Question about Northstar Garden
New thermostat don't work
I put on a new thermostat and it does notwork burner ison all tne time
Hello, we had central air conditioner installed last October. We turned our unit on for the first time and the outside unit shuts down but the air handler continues to blow air and never shuts down. ...
Hello, if the blower motor runs continuously and does not shut off at tne thermostat then the relay on tne integrated control board is bad. Only option is to replace the control board
Jun 28, 2011 | Goodman CKL36AR36 Air Conditioner
When the AC cuts off the blower fan runs for 90 more seconds, I have a Honeywell RTH8500D thermostat, I really don't like that, I live in Texas where the AC runs all the time.
Hello, usually tne blower runs longer to get all the cold air out of the air ducts, same thing happens in heating evcept it's warm air. You can change the blower timing by adjusting it on the integrated control board, it will say blower off timeing, this is what you use to adjust the blower timing. However, 90 sec is the least the blower will run on most furnaces.
May 24, 2011 | Heating & Cooling
Furnace not firing up...thermostat said low battery ...installed new batteries. Green (LED) light indicating power to thermostat is off. Furnace still doesn't fire up.
1) Turn the fan to on and if it runs you know that you have line
voltage to furnace and 24volts to the thermostat.
2) You could turn the furnace off remove the doors and get to the
control board. If you can find the Thermostat wires on the board
mark and remove them. If you have a typical Furnace and you
have some electrical background put a jumper wire between
terminals R and W,put the doors back on-there is a door switch
that if the panel is not put back on-it will not run. Turn your power
back on.
3) The Blower motor may come on, the induced draft blower should
come on, the glow coil should glow, the gas valve open and the
burners should come on and the unit should run.
4) If all of this happens, then you have a thermostat problem or you
have bad thermostat wires.
5) If nothing happens then you don`t have power to the furnace or the
little fuse that protects the transformer is blown.
Good Luck
Jan 08, 2010 | Honeywell Electronic Programmable...
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Wont turn on
Its not getting enough juice from the battery. Get a new battery. You can only re-charge a battery so many times. Many times people ruin the battery by not fully charging and draining a battery. The battery that came with this cam has a memory. Get a new battery.
Mar 08, 2009 | iSonic SNAPBOX DV566 Digital Camera
GKS91155DXAD Not finishing cycle
Check the heat anticipator setting on the thermostat if its a mercury type thermostat. It may not match the proper amp draw. Take the cover off and it is a little metal lever. Try different adjustments to see which are better. If its a digital thermostat it may have an internal setting. There are several other possible reasons this could happen but that would be the most likely. for more infor on self diagnosis or the like check out my fave website Ra-Jac Air Conditioners and Heaters TX for repair information.
PS: If its a new installation it should have a one year warantee so call back the person who put it in. If you did it yourself be extremely careful gas furnaces can be dangerous. You might want a service person to check the job out for safety hazards. Good Luck with it.
Feb 28, 2008 | Heating & Cooling
Garden Logo
32 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
