE: epson CX3650 printing gaps
Remove ink cartridges one by one and put it back in. If same thing happens, try to do head cleaning and nozzle checks consecutively from the computer.
Start -> Control Panel -> Printers & Faxes (Windows XP) / Printers (Windows Vista) -> Printer Icon (right click) -> Printing Preferences -> Maintenance
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on the patterns appear, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Posted on Jan 01, 2009
Joed911
  • 4338 Answers
SOURCE: HP J5680 is printing and scanning vertical gray stripes
The fix is on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00704831&cc=za&lc=en&dlc=en&product=3301296
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 03, 2009
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
Lables are printing, but they are duals and the lable on the right is not printing readable, very faint ink? cleaned the head, now what?
This could be a print head problem but without seeing it it is hard to say can you scan the labels and let me see them? this help with diagnosis.
Aug 22, 2011 | Zebra Eltron TLP 2844 Thermal Label...
I have been using an epson stylus color 880 for years. One day it would not print. Replaced the cartridges and still will not print. It goes through the printing procedures but nothing shows up on...
The print head nozzles may be clogged. From the Utility section found in the EPSON printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, try replacing the ink cartridge. Any ink cartridge installed into the printer must have a blue label on top of it. If the blue label has been removed from the ink cartridge, do not install the cartridge. Using an ink cartridge, which does not have the blue label on it, may damage the printer. Caution: If you have already installed a cartridge which is missing the blue label, or if a previously installed ink cartridge was missing its blue label at the time it was installed, and now head cleanings do not help the nozzle check pattern to print completely, your printer may require service and you should contact the EPSON Connection for further assistance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 08, 2011 | Epson Stylus 880 InkJet Color Printer
Gaps in barcode with Zebra S4M
The gaps run in the direction of the label feed? You have a bad printhead. Bad dots on the printhead prevent it from printing your format in the areas that you see the blank lines.
There is no easy fix other than replacing the printhead. You can prevent (or actually prolong the time between failures) in the future by periodically cleaning your printhead. It's recommended that you clean the printhead after every roll of labels. The printhead is underneath the hinged assembly. Over time, ribbon or adhesive from the labels builds up and causes dots to go bad - creating the blank lines you see. Clean your new printhead with rubbing alcohol.
May 15, 2010 | Zebra S4M Thermal Label Printer
By gaps, do you mean a "void" area ? Over time, the elements on the printhead will wear down and finally they won't transfer heat to the ribbon. This causes a gap or void area. Usually the elements go out one or two at a time. If the area that is worn out is supposed to be printing bars for the barcode, this will cause the scanning problem you are experiencing.
The best way to see if elements are worn out is to design a label that has a thick solid black line across the label or a solid black box. You will see white vertical lines in the areas where elements are worn out. Another method would be to use the widest and longest label you have and print a 'pause" test label. This is done by turning off the printer, pressing and holding on the PAUSE key while turning on the printer. Hold the pause key for 10-15 seconds and when the printer is done with it's power on self test, it will start printing out a test pattern label which includes a nice black area where you can look for the white vertical lines.
Hope that helps !
Mar 30, 2010 | Zebra S4M Thermal Label Printer
I get 2 labels(1 with data and 1 blank)for every label printed
THE LABEL SENSOR IS NOT SENSING THE BEGINNING OF THE NEXT LABEL
Clean the photo eye that senses the label gap with a q tip and alchol
Open side door release print head and remove label stock you will see small photo eye clean
put printer in manual mode( switch 1 on to and 1 on botom on
turn printer on it should advance one label and hit skip it should advance another
put back in computer mode
should work now if it still skips check yur label desigh=n software and label mode (continuous or sense label)
Best of luck to you
Dec 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
Poor Quality Print on Zebra 105SL direct thermal
How many labels has the printer printed? Because it sounds to me like you just need to replace the print head.
They are around $400 from whomever your supplier is, and very easy to replace.
Nov 12, 2008 | Zebra 105SL Thermal Label Printer
Epson stylus cx3200 all in one ink jet
You cannot seem to print properly. You can try and do the head cleaning.
For windows
just click on start / settings / printers & faxes
Check on the example below:
Right click on the printer icon then left click on printing preferences
Go to maintenance and click on head cleaning
After the head cleaning press on print nozzle check pattern. Check the patterns and see if there is gaps or breaks on it like this example:
Note: If there is gaps or breaks it explains why you cannot print properly because inks are not distributed correclty. If there is no gaps or breaks it means the printout will be fine.
For Mac users
Then click on confirmation then press Next. It will print on the nozzle check pattern.
Oct 14, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Bad color
Follow these steps to clean the print head using the control panel on the printer:
1. On the Main Menu, press UP or DOWN arrow to highlight More Options, then press OK.
2. Press UP or DOWN arrow to highlight Maintenance, then press OK.
3. Press UP or DOWN arrow to highlight Clean Print Head, then press OK.
4. Press OK to begin cleaning the print head.
*NOTE: The cleaning takes several seconds, during which the message 'Cleaning print head. Please wait.' appears on the screen.
5. When cleaning is complete, you see a message asking if you want to print a nozzle check pattern. To see if the nozzles are clean, load a sheet of photo paper, then press OK to print the nozzle check.
6. Check the pattern to see if there are any gaps in the lines. If there are gaps, press OK to clean the print head again. If there are no gaps, press Cancel to go back to the PictureMate Main Menu.
Jan 03, 2008 | Epson PictureMate (C11C556001) InkJet...
113 people viewed this question
jasbo
jasbo
