I need networking cables, which cables are best for use.
High quality & standardized products Bulk Cat5e, Cat6 Ethernet Networking Cables, Cat5e Jacks, Cat6 Jacks, Wall Plates, Connectors
  • davidcameron
    davidcameron Apr 08, 2014
    Yaa i've Cat5e cables are good but tell me about the features of Cat5e Cables
    Genius:
  • 1,552 Answers
CAT6 cables & jacks are better than CAT5E.
CAT5E cables & jacks are better than CAT5.
CAT5 cables & jacks are better than CAT3.
CAT3 cables have problems going faster than 10Mbit/second.
CAT5 cables support 100Mbit/second, and seem to work with 1000Mbit/second ("gigabit") devices.
Posted on May 21, 2014
How do i install?
This device is a plug and play device and doesnt need any configuration before installation.
You need CAT6 ethernet ( copper LAN cables) to connect the switch to the other device from where you want to extend/expand your ethernet.
Best Regards
Dec 31, 2010 | Dynex DXESW5 5Port Ethernet Switch
I have two des-1005d network switches. i want to communicate betwwen them with a cat5e cable. the cable is made as cross through and distance is about 70 meters. with one switch pc is connected and at...
Max distance for Cat5e cable is about 100M, but that is the best case scenario, essentially a straight line, down a building. If you have any kind of interference, like flourescent lighting, high voltage lines running parallel to the ethernet cable, the distance will be much less than 100M. Although it looks like you have 60 feet to spare, anything interfering with the cables will cut the signal down. Try to move the switches closer together, make the cable from pc to switch longer and ADSL modem to switch longer and cable between switches shorter. Use a known good straight through ethernet cable, as modern switches don't require crossover cables.
From Wikipedia: http://en.wikipedia.org/wiki/Category_5e#Maximum_cable_segment_length
According to the ANSI/TIA/EIA standard for category 5e cable, (TIA/EIA 568-5-A[5]) the maximum length for a cable segment is 100 meters (328 feet). If longer runs are required, the use of active hardware such as a repeater, or a switch, is necessary.[6] [7] This 100 meter limit is all inclusive. According to some authors,[who?] the practical limit for permanently installed cable is about 90 meters, leaving 5 meters at each end for the patch cables that connect the end equipment to the wall panel.
Hope this helps.
Sep 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Rewiring a house putting in a net work for the future . what cable cat5e ,cat5e screened , cat6 , cat6 screened . would cat5e screened be better than cat6 unscreened ? cables away from mains ,
I'm guessing when you say screened and unscreened you mean shielded or unshielded. Shielded wire is used when there is a higher possibility of electrical or RF interference. In a typical household those type of interferences are uncommon. As far as the Cat.5e or Cat. 6 decision, Cat 5e is tested to 150 Mhz. compared to a 250 Mhz. rating on Cat. 6 therefore with future speeds in mind I'd go with the Category 6.
Aug 25, 2010 | Dynex 7' Cat 6 Network Cable - Gray
Enthernet cable
Ethernet 100/1000MBPS cables need to be Cat6 cables. These can be purchased at your friendly computer shop or over the Internet.
Do a Google search for Cat6 ethernet cables on the Internet.
Oct 23, 2009 | HP Module Enthernet 100/1000MBPS 1-PORT...
Max cable lenght for cat 6e cable
The cable standard provides performance of up to 250 MHz and is suitable for 10BASE-T / 100BASE-TX and 1000BASE-T / 1000BASE-TX (Gigabit Ethernet). It is expected to suit the 10GBASE-T (10Gigabit Ethernet) standard, although with limitations on length if unshielded Cat 6 cable is used. Category 6 cable can be identified by the printing on the side of the cable sheath.
Cat5e is suitable for 10/100/1000baseT ethernet for 100 meters, when properly installed.
Cat 6 is also good for 10 gig ethernet for 37 meters, but that is pretty short, unless just in a server room.
There is no Cat 6e, but Cat 6A will be good for 10/100/1000/10GbaseT ethernet for 100 meters.
Unshielded Twisted Pair has no ground shield around the wires. It is the standard in the US, where most network standards were defined. There are extensions to the standards to allow for the more common in Europe, Shielded Twisted Pair.
Some Cat-6 cables are too large and may be difficult to attach to 8P8C connectors without a special modular piece and are technically not standard compliant. If components of the various cable standards are intermixed, the performance of the signal path will be limited to that of the lowest category. The maximum allowed length of a Cat-6 cable is 100 meters (330 ft) when used for 10/100/1000baseT and 37 meters (120 ft) when used for 10GbaseT. This applies for UTP cables only. Shielded Cat 6 and Cat 7 cables are capable of 100m.....sodeep
Jul 30, 2009 | Cables Unlimited CAT6 (UTP-7220) (UTP7220)
Network connections issue
Have you tried assigning a static ip to the computer.
Jun 20, 2009 | HP ProCurve 2524 24x10/100 Mbps Networking...
What is UTP CAT 5e cabel?
This 1000 foot, spool-boxed roll of grey Cat5e bulk cable is a must-have for extensive networking. This unterminated and UTP (unshielded twisted pair) cable is perfect for a plethora of networking applications.
Cat-5e, enhanced Cat-5 cable, is the standard for modern networking - enabled for far end crosstalk and compliant with up to 1000BASE-T standards. This unshielded cable comes in its own spool box and is connector free, giving the user the freedom to customize the length, wiring, and application.
This cable is 1000 feet long and are marked at every foot (marked 0001 - 1000 at each foot).
Wire the cable as either a patch or a crossover cable, use it for Ethernet or any other data transfer applications. Sewell Direct works hard to bring you affordable Cat5e bulk cable solutions.
Jan 13, 2009 | Intellinet Active Networking CAT5e UTP...
Dynamode ht809stp
just plug the power connection
and connect the network cables. and restart the computer.
Summary for Dynamode (HT809STP)
Dynamode products have earned a worldwide reputation for quality. The Dynamode hubs products utilize state-of-the-art design and ASIC-base hardware for high reliability.Dynamode offers the 8-port Ethernet Hub which, in compliance with IEEE 802.3 10 BASE-T standard, is a multi port repeater used in the twisted pair Ethernet Network. Featuring 8 RJ-45 twisted pair ports for twisted pair wiring, one AUI port for thick cabling and one BNC port for thin cabling, it allows to connect up to 8 devices (such as twisted pair Ethernet card), an Ethernet Transceiver and a Tee connector.
Sep 16, 2008 | Dynamode (HT809STP) Networking Hub
Computers & Internet Logo
243 people viewed this question
David Payne
David Payne
