Samsung wt7400 I had purchase washing macine samsung WT 7400 in 2004. Now washing machine metallic body got rusted & damaged from bottom of washer. So washing machine doesnot working. I want got some solution for easy running of washing machine. Is new metallic body available in market or this machine spares fitted in another model washing machine.
SOURCE: Samsung silvercare washing machine model no: WF337AA
Samsung told me to unplug for 9 minutes, then plug back in, for resetting.
Posted on Jan 20, 2008
SOURCE: samsung washing machine carbon brushes (b1215j)
yes i have this carbon brush
how can i send u this carbon brushes .
where u live and from?
my e-mail address is
identity_ahsan@yahoo.com
Posted on Jan 30, 2008
jsrock516
  • 5911 Answers
SOURCE: Error code F09/Whirlpool Duet front loading washer
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
Posted on Apr 14, 2008
Sea Breeze
  • 4654 Answers
SOURCE: What's value of Sears Kenmore washer, model 110.49722992?
$55.00 US dollars
Posted on Feb 26, 2009
SOURCE: Kenmore Washing Machine. ......Model 25842400
You can go on to sears website to Manage My Home and pull up your manuel for free. Just have your model number.
Posted on Sep 24, 2009
I have deep rust appearing around the bleach port. machine is only one year old. WHY is it rusting ?????
Samsung does not recommend the use of chlorine bleach in this machine. The bleach port is intended for color-safe bleach only. Chlorine bleach is an oxidizer that will accelerate the corrosion process of the drum, which is what you are probably seeing. The users guide for your machine states specifically that you SHOULD NOT put liquid chlorine bleach into the bleach port.
Aug 13, 2014 | Samsung WA5471AB 4.7 Cu. Ft. Top Load...
Whirlpool Washing Machine Extra Large Capacity Washer
It could be fouled with dirt / crud buildup. The metal basket would have to be taken out which requires special spanner wrench. Filter which is supposed to be self cleaning is on bottom of metal basket.
Aug 24, 2017 | Washing Machines
The "floating drum makes out of round knocking noise in spin cycl
On the bottom of the washer tub is a "balance block?" that the bolt has loosened on. Have GE come repair it. We just had it happen to us as well. If you don't get it repaired it will cause more damage to the washer and then it won't be covered under the warrenty.
Jun 01, 2010 | GE Profile WPRE6150KWT Colossal Capacity...
Macine holding water and making strange noise
Remove lower rear cover on washer, remove large black hose on bottom of drum, and check the filter inside hose, also remove hose onto pump, and check the pump.
Please rate my solution.
Thanks.
Nov 02, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Macine filter is not working correctly
Sounds like you've been using fab softner? this builds up like tar on the washers metal bowl. All you can try is pouring a whole large bottle 2L of white vinegar into this washer and selecting the hottest and longest was cycle and hope this dissolves the build up on the outside on the bowl. Tip never use fabric softner again or use white vinegar instead.. Tell me how you get on please.
Oct 30, 2009 | Samsung Washing Machines
WHY IS THERE RUST IN MY WASH MACHINE DRUM
Hi
Thanks for using FixYa. Take out the clothes immediately after the washer stops spinning. Also clean the tub with a rust remover. This issue occurs due to bad drum bearing and it may be grease rather than rust. Although the tub is metal with porcelain coating and it wears around the edge of the holes first, leaving metal without porcelain. On spinning the centrifugal force pushes the clothes against the basket and some water sneaks into the holes. Due to this you may see the rust on clothes. If still the issue persists, then the tub is required to be replaced to resolve the issue. Please do rate the solution and revert for further assistance. Thanks Rylee
Sep 18, 2009 | Kenmore 24032\24036 Top Load Washer
Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
May 19, 2009 | Samsung SW62ASP Top Load Washer
We have a Maytag Neptune washer Model # MAH4000 AWW it is leaking from the front at the bottom of door. Water pours out like a water fall when it wants to rinse. Any ideas?
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: CJA931@FRONTIERNET.NET , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
Leaking whashing macine
you probably have a leak high up in the machine. take the top off, wash some blankets and see if you can spot the leak
Oct 16, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
