Question about AB Soft PXL Soft Dg Foto Art - Gold Full Version for Mac
When cropping in dg photo art programme stups running
When i crop a picture and either exit crop or enter programmes stops and asks to reopen
Says"object can't crop" when I select crop option, why?
Could be that it is protected. Or that they programme simply can't handle the object, or you are in the wrong mode to crop it.
Nov 01, 2015 | Computers & Internet
After cropping and saving a picture, how do I revert it back to the original photo?
Hello Karen,
You need to go to the original picture file. As you can only undo cropping or other changes while the undo option in edit menu is active, usually early on when file is open in programme editing with. Just after doing the cropping.
So hopefully you didn't crop picture then write over its original file. You saved it { save as } to a new file. If you did overwrite original file after cropping; then you will need to relocate this original picture from the source it came from to access original composition, size etc. If from your camera then simply re transfer to your computer & open it there.
If you're not sure about where it is on your computer then you can do an open search by typing in part of the file name or file format { part after the dot in filename & go through the results lists to try & locate it.
Hope this helps.
Dec 18, 2012 | Microsoft Digital Image Pro 10
Youtube didnot open
Try exiting and reopening your browser. If that doesn't work, clear you cookies and cache and history, then exit and reopen again and enter the link.
Nov 29, 2012 | youtube.com
How can i crop a picture of a coin around its edge,not a square
Hello
Im guessing you have extracted the picture from ur cam to your PC? The most efficient way to do this would be to use a programme such as photoshop, which would allow you to cut out the exact image you want. If you dont have photoshop, a quick and cheap solution would be to use Paint which almost every standard PC will have, usually found under all programmes & accessories. Simply paint white around the coin and save the pic.
Hope this helps
Apr 02, 2011 | Cameras
CANT FIND MY DIRECTIONS-HOW DO I SCAN A PICTURE?
Hi k_eddings06,
Based on your concern, i suggest tyring these steps:
1. Place the item you intend to scan in the appropriate place.
2. Locate the HP Solution Center programme, which may be accessible from a desktop icon.
3. Open up this programme by double-clicking on the icon, to enable you to scan and modify your picture.
4. Click on 'Scan Picture' Click 'Scan', and 'Accept' on the next screen to begin scanning the image on the printer.
5. You will then be able to modify the picture, crop as desired, and export to various programmes and formats as desired.You may also be able to print directly from this screen if required.
Hope it helps.
Thanks for using FixYa
Best regards,
Reyjoshua07
Jan 21, 2011 | HP PSC 1510 All-In-One InkJet Printer
Hi, im trying to click to crop my pictures,but when i want to save and exit, it doesnt work.What is wrong ?
You have posted this in ROUTERS, and dont mention what software your having problems with.
More info please
Aug 20, 2010 | Computers & Internet
Dimage Z6. How do I save a cropped picture onto the camera memory card? I can do it on my Sony Cibershot. Can I do it on the Dimage (no manual or CD provided with second-hand camera).
After you have cropped your picture, just press the enter button. It will ask if you want to save it. It will be saved as another image. You will not lose the original.
Jan 03, 2010 | Konica Minolta DiMAGE Z6 Digital Camera
HOW TO RESIZE PICTURE AT ADOBE??
To resize an image with Adobe Photoshop Elements 4.0 you first need to open the image. After opening the image you will select Image---> Resize---> Image Size. If you select canvas size the image itself will not change.
At the Image Size menu, make sure that the "resample" check box at the bottom of the menu is selected. Then enter the desired resolution and width/height. For printing an image, a resolution of 300 pixels/inch or more is desirable. When images are intended for computer or web display, 72 pixels/inch (sometimes referred to as dpi) is sufficient. You can set the image size in pixels (at the top of the menu) or in inches (at the lower part of the menu). Once the desired sizes are entered you only need to press "ok" for the change to be made.
Photoshop Elements also offers another method of resizing an image. You can use the "crop" function to resize your image quickly. The crop tool looks like a small square with overlapping edges and can also be accessed through the Image menu bar at the top of your screen.
Once the crop tool options bar opens, select "custom" and then enter the desired height/width and resolution. To crop to specific pixels you must enter the letters "px" after the size number in the width/height boxes. If only one dimension is important you can enter information in only one box and let the other dimension be determined purely by where you place the crop line.
After entering your preferences you will click and drag the crop tool across the image to select the part of the image you wish to keep.
Jul 17, 2009 | Adobe Photoshop 7.0 for PC
Setting clock
First select calender press enter. to set date press stop then use < arrows > to set year, up and down to set month, press stop to comfirm. Then use navigation buttons to select cuarrent date and press enter to confirm. To exit press menu button.
Use nav buttons to select clock, press enter to confirm the clock display will appear.
To set clock press menu for custom set up. Use down arrow key to find "set time" right arrow to kighlight set time press enter, then arrow keys to set time then enter then left arrow all the way to the left then down to exit, athen enter.
Hope this helps.
chuck32
First hit setup then find settings, then enter. Use arrow keys to change time, then enter
Feb 03, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Photoshop 7 Croping
I use photoshop 10 but i believe there is not much difference in cropping. What you do is select your crop tool, with it selected enter your dimensions in the W and H text boxes at the top. In the box you would type in the corresponding box; "5in" or "7in" without the quotes. When you have entered your dimensions your crop tool will draw a shaded box as you drag it on the workspace that will be presized to your entered dimensions.
Hope this helps
Dec 04, 2007 | Adobe Photoshop 7.0 (321115627)
AB Soft PXL Soft Dg Foto Art - Gold Full Version for Mac  Logo
20 people viewed this question
Top AB Soft Computers & Internet Experts
David Payne
David Payne
Are you an AB Soft Computer and Internet Expert? Answer questions, earn points and help others
