Question about LG WM1814CW Front Load Washer
Lg wd 1243fhb
I need to order a door for my lg washer.
2 Suggested Answers
SOURCE: Hi, I need to order door
There are many many online parts stores for washing machines and other appliances. You need to shop for best prices. Be prepared to pay extra for shipping and have a longer waiting period.
I know a local small business repairman who orders any parts I need at his cost and a smaller shipping cost. I don't have to wait as long and he is very helpful--if not amused--with my efforts at fixing things.
Go with the small business if looking locally. They can get any part the big stores can, and will often charge you less. Plus, the parts usually come in the next day.
Posted on Feb 14, 2011
My LG WM2101HW washer door will not lock. Sometimes if you shut the door just right, it will work. I ordered and replaces the actually door switch, but it still will not lock. What else can I do?
You say that you replaced the door switch, but you need to check that the spring of the latch hook inside the door is working properly, otherwise it does not hook properly and will cause these problems.
Jul 28, 2016 | LG WM2101HW Front Load Washer, White, 4.0...
Lg washer wm2455hw door won't lock. DE code flashes.
LG Washer Door or Lid Won't Lock - Model WM2455HW ...
www.repairclinic.com/...Washing-Machine/...-/LG-Washer-door-or-lid-...
LG washer door or lid won't lock? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Nov 15, 2015 | LG Washing Machines
My LG washer (Lg tromm Wm2377cs) is coming on by itself when the door is open. The panel stays lit, then eventually goes dead, only to come on again later by itself.
not just yet? still need to check other items? the timer, the push start? etc buying a new board may not solve ur issue less ur sure of the cause, the door actuator may be stuck closed however cant see how it would effect the start staying continually on so I would check both out at the least
Mar 08, 2013 | LG WM-2277HW Front Load Washer
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
Door latch wont unlock LG WM2455 Front Load Washer
You can also gain access from the back by removing the back panel...The top on this washer can also be removed..Remove the dispenser cover...Take a putty knife..Insert it in between the top cover and the cabinet ..Push in the tabs located 4 inches in from the sides.
Oct 20, 2012 | LG WM2455 Front Load Washer
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
I have a tromm wm1814cw washer .i am trying to replace gasket.not having any luck.can you inform me as to the secret. thank you
There are 2 special tools you will need to change the door gasket. Call LG and order the door spring removal tool. There are 2 of them.
Jun 15, 2011 | LG WM1814CW Front Load Washer
LG-INTELLO WASHER 7kg WD-8074FHB
"de" means door is open you have to close the door titly then press the start bottom or check door switch if its out of order or not with digital multi meter.
Apr 10, 2010 | LG WM1812C Front Load Washer
LG Washer leaks from front door
search the parts stores on internet then check ebay i find many times the common parts such as door gaskets can be had cheaper on ebay
Sep 29, 2009 | LG WM-2277HW Front Load Washer
LG Front Loan washing machine
If your LG is similar to mine, there could be water in a hose that is located behind the small door on the bottom front of the washer. Open the door and drain the hose. Be sure to have a bowl or pan to let the water run into. Once the water is drained hopefully the washer door will open. When i brought my washer this was one of the selling features the sales person told me about.( The door and hose are accessible to the consumer to prevent them from having to call for a repair) Hopefully this will be your only problem. I bought an LG washer on June 28, 2008. It is now August 21st and my machine is still broken. It broke the FIRST time I ever used it (July 13th) and it still has not been repaired. (Per the repair person it is a water sensor problem which has been "ordered") I wish I had purchased another kenmore instead. I had my kenmore 16 years and never ONCE has a problem with it. I simply wanted to update my laundry room. WHAT A MISTAKE for me to purchase LG!!!!
Aug 12, 2008 | LG WM-2277HW Front Load Washer
LG WM1814CW Front Load Washer Logo
24 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
