Question about HP Laserjet P3015X Printer
HP Laserjet p3015 all lights blinking
Trying to configure the new printer but started and all lights on it is continously jumping to each other and blinking and no idea what is the issue where Cartridge is fine, paper tray is full and powered on. any idea?
  • 25 Answers
SOURCE: My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Posted on Aug 14, 2008
shadiabed
  • 72 Answers
SOURCE: Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Posted on Jan 08, 2010
Milleniumboy
  • 106 Answers
SOURCE: Paper Jam HP LaserJet 1300
I hope this will be of Help for the HP LaserJet 1300 Paper Jam Trouble Shooting:
  1. See the product user guide for information about clearing jams from the printer.
  2. Make sure that the paper guides are adjusted properly. Slide the guides against the sides of the stack in the main input tray or the priority input tray to center the page. Make sure that the guides are not adjusted too tightly.
  3. The media input tray might be too full. Remove some of the sheets.
  4. Make sure that the media being used meets specifications. Click here to refer to "Media specifications" for more information .
  5. Make sure that the media being used is not wrinkled, folded, or damaged.
  6. Make sure that the printer is clean. See the product user guide for information about cleaning the printer.
  7. If printing to the straight-through output path, close and open the door again to make sure that the green release levers are closed.
  8. The paper might not have been removed from the main input tray before the tray was refilled. Always remove paper form the main input tray before refilling it.
  9. Output capacity might have been exceeded in the paper output bin. Do not allow more than 125 sheets of 20-lb (75 g/m2) bond weight paper to fill the paper output bin (less for heavier paper).
  10. The pickup roller or printer separation pad might be dirty or damaged. Clean or replace the part. (See the product user guide for information about cleaning and replacing the pickup roller and printer separation pad.)
Posted on Apr 03, 2010
SOURCE: My HP Laserjet 2430dn makes a grinding noise after power on.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
Posted on Jan 21, 2011
SOURCE: configure ip adress to hp
This model does actually have embedded network functionallity.
To configure the IP Address, follow the menu map as below:
1) - (4) I/O
2) - (4-2) Embedded JetDirect Menu
3) - (4-2-2) TCP/IP
4) - (4-2-2-1) Enable (Make sure this is 'On')
5) - (4-2-2-3) IPV4 Settings
6) - (4-2-2-3-1) Config Method (Auto = DHCP, Set to Manual in order to specify an IP address.)
7) - (4-2-2-3-2) Manual Settings (This is where you can set the IP Address, Subnet Mask, and Default Gateway.)
Posted on Jun 07, 2011
How do I reset hp laserjet p3015 to factory settings
  1. Press the Menu button .
  2. Open each of the following menus. Press the down arrow to highlight it and then press the OK button to select it. CONFIGURE DEVICE. RESETS. RESTORE FACTORY SETTINGS.
Dec 04, 2016 | HP P3015 Laser Printer
LaserJet P3015. Why is it printing dark background?
Hi Boateng Samuel,
I would be happy to help you with your P3015. Although the enterprise printer models are out of my support scope, I was able to find you the appropriate document specific to print quality. Please use the following document to troubleshoot the issue:
HP LaserJet P3015 Printer Series Solving Print Quality Problems
Best of luck, I hope this helps.
I work on behalf of HP.
Jul 17, 2015 | HP Office Equipment & Supplies
P3015 hp lasser printer 49.4C01 error proper solution
Sounds like a bad formatter. I would try a firmware upgrade first and if unsuccessful, would replace the formatter. These formatters are infamous for failure.
Feb 22, 2015 | HP RB1-3015 LaserJet 4L Laser Scanner...
Hello! I have a HP P3015 LaserJet Printer show
you need to go to the printer on computer, then to the port settings and use the usb dot 4 port - will be that
Oct 22, 2013 | HP P3015 Laser Printer
Hp laserjet p3015 not printing
The printer will have a message in the screen saying roughly how many pages are left in the toner cartridge if the toner is running low. Try printing a "configuration page" by pressing "ok", arrow down to "information", arrow down to " print configuration page", then press "ok". If this page prints you still have toner left.
Dec 12, 2012 | HP Laserjet P3015X Printer
I want to reset my printer, HP Laserjet P3015 to default, like as if it were a new printer with default settings.
Press the Menu button c01779038.gif , select the CONFIGURE DEVICE menu, and then select the RESETS menu. RESTORE FACTORY SETTINGS. Clear the page buffer, remove all perishable personality data, reset the printing environment, and return all default settings to factory defaults. Hope this helps.
Aug 06, 2011 | HP Laserjet P3015X Printer
Configure ip adress to hp laserjet p3015
1) - (4) I/O
3) - (4-2-2) TCP/IP
Apr 28, 2011 | HP P3015 Laser Printer
HP Laserjet P3015X Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
