Question about Epson WorkForce WF-2530
Scanned document is 8.5 x 14 even though setting says 8.5 x 11
The printed scans are printing out on 8.5 x 11 but appear shrunken. The setting in the pdf file says it scanned as 8.5 x 14 but the scanner settings say 8.5 x 11
    Problem Solver:
  • 14 Answers
You probably have the PDF programme page size settings incorrectly set to the larger size = why only able to print some of the length. As a solution, use a photo programme (Photoshop, Elements or the excellent FREE Faststone Image Viewer to resize the image so it will then print on your paper but so doing will reduce, slightly, the width to suit the revised shorter length to preserve the proportions/balance between length and width.
Posted on May 06, 2014
How do I fix a printing problem where the error message load tray 1 keeps appearing?
You Really need to have this Machine Cleaned. there is too Much Paper dust On the sensor
Jun 06, 2015 | Xerox 6505/dn Workcenter 6505dn Color...
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
Our HP Deskjet 6500 wireless copier is stuck on copying 8.5 x 11 about 1/4 of the size smaller...shrunken copies, AH! How can we reset the copier. Thank you April
Thank you for posting your printer problem to FixYa.
  • On the document you want to print.
  • Go to FILE, PRINT (or PRINTER PROPERTIES)
  • The Print Dialog Box will open
  • Click the EFFECTS tab
  • Check the option that says Print document on:
  • Choose the correct paper size from the pull down menu
  • Uncheck the option that says Scale to fit.
Keep me posted.
Jas247
Aug 19, 2011 | HP Deskjet 6500 Series
Put scanned document on my computer to print afterwards if necessary and read on my computer
I am unclear on your problem but in general..you use the scanning software that came with the scanner scan the document and save the scanned file to your computer as a pdf file for documents or tiff or jpg for photos, (you set the type of file you want to save with the software options)
To print afterwards open the pdf with acrobat and print it
Did that answer your question?.
Mar 07, 2011 | HP Scanjet 5590 Flatbed Scanner
I have canon image runner 3035. I want to know to know how to scan
you can find manuals here:
http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/imagerunner_2230_2230g_2270_2830_2870_3530_3025_3030_3035_3045_3530g_3570_4570/imagerunner_3035#BrochuresAndManuals
Jul 25, 2010 | Office Equipment & Supplies
I am using epson stylus tx110 and i tried to scan and copy a document but there is always appear a black on the the side of a paper when it scanned and printed, how can i remove or set it on full image?...
when you are scanning do set the flat bed cover as flat as you can,?? because when you scan a document with the lid slightly open black lines or shadows might appear. also check the settings of your printer.
Jun 02, 2010 | Office Equipment & Supplies
Reds come out yellow, and facial tones are too red
It sounds like your machine needs to be calibrated. First try turning the machine off and unplug it for about 15 seconds. When you turn it back on it will reboot its software and stabilize the image units. If this does not correct the problem you can perform a gradation adjustment by:
1 Load 11 × 17 L-size paper into the 1st drawer.
❍ Letter C, A3 L or A4 C can be loaded instead.
2 Press the [Utility] key.
3 Touch [Admin. Mode].
4 Using the keypad, type in the administrator code.
❍ Touch [Enter].
5 Touch [Gradation Adjustment].
The Gradation Adjustment screen appears.
6 Press the [Start] key.
A test pattern is printed.
7 After the test pattern is printed, a screen appears, indicating how
the test pattern must be loaded.
8 Place the printed test pattern on the original glass.
❍ Align the edges of the printed test pattern with the document scales.
9 Place into the 1st drawer 10 more sheets of blank paper of the same size as the printed test pattern page.
10 Close the original cover, or the reverse automatic document feeder if it is installed.
11 Press the [Start] key. The printed test pattern is scanned.
12 Based on the scanned image, the gradation levels are automatically adjusted.
After the gradation levels are adjusted, the Admin. Mode screen appears again.
13 Repeat steps 5 through 12 three times.
14 Touch [Exit], and then touch [Exit] in the Utility screen.
May 11, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Black stripe on scanned documents
The HP Scanjet IIP scanners are supported in Windows XP and the drivers included on windows XP CD.
If you can’t manage download it from Windows XP operating system please try to update your Operating system then try again.
All the best.
1. Try going to the bottom of any word document.
2. Click on the language tab (will show current language, eg. "German").
3. Select the desired language (eg. "English (U.K.)"). The select the "Default" button (to make it the default language for every future document).
You can also check this link to get detailed information.
Make sure the document lies perfectly straight on the document table.
If you're printing on glossy paper, prints may be scratched if not handled properly. Don't place objects on top of your prints, and be careful not to scratch them with your fingernails. For best results, frame your prints under glass.
A moiré is a cross-hatch pattern that may appear in a scanned image of a printed document. It is caused by interference from the differing pitches in the scanner's screen and the halftone screen in your original.
  • Select the Descreening Filter check box in EPSON Scan's Home or Professional Mode window. In Professional Mode, set the Screen Ruling of the Descreening Filter setting to an appropriate setting for your document and deselect the Unsharp Mask Filter setting. See Adjusting the Color and Other Image Settings for instructions.
  • Select a lower Resolution setting. See Selecting the Scan Resolution for instructions.
You can also check this link (manual) to get detailed information.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 27, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Scanned documents are very light
I have found that when scanning b/w documents, its helpful to start with a black and white copy, not a grayscale, pen written, or printed form a printer in grayscale mode copy, but a true black and white on the copier or fax copy. The scanner doesnt read shades of black so well and when scanning multiple page documents, my pixma tends to scan in lightly. I havent found a piece of software to do just this, batch darken what has been scanned (at least not for free). Copying before scanning is the work around. Hope this helps everyone who's had this problem. It also doesnt hurt to darken what your scanning down a notch when copying
Mar 21, 2008 | HP PSC1510 Printer/Scanner/Copier...
Epson WorkForce WF-2530 Logo
59 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
